Maximum lift 2000 Tundra
Discussion in 'Suspension' started by RJ17, Feb 18, 2018.
  1. Feb 18, 2018 at 12:06 PM
    RJ17
    RJ17 [OP] New Member
    RJ
    2000 Tundra TRD
    hey guys, new to the Tundra community here!
    I recently purchased a 2000 Tundra TRD package, and I want to raise it, but not get into changing brake lines, steering extensions, and whatever else.
    Suggestions?
    Best places to shop?
    Thanks !!
  2. Feb 18, 2018 at 12:11 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Bilstein lifts is a good site. Toytec also. Try to steer away from spacer kits. I have one and I'm not happy with it. Fortunately it was already on the truck when I bought it. So, really no loss. Just doesn't ride that good. I'm looking at the Bilstein 5100's front and rear. It's a 2.5 inch lift in the front and i was going to get a 1 inch block kit for the rear.
    Bob likes this.
  3. Feb 18, 2018 at 12:29 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome!
    :worthless:
    RJ17[OP] likes this.
  4. Feb 18, 2018 at 12:50 PM
    RJ17
    RJ
    2000 Tundra TRD
    Thanks mudslinger79 I’ll check those sites out
    mudslinger79 likes this.
  5. Feb 18, 2018 at 1:27 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  6. Feb 18, 2018 at 1:40 PM
    RJ17
    RJ
    2000 Tundra TRD
    I’ll check out that link! Appreciate it
  7. Feb 18, 2018 at 1:56 PM
    Definitely check out ToyTecs' OME lift kit for your 2000. Complete OME kit is $860ish.
  8. Feb 18, 2018 at 2:36 PM
    RJ17
    RJ
    2000 Tundra TRD
    Thank you sir! I appreciate the input
  9. Feb 18, 2018 at 2:45 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Welcome from CO. I'm like you, I want a lift but don't want to change a bunch of lines or hoses. From what I've seen you can do this with a 3" lift. A 4" lift you the swapping out starts. Im looking at the Toytec lift myself. It comes with new coils which is nice. One stop shop.
  10. Feb 18, 2018 at 7:25 PM
    Casper421
    In the woods
    06 DC
    5100’s are a good option, especially if your shocks are blown or close too. Stepping up from 5100’s are Old Man Emu or Eibech coils and struts. Then you have the coilovers: Toytec, sway’s, ICON, Fox, king.
    All depends on your intentions, just want room for 33’s or off-road performance?
  11. Feb 19, 2018 at 4:17 AM
    RJ17
    RJ
    2000 Tundra TRD
    NCinCO, I was leaning to the 3” lift as well, which exact one are you getting ? Thanks
  12. Feb 19, 2018 at 4:23 AM
    RJ17
    RJ
    2000 Tundra TRD
    Casper421
    I’m not looking too much for off-road performance - I get that fix with my 4 wheeler when needed
    So i want a better look, a better stance, and room for bigger tires/ after market rims.
    As mentioned I didn’t want to get into having to change out a bunch of stuff to make it happen
    I appreciate any input. Thanks again
  13. Feb 19, 2018 at 9:27 AM
    Casper421
    In the woods
    06 DC
    Sounds like 5100’s meet your criteria. I would recommend setting the collar at the second or third notch. Then a 1” block or an AAL for the rear depending on how much you tow. You might want to consider a 1” diff drop if you set the front billies on the third notch. Hopefully preventing you from regreasing and reclamping a cv boot after installing the lift.
    Hope this helps.
    RJ17[QUOTED][OP] likes this.
  14. Feb 19, 2018 at 10:47 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  15. Feb 19, 2018 at 1:10 PM
    RJ17
    RJ
    2000 Tundra TRD
    I appreciate it man! Thanks
  16. Feb 19, 2018 at 1:10 PM
    RJ17
    RJ
    2000 Tundra TRD
    Thank you sir !
    831Tun[QUOTED] likes this.
