Bilstein 5100 adjustable after initial install?
Discussion in 'Suspension' started by Randy1794, Feb 17, 2018.
  1. Feb 17, 2018 at 12:14 PM
    Randy1794
    Randy1794 [OP] New Member
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Does anyone know if on can easily adjust the 5100 adjustable shocks after they have been install without completely removing them again?
    Thanks
    Randy
  2. Feb 17, 2018 at 12:19 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    The adjustable 5100 fronts have a groove in the shock where a ring sits in. Then your perch rests on top of that. Spring is then compressed on top of that.
    You will have to completely disassemble the shock then reinstall everything after changing the height setting.
    Randy1794[OP] and Stulloh like this.
  3. Feb 17, 2018 at 1:08 PM
    Randy1794
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Thanks, I had them installed yesterday and I had them set on the middle setting. I was curious, because I may want to bring them up to the top setting in the future, for a true 3/1 level. Just don't want to tear my entire front suspension apart again, just for one notch.
  4. Feb 17, 2018 at 2:44 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Yeah. Its a pain in the ass and the compresser tool can be dangerous. You can add a spacer above the top hat if you do not want to disassemble.
    Randy1794[OP] likes this.
