Thoughts on this 07 DC 4x4 for $12,900?
Discussion in '2nd Gen Tundras (2007-2013)' started by FloridaBoy99, Feb 10, 2018.
  1. Feb 10, 2018 at 7:31 PM
    FloridaBoy99
    FloridaBoy99 [OP] New Member
    Hello there, I am in the market for a used Tundra. Found a Toyota Dealership near me selling a 2007 Double Cab SR5 4x4 and they are advertising it is a 4.7L. Is that correct, I thought it would be a 5.7. It looks like it even has the 5.7 badge on the side in the pictures it has on the website, but they’re a little to blurry to tell. Could someone please let me know if that is right or not.
    Also, they’re asking $12,900, it has 140k miles, taken care of pretty well. And I’m pretty sure I will be able to get a good amount off with my military discount, would you recommend getting this? Thank you for your replies and time.
  2. Feb 10, 2018 at 7:34 PM
    FloridaBoy99
  3. Feb 10, 2018 at 7:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Welcome to the forum @FloridaBoy99 .
    It certainly can be the 4.7, they came with an i force badge too but it won't say 5.7 in red, I think it says V8 in black instead.
    As far as the price, etc.. Hard to tell without Carfax and pictures and a test drive.
  4. Feb 10, 2018 at 7:39 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Have you checked kbb.com for retail price and CarGurus, Autotrader, other dealers for similar trucks? Those are typically my go-to steps for determining if it's a good deal as far as price is concerned.
  5. Feb 10, 2018 at 7:44 PM
    FloridaBoy99
    Yea definitely searched everywhere and it was considerably lower. Also carfax checked out, got into a fender bender but other than that has been maintained pretty well. Also is the 4.7L a solid engine in the 2007? A buddy of mine has the 4.7 in the 06 and beats it to hell and has almost 300k miles
  6. Feb 10, 2018 at 7:45 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome!!
    FloridaBoy99[OP] likes this.
  7. Feb 10, 2018 at 7:49 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    Supercharged, TRD Dual Exhaust, Bilstein 6112's/5160's, TSS wheels, Toyo AT Xtreme 285/60R20, LED bed lights, Hellwig sway, PopNLock tailgate lock
    4.7 was the lowest trim level on the 07, so should be much lower in price. That still has a timing belt. Make sure it has been changed and you are price checking that trim/engine. (Loved that engine in my 05, but no match to the 5.7 or 5.7 SC).
    15whtrd and MotoTundra like this.
  8. Feb 10, 2018 at 7:50 PM
    FloridaBoy99
    Thank you! Hoping this “should I buy” post turns into “look what I bought”, and that turns into years of posting on here all the upgrades and mods I have planned.
  9. Feb 10, 2018 at 7:50 PM
    Ericsopa
    Ericsopa Old man and the sea
    According to the VIN, 5TFBT54117X008111, it is a 4.7L.
    NewImprovedRon and MotoTundra like this.
  10. Feb 10, 2018 at 7:53 PM
    FloridaBoy99
    I learned something new today, thank you. Would you recommend buying it? I mean for a first vehicle it’s not bad right? Same engine set up as the 06 model also?
  11. Feb 10, 2018 at 7:54 PM
    FloridaBoy99
    Thank you, I just wanted confirmation from the experts on here
  12. Feb 10, 2018 at 7:59 PM
    FloridaBoy99
    Thank you
  13. Feb 10, 2018 at 8:06 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Seems a bit high. What are taxes and fees in Florida? In Tx, that $12,900 would be closer to $14k.
    It is clean, dealer will more than likely sell it for close to that, easy financing......
  14. Feb 10, 2018 at 8:09 PM
    FloridaBoy99
    I have my own loan, low apr and I’m going to negotiate from the $12,900 down. So after it’s all said and done I wouldn’t mind $13-13,500 driving off the lot.
  15. Feb 10, 2018 at 8:09 PM
    Welcome from Texas!
  16. Feb 10, 2018 at 8:10 PM
    FloridaBoy99
    I appreciate it!
  17. Feb 10, 2018 at 8:12 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
    It is a good engine and will run for a long time as long as it is maintained properly. Same as the 00-06 tundra and sequoia through 07. If the timing belt/package has not been for the 2nd time make sure it is done as part of the deal!
    Truck looks clean. Check maintenance records and if you enjoy the drive and feel good, go for it.
    Brochure here to read about that year: http://www.auto-brochures.com/makes/Toyota/Tundra/Toyota_US Tundra_CM_4x4_2007.pdf
    Also pentagon federal credit union has great rates! easy if military.
  18. Feb 10, 2018 at 8:17 PM
    FloridaBoy99
    Thank you for the information, how much is a timing belt and what is the skill level required to change one yourself?
  19. Feb 10, 2018 at 8:21 PM
    cu52
    cu52 New Member
    Denver Metro
    13 Platinum CM
  20. Feb 10, 2018 at 10:02 PM
    trey169
    trey169 New Member
    SF Bay Area
    2007 Tundra DC SR5
    IMG_0101.jpg I just bought a 2007 Tundra DC with 101,800 miles on it. It is only a 4x2 but a 5.7 engine. Extremely clean in and out, clean carfax, one owner and all maintenance records done through a Toyota dealership. Had the belts, brakes and tires redone at inspection and it cost me $15000, which was $3000 lower than any other place I could find for trucks that were not as well maintained. However, I'm in California and it seems everything is more expensive here. Looking at kbb and other pricing websites are a good starting point, but what is the market for Tundra's in your area, that really drives the price from what I have seen.
    MotoTundra likes this.
  21. Feb 11, 2018 at 6:51 AM
    Trooper2
    JR
    KBB does show it in range for a Dealership in your area. If you have your own financing you may consider private party sellers. It does require a bit more work but could pay off. Private party values on KBB are up to $2-3K less. (I believe "Stealerships" make a lot of money on used vehicle, just my 2 cents)
    We recently bought 2007 from private party, it did pay off. It also required some hard work monitoring all the sites for auto / truck sales; (Craigslist, Facebook, Autotrader, CarGurus, etc.) about 4 months for us. It became a passion to find that great deal. I went ahead and got Carfax subscription for insurance. I also like to get a feel for the previous owner and how they took care of their vehicle. That one is pretty clean, probably well taken care of.
    Good Luck!
  22. Feb 11, 2018 at 8:36 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    If you have your own finance I will look for a private seller, there’s a lot of tundras for sale in south Florida, I’m sure you will find a well taken care truck for a lot less.
    Trooper2 likes this.
  23. Feb 16, 2018 at 9:57 AM
    Bpowa
    Bpowa New Member
    If you can look into a private party and loan from the bank. If you have not looked at it in person, there maybe more damages. A quick look at the pictures I see dents on the bumpers and tailgate.
