Automatic Climate control A/C turns on automatically in cold weather. Why?
Discussion in 'General Tundra Discussion' started by himmy33, Feb 20, 2014.
  1. Feb 20, 2014 at 8:13 AM
    himmy33
    himmy33 [OP] New Member
    Washington
    2014 Tundra 1794
    My truck has auto climate control and I typically leave it around 68 to 70 but sometimes when I turn the truck on it turns the a/c on as well. This is in cold weather where it would seem counter productive. Does anyone know why it does this. I can turn the heat all the way to high and it will not shut off unless I manually hit the the a/c button to turn it off. Not a big deal but was just curious why the truck does this? Is it to run the a/c every now and then so it does not sit unused for long periods of time? Should I leave it on until it turns off? Will it turn off if I leave it? Just curious if anyone else has noticed
    Thanks!
  2. Feb 20, 2014 at 2:03 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 Mall Crawler Extordinare
    All Pro Long Travel with Walker Evan Coil Overs, All Pro Expedition Leaves with Walker Evan Resi Shocks, All Pro IFS, transmission and E-Locker skid plates/guards, ARB Bumper with Kragen LED flood lights, 10,000lb SuperWinch, All Pro Rear Bumper, All Pro Sliders, Custom RTT Rack with Roto Pack, ARB Simpson RTT, Bed Tray. 285x75R16 Mickey Thompson MTZs and 285x75R16 Yokohama Geolander it g072. Airaid Short ram intake, Intake manifold spacer, Borla Cat back Exhaust.
    Is it when you turn on the windscreen defrost? Cause the A/C helps to dehumidify the air.
  3. Feb 20, 2014 at 2:44 PM
    himmy33
    Washington
    2014 Tundra 1794
    Nope. It's when Auto is engaged.
  4. Feb 20, 2014 at 2:53 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    This something new with the 2014's?
  5. Feb 20, 2014 at 8:45 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I used to have an Acura that did the same thing to control humidity. I didn't realize Toyota was doing the same thing... I bet it talks about it in your manual
  6. Feb 20, 2014 at 10:26 PM
    himmy33
    Washington
    2014 Tundra 1794
    I have a feeling it is to control the humidity but I'm not sure. I feel like leaving it on with heat is bad but maybe it is the system just working how it's supposed to. It just happens today. Drove the kids to the babysitter approx 15ish miles away. System on auto no a/c on. Jumped in the truck for the ride home and sure enough the a/c is on now. Strange. I think I will leave it for instead of turning it off like I normally do. We will see if it stays on or if it will turn off by itself...
  7. Feb 26, 2014 at 12:35 PM
    WyoBull
    WyoBull New Member
    2007 Tundra DC 4x4 5.7 V8
    Controlling the humidity is exactly what it is for. If you live in a higher humidity climate and leave it alone, you will definitely notice less condensation buildup during the colder months inside your truck.
    Wish I would have had this feature during those make-out sessions on lookout point back in the day! Would have had a lot less fogging going on inside the car!!! LOL!
  8. Feb 26, 2014 at 1:09 PM
    himmy33
    Washington
    2014 Tundra 1794
    Thanks for the confirmation. I personally liked the privacy the condensation brought... lol
