FLAT TIRE
Discussion in 'General Tundra Discussion' started by TRDProLife, Feb 14, 2018.
  1. Feb 14, 2018 at 1:14 PM
    TRDProLife
    TRDProLife [OP] LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    Found a nail in my trailer tire while getting gas...
    Neat trick I picked up a couple of years ago for all you trailer guys, use a board instead of a Jack quick and easy.
  2. Feb 14, 2018 at 1:16 PM
    15whtrd
    15whtrd Mr. Blonde
    Ahhh the beauty of a double axle!
    Newm and Scpringle like this.
  3. Feb 14, 2018 at 1:16 PM
    I like it!
  4. Feb 14, 2018 at 2:53 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    seen that done a few times , It think they make poly ramp / board set up to do the same thing (lighter / wont rot)
  5. Feb 14, 2018 at 3:28 PM
    Ps3udonymous
    Ps3udonymous Who is the smart ass that changed the title?
    Just bench press it, bro:benchpress:
  6. Feb 14, 2018 at 3:47 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    TRDProLife[OP] likes this.
  7. Feb 14, 2018 at 5:13 PM
    TRDProLife
    St.Louis
    Spend money!!??? I've also just pulled up on a curb before even lighter and less rot. Also I always have a board to pull motorcycles with large fenders up too, and block up the trailer soooo. No need for fancy thongs here.:spending:
  8. Feb 14, 2018 at 6:12 PM
    sk8142
    sk8142 New Member
    Shawn
    WA
    2014 Black Tundra TRD
    Bilstein 5100 F&R - Front middle setting w/2 CB shims Toytec rear shackles @ 1" setting Method NV 18x9 +25 Bronze 295/70/18 Nitto Ridge Grappler Retrofit headlights with Morimoto DS2 4.0, Apollo 3.0 shrouds, switchbacks Prodigy P3 brake controller
  9. Feb 17, 2018 at 8:22 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    I drive a semi for a living ands that’s how tire company’s change tires on trailers.
