Removing BIG FAT V8 Door emblem
Discussion in '2.5 Gen Tundras (2014-2021)' started by Darth Tundra, Feb 11, 2018.
  1. Feb 11, 2018 at 12:47 PM
    Darth Tundra
    Darth Tundra [OP] I AM....YOUR FATHER
    Curt
    17 CM TRD Black
    HELP !!!...Who here has removed this emblem with success....and EXACTLY HOW DID YOU DO IT ????..Thanks in advance for your input !!!
    Notachickmagnet and geno0506 like this.
  2. Feb 11, 2018 at 12:51 PM
    Kmiller002
    Kmiller002 New Member
    2016 Tundra Platinum Blazing Blue Pearl
    Did it on my last tundra...used a heat gun on low setting for a few minutes, then used some fishing line to take off. Came off like butter. Then just cleaned off the glue with some soap and water then used some spray wax. Could never tell it was there.
  3. Feb 11, 2018 at 12:52 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Did you notice how TIGHT the emblem is up against the door ?
  4. Feb 11, 2018 at 12:55 PM
    Kmiller002
    Ya it’s pretty tight. Once you heat it up a little, get that fishing line in between the emblem and the door then use a cutting motion and should come off fairly easy. Just don’t heat up too much. Low setting and hold it a couple inches away or so. At least this worked for me on all my emblems. Hope this helps. Lemme know if you have more questions.
  5. Feb 11, 2018 at 1:06 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Quit being a bitch and go heat that thing up
  6. Feb 11, 2018 at 1:14 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    I know a lot of MEMBERS prolly dont know I run a bodyshop and I know how to remove it....its just the damn emblem is TIGHT up against the door...I'll get it off...just curious to see if any members had a HARD time with this particular V8 badge :notsure:
  7. Feb 11, 2018 at 1:27 PM
    Funny Scott, I was thinking “this guy runs a body shop. He’s messing with us.”
    Cool way to remove it @Kmiller002
  8. Feb 11, 2018 at 1:57 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    This ^^^^^^^^^
  9. Feb 11, 2018 at 3:03 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    :eek::eek::eek::eek:
  10. Feb 11, 2018 at 3:13 PM
    Agitated1
    Agitated1 Newish Member
    Los Angeles
    2017 Tundra Crewmax TRD 4x4 Quicksand
    TRD Pro Grill King Coilovers with compression adjuster Tint 5% Rear, 30% front and 70% windshield Husky X-Act Floor liners BA Muffler 8in standard system Truck Covers USA retractable bed cover Yakima bed rails
    I had no problems.
    Notachickmagnet likes this.
  11. Feb 11, 2018 at 3:17 PM
    Dang Scott..use a frigging Binford 2000 crow bar..:cheers:
  12. Feb 11, 2018 at 3:28 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Mine is tight to, if I were to remove it I'd probably use a 12 gage shotgun...
  13. Feb 11, 2018 at 3:53 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Tim Allen style
  14. Feb 11, 2018 at 3:58 PM
    geno0506
    geno0506 New Member
    Michael
  15. Feb 11, 2018 at 4:03 PM
    geno0506
    geno0506 New Member
    Michael
    Easy as moms warms apple pie just heat it up and go for it!
  16. Feb 11, 2018 at 4:43 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    20180211_164249.jpg ONE DOWN....ONE TO GO
  17. Feb 11, 2018 at 6:13 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    20180211_175813.jpg 20180211_181127.jpg Off with the chrome. ...on with the Factory Toyota black badges :D :bananadance:....A BIG THANK YOU AND SHOUT OUT TO @SR5TRDTUNDRA for shipping these to me ALL THE WAY from Alberta !!!....I will be returning the favor SOON !!!!!!
  18. Feb 11, 2018 at 9:19 PM
    dieselkeane
    dieselkeane New Member
    2014 White Tundra
    I just did the same thing yesterday. I just let the truck sit in the 70 degree weather, used 30lb test, and a rubber wedge. I worked it to get it behind the badge and pulled back and forth. It took about 2 minutes each side. I sprayed it with simple green and peeled it off. Then i used the 3m rubbing compound to clean it up.
  19. Feb 12, 2018 at 7:05 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Friggin HILARIOUS
  20. Feb 12, 2018 at 7:17 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    You can use a hammer. You have to be accurate and not miss. Stay steady and breath.
    Smiley and Notachickmagnet like this.
  21. Feb 12, 2018 at 7:27 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Uhhhh....ya......NO
  22. Feb 12, 2018 at 7:48 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    nothing wrong with that.
