DIY wheel well liners
Discussion in 'General Tundra Discussion' started by ZPMAN, Feb 10, 2018.
  1. Feb 10, 2018 at 4:58 AM
    ZPMAN
    ZPMAN [OP] 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    Spent a day making up a wheel well liner for the Tundra. Living on dirt roads and the salt i thought a little more protection would be nice. Wrote to Husky and asked why they only make liners for big 3 , there reply was tundras already have a liner. Stock liners don't cover much.
    Look at this on eBay http://www.ebay.com/itm/131499725150
    20180209_121333.jpg 20180209_145748.jpg 20180209_123421.jpg 20180209_150014.jpg
    One thing i should have done was removed the emergency brake cable and route it under the leaf spring because of the 2" lift block. That would have prevented so much cut out in the middle.
  2. Feb 10, 2018 at 5:13 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Pretty awesome mod, man. This is giving me some ideas.
    ZPMAN[OP] and Black Wolf like this.
  3. Feb 10, 2018 at 12:05 PM
    ZPMAN
    Minnesota
    You can heat and mold this plastic if you have to, i just started to bolt it in place then used a heat gun + propane torch and pretty much formed it self. The drivers side should go much faster.
    gosolo likes this.
  4. Feb 10, 2018 at 12:10 PM
    One of the best purely practical mods here lately:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
    ATV25, Law323, Inquiringone and 4 others like this.
  5. Feb 10, 2018 at 12:12 PM
    Just now ordered a roll off Ebay:thumbsup::thumbsup::thumbsup:
    831Tun and ZPMAN[OP] like this.
  6. Feb 10, 2018 at 1:32 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    I'll definitely be doing this. Thank you for sharing
    ZPMAN[OP] likes this.
  7. Feb 10, 2018 at 4:47 PM
    ZPMAN
    Minnesota
    NP and thank you, will be working on something for the front and i have some bettor mud flaps to install.
  8. Feb 10, 2018 at 5:56 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Well, that is a pretty innovative modification. Came out good!
  9. Feb 10, 2018 at 5:58 PM
    Great MOD great job!
  10. Feb 10, 2018 at 7:09 PM
    ZPMAN
    Minnesota
    Will be making a small bracket for center support of liner, there are two holes in frame by the upper stop mount.(yellow) I got my bolts and extuded U nuts from a local auto body supply shop.20180210_144732.jpg
    Update: did not have to make any center support, the liners are still 2 1/2" to 3" away from tires.
    Edit
    I did not have to make a bracket, the liner is still at least 2 1/2" away from wheels
    ATV25 and (deleted member) like this.
  11. Feb 10, 2018 at 7:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good work. Looks clean.
  12. Feb 10, 2018 at 7:16 PM
    ZPMAN
    Minnesota
    Also when i got the plastic i rolled it out on my heated slab and put a few weights on it for a day made it much easier to work with. The length of plastic i started out with was 54" to be on the safe side
    MotoTundra likes this.
  13. Feb 12, 2018 at 9:38 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Good idea!!!
  14. Feb 12, 2018 at 10:14 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Slick!
  15. Feb 12, 2018 at 1:16 PM
    ZPMAN
    Minnesota
    This is slick for a 52 year old, i miss racing.Screenshot_20180204-083002.jpg
    ATV25 and geno0506 like this.
  16. Feb 13, 2018 at 8:11 PM
    ZPMAN
    Minnesota
    Part 2 the drivers side install.
    It took about 2 hrs to install, much quicker then the first.
    The stock clips are a pain in the ass to remove epically if you are using bushwacker flairs (clips get distorted from flair screws), what i did is replaced all of them with these clips and bolts, was about $20 from an auto body supply shop.
    I cut off a 56" piece and centerd it between the top two mounts. Cliped in place with vise grips. Used a pick to find the mount holes , then drilled the 4 holes out with a 1/4 bit.
    Pull the plastic down and install the clips then reinstall plastic and loosely install bolts.
    I found it was easier to just use the pick then drill the holes and use a nut and bolt to temporally hold it in place. After all bolts are in place i used a little heat so the plastic would take shape. Make sure you have enough plastic on the lower part of panel for your tire clearance.
    Rica25 likes this.
  17. Feb 13, 2018 at 8:23 PM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Clever thinking and looks sweet
    Rica25 and ZPMAN[OP] like this.
  18. Feb 13, 2018 at 8:50 PM
    ZPMAN
    Minnesota
    Take the unit down, then cut 1/2" away from holes and install clips. Reinstall unit and now and put on back side of framework. Start bolting in place and trim as you go. After it's all trimed and bolted in place you can heat it if needed to take final fourm. Dont forget to trim out for the emergency brake cable and axle, i jacked up the wheel and trimed as i went, make sure you take into consideration of the rubber stop being compressed an inch or two.
    Good luck, I've had to many beers.
  19. Feb 15, 2018 at 7:35 PM
    ZPMAN
    Minnesota
    It got up to +37`yesterday and washed the truck befor going into town to pick up my new floor mats. Now i its time to wash it agian.☹20180215_195543.jpg
  20. Feb 15, 2018 at 7:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Just gonna send it
    Rica25 and Vendeta2k like this.
  21. Feb 15, 2018 at 7:47 PM
    Pudge
    CT
    Great job and awesome idea. I did something similar years ago on my taco that had a body lift becsuse it looked like crap. This material looks much nicer and useless that the old "gap guards". I may have to buy a roll this summer
  22. Feb 15, 2018 at 7:54 PM
    Nice work!:thumbsup:
  23. Feb 15, 2018 at 9:41 PM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    This is badass! Great work and ill definitely refer back to this for my front inner fenders since I went with fiberglass fenders
  24. Feb 15, 2018 at 11:01 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Nice work!
  25. May 2, 2018 at 11:56 AM
    MammothGuardsUSA
    MammothGuardsUSA New Member
    Justin Mitchell
    Toyota Tundra Gap Guards
    A lot
    I want introduce you to a new product. They are called Mammoth Guards by Mammoth MetalWorks. We have designed these guards to work with 07-17 Tundra’s without body lifts. They are 16 gauge steel and we use Prismatic Powders for coating.Production will be starting May 7th and we will begin shipping in order received starting May 25th. After May 25th there will be a minimum 1 week lead time. We have several colors to start out with Light Blue, Dark Blue, Red,White, Mammoth Grey and Black. We are working on other patterns and colors and will update our Instagram as they become available. The great thing about our design is as we add designs and colors you can simply change out a layer to suit your builds needs. All of our sets come with new hardware for install. You can check out our Instagram page @MammothGuardsUSA or website www.mammothmetalworks.squarespace.com where we have more pics and an install video. If interested you can PM me directly or DM us thru Instagram. We look forward to serving this great group.
    CaptSpaulding and 1UPPER like this.
  26. May 2, 2018 at 11:57 AM
    MammothGuardsUSA
    Justin Mitchell
    A lot
  27. May 2, 2018 at 12:04 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    @MammothGuardsUSA I took a few photos of them in Tennessee this past weekend. Looked really good!
  28. May 2, 2018 at 3:34 PM
    Professional Hand Model
    Fred
    Hand Protectors
    These Mammoth ones remind me of butterflies. Something girls would put on their truck.
    The original posters fab is pretty cool looking. Thanks for the pics and write up. Are there any new noises with the wind travel speeds? Quieter?
  29. May 2, 2018 at 5:14 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Send me some leftovers.
    I wouldn’t love to cover the front by the fog lights when I sliced up from rubbing. Deal????
  30. May 3, 2018 at 3:24 PM
    ZPMAN
    Minnesota
    Well i have to say I'll give you an "A" for artistic value, but as for protecting the frame and undercarriage from salt and rocks in northern Minnesota i would give it a solid "D". As for the price,,, $150 to $250 thats alot beer.
    BravoDeltaRomeo, Jfuggint and Major like this.
