Installing bed lights, need wiring help on 2018
Discussion in '2.5 Gen Tundras (2014-2021)' started by coreman23, Jan 20, 2018.
  1. Jan 20, 2018 at 11:13 AM
    coreman23
    coreman23 [OP] New Member
    Cory
    2018 4wd Crewmax Tundra
    I bought some led’s to go on my bed rail under my tonneau cover.
    https://www.amazon.com/gp/aw/d/B01JUE9OLM/ref=yo_ii_img?ie=UTF8&psc=1
    I’d like to run it off my cargo lights. I have the sparks pdf with the wiring info, but it’s for a 2015, my 2018, and I don’t have the brown wire to hook up. Before I go testing all the wires, I thought I would check here to see if anybody with a 2018 has done it before and where they taped in.
  2. Jan 20, 2018 at 2:52 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I don't have the answer for you, but hopefully someone will chime in.
  3. Jan 20, 2018 at 5:14 PM
    coreman23
    Cory
    Thank you, I’ll give it a shot.
  4. Jan 20, 2018 at 9:15 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I also installed the lights on my 2018 today and have the same issue. I contacted the seller (Toyota dealer on eBay) and asked for updated instructions. They should be available because Toyota sells them for the 2018 Tundra (page 29 in the brochure). I really want it connected under the dash since I already run the harness.
  5. Jan 21, 2018 at 4:52 AM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    I'm doing the same thing soon. I ordered the color changing LED's so I can lite up my bed orange to match my Inferno Tundra
  6. Jan 21, 2018 at 2:55 PM
    coreman23
    Cory
    Let me know if you hear back. I tried to find the wire in my rear drivers side floor, but couldn’t find anything. I’m installing a pop and lock, and would like to just run all those wires in 1 shot.
  7. Jan 21, 2018 at 3:27 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is what I did, run all the wires at the same time. By the way, I run the P&L wires through the floor grommet in front of passenger seat, no need to go all the way through the engine bay. The P&L wiring instructions are wrong, there is a video on youTube giving you the correct wires (just search 2018 Tundra Pop & Lock).
    As far as the bed light wiring, I did get a replay. There are no 2018 instruction out But he sent me some for a 2018 Taco. I probably just install a switch for now and once instructions are out I will correct it so it works as designed.
  8. Jan 21, 2018 at 3:33 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Forgot, here are the two sheets for bed lights the seller send me. I could probably figure it out if I had that particular wiring diagram page for a 2018 Tundra, with CAN Bus is not as simple as probing for a "hot" wire.
  9. Jan 23, 2018 at 3:04 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I asked one of the vendors about it and they sent me the 2018 specific instructions
  10. Jan 23, 2018 at 3:54 PM
    coreman23
    Cory
    You are the man!!! Thanks
  11. Jan 23, 2018 at 5:37 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    That is great............we have instructions for the 2018. The only thing I don't get is the inline fuse (Figure 3i) which mysteriously appears but is neither part of the kit nor is it mentioned anywhere else in the instructions that I can see. No big deal, a fuse makes sense and they are sold at every auto parts store.
    Thanks for posting the instructions.
  12. Jan 23, 2018 at 6:31 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    How are you attaching the lights? On my Tacoma I ended up having to use 3m tape. Then the lights burned up after a year. I replaced with 8" submersible bars. Mine were mounted under tie down rails and bed was open so somewhat exposed. They were supposed to be waterproof. I really liked them when they worked.
  13. Jan 23, 2018 at 11:07 PM
    TTund16
    TTund16 New Member
    @RowdyRon can we tap into the 7 pin tow connector in the back. I think it has an auxiliary power pin. not sure ... I also have not looked into the spec yet as to how many amps it can support, etc. have you looked into this? Thanks
  14. Jan 24, 2018 at 3:40 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    You are supposed to drill three holes for each light (2 mounting, 1 for the harness) and attach them with the provided screws. The instructions come with templates that show you where to drill the holes, pretty easy job.
  15. Jan 24, 2018 at 5:02 AM
    AlexWV
    AlexWV Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    Those look nice. I wish I had any wiring skill at all to attempt it myself.
  16. Jan 24, 2018 at 6:36 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Just two wires to connect. It is pretty easy and the instructions are good, you just have to use the older instruction version for your 2014.
  17. Jan 24, 2018 at 9:29 PM
    TTund16
    TTund16 New Member
    I am not doing anything yet but maybe bed lights or backup lights in the future ... I can connect the backup lights to reverse light I assume and for bed lights I was thinking of getting the power from the tow connector aux power pin. I haven't check the power requirements of the bed light and the spec for the auxiliary power pin (if any) ...
    NewImprovedRon likes this.
  18. Jan 25, 2018 at 3:39 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Good to know they are not the the peel and stick type. May have to look at those. No real need since I have LEDs in overhead and no cover.
  19. Jan 25, 2018 at 9:12 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I did same except I just tapped the reverse circuit without the relay and additional wire. I have leds in factory dockets so plenty of capacity on circuit
  20. Jan 28, 2018 at 5:28 PM
    coreman23
    Cory
    I tried to download this again, and it wasn’t working, is it just me?
  21. Jan 29, 2018 at 8:50 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Got my bed lights working this morning the way they are supposed to by using the instructions for the 2018. That is 2 out of 3, bed lights and P&L work remote start was a No Go. It is already sold, my truck is back together and cleaned up.
  22. Jan 29, 2018 at 9:10 AM
    coreman23
    Cory
    I couldn’t get it to open, but now it works, have it saved, thanks!
  23. Jan 29, 2018 at 1:16 PM
    coreman23
    Cory
    So I got it all hooked up, but have one issue. I kept the included switch hooked up, thinking I was smart. Here is my issue, when I turn the switch on, my bed lights work, but the cargo light turns off. The lights also aren’t as bright as I’ve seen online. When I turn the switch off, the cargo light comes back on. Should I just scrap the connecting to the cargo switch and wire directly to the battery?
    Will removing the switch possibly fix it?
  24. Feb 6, 2018 at 11:21 AM
    coreman23
    Cory
    Can you share how you installed your bed lights? I got mine installed, but I installed my included switch, and when I turn the bed lights on, the cargo lamp shuts off. Trying to decide if I should just clip off the switch, or go directly to the battery.
  25. Feb 6, 2018 at 12:15 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I followed the instructions given in the attachment in post #12. My bed light kit didn't come with a separate switch, they work off the cargo light switch, when you open the door or pushing the remote key fob.
  26. Feb 7, 2018 at 10:15 AM
    doug20666
    doug20666 New Member
    Doug
    18 Inferno TRD Off Road
  27. Feb 7, 2018 at 12:10 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I bought a 2017 kit and used the 2018 instructions to install and wire it up. Only difference is that they show an inline fuse in the 2018 instructions (and obviously different wires to tap into), the fuse wasn't included in my kit since the 2017 doesn't use one. You can find them at any parts store for a few bucks.
  28. Feb 7, 2018 at 12:27 PM
    doug20666
    Doug
    Thanks for the info 71_340. I asked the parts department about the lights and they told me they couldn’t get them it was a port installed option.
  29. Feb 7, 2018 at 12:30 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    just order a 2017 kit of eBay like I did. I think I paid around 65.00 shipped.
    doug20666 likes this.
  30. Feb 7, 2018 at 4:10 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
