  1. Feb 4, 2018 at 4:19 AM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    The safe is sold by Lock’er Down. The organizer is just one of the full size ones, cut to fit. Bought it on Amazon for $12.99. There are quite a few on there, but they’re all the same, just get the cheapest one that ships free, if you’re a Prime member.
  2. Feb 4, 2018 at 4:21 AM
    jmdaniel
    Leander, TX
    :rofl::rofl::rofl:
    Sunnier[QUOTED] likes this.
  3. Feb 4, 2018 at 4:26 AM
    SCCachr
    SCCachr I love geocaching!!
    SC
    2018 Tundra TRD Crew Max 5.7L 4X4 Blaze Blue
    When I switched to LEDs on my FJ cruiser I just replaced the flasher module and didn't need to use the resistors.
  4. Feb 4, 2018 at 4:28 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Are those rear blocks hollow?
  5. Feb 4, 2018 at 4:32 AM
    jmdaniel
    Leander, TX
    Another difference between the two, at least in pictures I’ve seen of the SE Toyota half safe, and my experience with the Lock’er Down, is that the lid on the latter is spring loaded. That means that no tab is needed, in order to pull it open. When I spoke to the owner of Lock’er Down about the bad bolts I was sent initially, he said that tab was required when SE Toyota came to him about making a safe for them, and he refused, as it’s simply something that can easily be pried up, and with the spring hinge, not needed.
    Again, I know there are folks that have gotten bent out of shape, (w/o the use of a pry bar!), with my comments on the SE Toyota safe. Enjoy what you have, I bought the Lock’er Down and am happy with my purchase. Life is good with choices.
  6. Feb 4, 2018 at 8:12 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    One of my favs too...the Mrs. gets tires of hearing me tell others no "negative waves" hahah
    NewImprovedRon likes this.
  7. Feb 4, 2018 at 8:24 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Please tell me more...you just used the LEDs with a new flasher...so, how did you choose a new flasher that would work with the LEDs? I like the idea of this...
    AxelsHumanDad and Sunnier like this.
  8. Feb 4, 2018 at 8:47 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    @geno0506 here's how mounted mine.
  9. Feb 4, 2018 at 9:02 AM
    dmiller
    dmiller New Member
    Dusty
    Guntersville, AL
    '18 MGM CM SR5 XSP
    BD Squadron Sport Amber WC Fogs
    Someone want to explain the advantages/disadvantages to the different mounting options?
    Darth Tundra likes this.
  10. Feb 4, 2018 at 9:03 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    If off roading...your better off mounting it higher up as to not tear up the sway bar
  11. Feb 4, 2018 at 9:06 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    It's real advantages are considerably more noticeable for street driving...thats why I mounted mine per Toyotas instructions
  12. Feb 4, 2018 at 9:29 AM
    geno0506
    geno0506 New Member
    Michael
    Awesome, thanks
    mgm16trdpro[QUOTED] likes this.
  13. Feb 4, 2018 at 9:33 AM
    geno0506
    geno0506 New Member
    Michael
    :cheers: Thanks for your service brother!
  14. Feb 4, 2018 at 10:41 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yea we know the sausage is tucked between the buns half of the day here.. :dancingbacon:
    Hey , if you love the attention.. cool
  15. Feb 4, 2018 at 11:40 AM
    proachman
    proachman New Member
    Reno Nv
    2017 Tundra Platinum 4x4
    4" Fab-Tech lift with dirt logic coil overs in front and shocks in rear, 20" Raceline Wheels, TOYO AT 295/65 R20, TRD Dual exhaust, K&N 77 Series CAI, 2018 Platinum Grille, 100% LED Lighting, Spray-in Bed Liner, Tri-Fold Tonneau Hard Cover, Color matched handles and mirror caps, Ceramic window tint on all 7 windows, TRD Shift knob, Nerf Bars, Driver side grab handle, Clear bra on entire front end.
    Quick question.. how do I get the key fob to automatically set the seat program to one or 2? I tried following the manual, to no avail... am I doing something wrong?
  16. Feb 4, 2018 at 11:51 AM
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    @easleycrawler I went with 1.5". They're not well known as far as i know, but they drive well and I checked them today after 100 miles and they were still torqued. They fit tightly on the hub and the wheel (even without the studs), just like my previous Spidertrax. Other than the color and width, I don't notice any outward differences between these and the Spidertrax. https://smile.amazon.com/gp/product/B07544PGK8/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
    mgm16trdpro likes this.
  17. Feb 4, 2018 at 11:53 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Side steps, @bajadesigns sport amber.. froze putting them in 10 degree windchill.. look great though
  18. Feb 4, 2018 at 12:51 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ohhh that’s perfect!!!! #Itputsthelotionontheskinorelseitgetsthehoseagain :rofl::rofl:
  19. Feb 4, 2018 at 1:03 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Thanks. Now I just need to find me a set of those wheels.
    912[QUOTED] likes this.
  20. Feb 4, 2018 at 1:11 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I see you Caitlyn
  21. Feb 4, 2018 at 1:46 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  22. Feb 4, 2018 at 1:56 PM
    mgm16trdpro
    Northern NJ
    912 and Jsena like this.
  23. Feb 4, 2018 at 1:58 PM
    mgm16trdpro
    Northern NJ
    That's 1 hell of a deal i just found for ya too. The tires themselves are probably worth that, now u get the wheels for free.
    757TUNDRA likes this.
  24. Feb 4, 2018 at 2:04 PM
    easleycrawler
    Travis
    Thanks. Contacting now.
    Sunnier and mgm16trdpro[QUOTED] like this.
  25. Feb 4, 2018 at 2:06 PM
    mgm16trdpro
    Northern NJ
    Ur welcome. Smart move don't wait, I doubt they will last too long.
  26. Feb 4, 2018 at 2:18 PM
    mgm16trdpro
    Northern NJ
    I run them tires in 295/70r18 on oem pro wheels and love them. Now u can kill 2 birds 1 stone. If u don't want the tires u will have zero issues selling bc everyone else does want them. I think I got mine new for just under that. If u sell them u get the wheels free or close to it. If I was u I'd rock them with the tires, they're bad ass tires. Good luck.
    Sunnier likes this.
  27. Feb 4, 2018 at 3:05 PM
    easleycrawler
    Travis
    Haven't heard back from him yet. I think those tires will be a little big for my truck. I'm running 285/55r20's now, I have very little clearance now. My truck is a 2wd sr5.
  28. Feb 4, 2018 at 3:08 PM
    mgm16trdpro
    Northern NJ
    Oh ok, yeah can't comment on fitment, worst case though u sell the tires and get the wheels for free or almost free. Good luck either way. I just remembered seeing that post the other day and figured I'd try to help ya out.
  29. Feb 4, 2018 at 3:16 PM
    easleycrawler
    Travis
    I definitely appreciate it. Just waiting to hear from him.
  30. Feb 4, 2018 at 5:19 PM
    Deucemimo
    Deucemimo New Member
    2014 Tundra 1794
    Installed LED Headlights today.
    driverdog, Munk, classic17 and 13 others like this.
