Cats failing
Discussion in '2.5 Gen Tundras (2014-2021)' started by BOBONTUESDAY, Jan 29, 2018.
  1. Jan 29, 2018 at 8:32 PM
    BOBONTUESDAY
    BOBONTUESDAY [OP] Grocery Getter
    2016 Limited Trd
    One of the cats are failing at 122k I can smell rotten egg consistently. I'm hoping the stealership will fix it under warranty as I've got 3k left on my 125k or 7 year warranty.
    If they don't I'll just run it till it either throws a code or gets to loud. I'm surprised it's already failing. Anyone running bad cats with no problems? I really don't want to fall into limp mode or something of the sorts.
    122k 2016 5.7 stock exhaust.
    Y0TA PR0 likes this.
  2. Jan 29, 2018 at 8:45 PM
    Damn! Grass doesn’t grow under your Tundra with those miles and being a 2016!!!
    I would be looking into why your cats are failing.
    Spark plugs are due at 120k miles, and assume you have done that right? I would look into this first. Cheapest fix, but once your catalytic converters go bad......
    Piston rings, valve guides, or other engine components that are damaged can also cause this problem. Since it is a Toyota, I’m going with spark plugs first, and a likely cause.
  3. Jan 29, 2018 at 8:56 PM
    BOBONTUESDAY
    2016 Limited Trd
    Sometimes it sits for a couple hours when I'm sleeping. Lol
    I'll have to check the spark plugs I didn't even think of that. I did them at a 100k so I don't think it could be that. There's absolutely no change in the actual function of the truck it doesn't drive differently there's no lack of power nothing odd no weird sounds. I would notice a weird sound I spend a lot of time with the truck. I'll check the plugs in the morning. At first I thought it was a natural gas leak. Then I smelled my exhaust.
    I'm just surprised it's happening this early my Tacoma had cats fail somewhere around 200k.
  4. Jan 29, 2018 at 9:00 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Holy did you go around North America in two years? Lol
    darkknight2014 and ColoradoTJ like this.
  5. Jan 29, 2018 at 9:08 PM
    BOBONTUESDAY
    2016 Limited Trd
    I'd say about 90% of it was in Minnesota. Then the rest was between Colorado and Illinois. Lots of Towing always hauling something this truck has definitely not been babied.
  6. Jan 29, 2018 at 9:17 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Nice! Hope you get that cat fixed. And good to know the tundra is holding up strong after all does miles is short period of time.
  7. Jan 29, 2018 at 9:21 PM
    Maybe change brand of fuel. One of my good friends has had two Lexus IS300’s with the dredded smell. Comes to find out on his 16’ IS300 is was just the brand of gas. Hasn’t been back in 15k miles.
    I’m assuming that this smell has been over a few tanks of fuel.
  8. Jan 29, 2018 at 9:32 PM
    15whtrd
    15whtrd Mr. Blonde
    Maybe you need to floor it now and again to keep them cleared out. Sometimes I smell it on new cars. I just figure they drive like an old lady and finally grew some balls.:burnrubber:
    Edit just read that you tow
    blue16 and BOBONTUESDAY[OP] like this.
  9. Jan 29, 2018 at 9:36 PM
    BOBONTUESDAY
    2016 Limited Trd
    Thanks. It's been a good truck I've definitely taken care of it more than my other ones. I've had more problems from trucks that sit.
    I'm about 2 and a half tanks in. It started around Friday. I try to only fill up at larger gas stations to avoid bad fuel but it could still happen. I can't smell much today or I'd go check right now lol.
    Y0TA PR0[QUOTED] likes this.
  10. Jan 29, 2018 at 10:45 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Run some sea foam in the tank while at it.....
  11. Jan 30, 2018 at 5:37 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    sorry if i missed it, but it doesn't sound like OP has a thrown a code yet for bad cat converter. sounds like the only indication the cats might be bad are the smell of the exhaust. i'd venture a guess that his cat converters are fine.
    15whtrd likes this.
  12. Jan 30, 2018 at 3:44 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    I kinda agree with this. No codes yet, i would prob leave it alone. Maybe fill up at a different station. Just keep the thought in the back of my mind
  13. Jan 31, 2018 at 3:11 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Throw some high octane fuel in her. Thats what i was told when my sports cars sat for the winter to clean it out.
