Can I fit 35s on it
Discussion in 'Wheels & Tires' started by Jduck031, Dec 21, 2015.
  1. Dec 21, 2015 at 9:14 AM
    Jduck031
    Jduck031 [OP] New Member
    I have a 2nd gen tundra with a 3 and 1 lift and have always ran 325/60/18s on it with no probs. Could i put 1in wheel spacers on it and fit 35x12.50s or maybe 325/65/18s? Has aftermarket xd rims.
  2. Dec 21, 2015 at 11:47 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Short answer, yes you can with proper offset.
    It really depends on the offset of the wheels (wheel spacers typically will make the tires to have more serious rubbing problem, unless you have factory wheels). Do you know that your wheel's offset? Which xd wheel do you have? Which tire are you thinking of going with? BFGs tend to run somewhat smaller than spec and Nittos tend to run somewhat larger than spec.
  3. Dec 21, 2015 at 12:19 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Ditto on the above reply. I have a 2.5" lift on mine and run 35's.
  4. Dec 21, 2015 at 5:34 PM
    Jduck031
    I have 18x9 hoss rims. I think +18. I have Hankooks on it now and really like them, thought about going w them again.
