New windshield install
Discussion in 'General Tundra Discussion' started by Rotty23, Jan 29, 2018.
  1. Jan 29, 2018 at 7:16 AM
    Rotty23
    Rotty23 [OP] New Member
    Phil
    Upstate SC
    2014 1794 CM 4x4 Blue Ribbon Blue Metallic
    TRD Pro grill, TRD rear sway bar, Bilstien 6112 up front set at middle setting, Bilstien 5160s on rear, BFG KO2s on Method 20x9 wheels, drilled and slotted rotors, color matched front bumper caps, mirror caps and door handles, BA 8" stainless exhaust, TRD Pro skid plate, drivers side grab handle
    IMG_0010.jpg They are coming to the house today to install a new windshield on the the Tundra. I'm just wondering if there is anything I should be aware of during and after the install.
  2. Jan 29, 2018 at 7:47 AM
    How bad was old one?
  3. Jan 29, 2018 at 7:48 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    some Tundras have a heater element in them for the windshield wipers...
    Rotty23[OP] likes this.
  4. Jan 29, 2018 at 7:53 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    1. carefully look around the windshield for paint damage or excess primer.
    2. Look on the outside and inside for excessive urethane squish. (this is what glues the windshield in place).
    3. Look for A-pillar trim and headliner damage.
    4. When you drive listen for excessive wind noise and carefully watch around the inside the next time you go thru a care wash. It is not uncommon to have a windshield leak. This will appear as either water on the floor board, or water on the headliner / a pillar.
    5. After the windshield has set (couple days later). Very lightly push on the inside edges, DO NOT PUSH HARD you can break the glass by pushing too hard. you are just looking for adhesion issues where the glue may not have adhered to the glass or body.
    6. test your wipers to make sure they were correctly positioned.
    This is correct - depending on the region your truck is from it could be all Tundras. If you have heated side mirrors you probably have a heated windshield.
    Hope that helps.
  5. Jan 29, 2018 at 7:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    There's a picture.....lol
    Make sure the new windshield has the gradient tint along the top 4-6 inches.
  6. Jan 29, 2018 at 8:03 AM
    Yes I see but it doesn't show anything wrong
  7. Jan 29, 2018 at 8:16 AM
    Rotty23
    Phil
    Upstate SC
    Look in front of the steering wheel and u will see the crack curving up. It runs all the way to the passenger side A pillar.
    It wasn't there before our cold snap and 4" of snow...cleaned the snow off and there it was so I'm not sure what happened.
    4x4_Angel likes this.
  8. Jan 29, 2018 at 8:18 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    You probably took a rock in the black band. Look along the path of the crack and look for some small impact. IF there was no impact go to your Toyota dealer and have it covered under warranty.
  9. Jan 29, 2018 at 8:20 AM
    Rotty23
    Phil
    Upstate SC
    Thanks to all for their replies...I will for sure take this advice...I do have heated mirrors but not sure about a heated windshield
  10. Jan 29, 2018 at 8:22 AM
    Rotty23
    Phil
    Upstate SC
    It's a 2014 so I'm not sure it's covered under warranty but insurance pays 100%.
  11. Jan 29, 2018 at 9:41 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    You would have a heated windshield. There just isn't way to really tell until you pull the wipers and cowl off.
    It looks like you have a 1794. Yes you would have a heated windshield.
    Rotty23[QUOTED][OP] likes this.
  12. Jan 29, 2018 at 9:54 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Watch the plastic cowling between the hood and windshield. The wipers are located on it. My 2014 was pushed below the windshield half way across. Saw it 3 weeks after purchase used. Toyota replaced it but would have cost $650. Don't let em f it up.
    Patriot likes this.
  13. Jan 29, 2018 at 10:00 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    How do you know if wipers are not correctly positioned? I had mine replaced and I get a little clunk noise when the wipers return.. cannot figure out why, but haven't spent a ton of time on it as there is no moisture here..
  14. Jan 29, 2018 at 10:15 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    probably won't replace with OEM
  15. Jan 29, 2018 at 10:21 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    pull the wiper arms off.
    Turn on the wipers you should see the posts twist.
    See if the clunk persists. (If so you will need to turn them off and pull the cowl to see if the wiper motors are contacting anything)
    turn off wipers so they return to home.
    turn off truck.
    re attach the wiper arms.
    see if the wipers still make the sound.
    The wipers have a fixed range of motion so if they are attached to the post either too low or too high they will impact the cowl or the a-pillar of the truck respectively.
    hope that helps.
  16. Jan 29, 2018 at 10:29 AM
    Backslider
    Tooele, UT
    I'm almost positive that's going to be it. I checked all the small visible stuff and even replaced the wipers. I really appreciate the info. I'll check tonight and report back!
  17. Jan 29, 2018 at 10:29 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    PGW (brand) is the OEM provider for the Tundra windshield.
    I Doubt the dealer would install "Toyota" branded glass but an aftermarket could be a "PGW" which would be the same as OEM just without the Toyota logo.
    The brand of glass depends on who is doing the install and who their provider is. OEM is always going to be more expensive because Toyota wants their $ too.
    The major brands would be XYG, PGW, and Pilkington. Personally I prefer Pilkington due to their quality standards but any brand can be OEM for a given vehicle just depends on who gets the contract.
    one more thing to look out for is a distortion in the glass. along the edges (band bend in the glass) or in the middle (If there was a scratch at some point someone in the supply chain could buff the scratch out). These distortions can be like looking thru a fishbowl and annoying.
  18. Jan 29, 2018 at 10:33 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Probably depends more on who is paying for the install. Most insurance companies only cover aftermarket glass.
  19. Jan 29, 2018 at 10:35 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    This is true.
    I've seen some insurance policies and customers dictate the use of "OEM" glass but not very often.
  20. Jan 29, 2018 at 10:51 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    you forgot one important piece......
    Don't Mess Up the Blue...... its the best color there is........
    Now you are "did"!!!!!
    4x4_Angel and Rotty23[OP] like this.
  21. Jan 29, 2018 at 11:02 AM
    Rotty23
    Phil
    Upstate SC
    They put in the PGW brand...I watched the total process and the guy did a professional job from what I have seen...told me to let it set for about 30 min then I'm good to go.
  22. Jan 29, 2018 at 11:03 AM
    Rotty23
    Phil
    Upstate SC
    Thank god the Blue is in great shape...lol
    4x4_Angel and Les7311[QUOTED] like this.
  23. Jan 29, 2018 at 11:06 AM
    Rotty23
    Phil
    Upstate SC
    You were right it was heated...glad I know that now...thanks for telling me about this.
    ChucklesToy and mtTundra[QUOTED] like this.
  24. Jan 29, 2018 at 11:44 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    glad it worked out.
    The industry has a bad rap but for every crap tech there are 4 awesome ones.
  25. Jan 29, 2018 at 11:57 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I need a new windshield too. Might just do that after my truck gets all fixed up.
