2018 Rear window whistles at 78 miles and hour or greater
Discussion in '2.5 Gen Tundras (2014-2021)' started by mzaluski, Jan 26, 2018.
  1. Jan 26, 2018 at 9:42 AM
    mzaluski
    mzaluski [OP] New Member
    Michal Zaluski
    2018 Tundra Crewmax
    Step up bars, and Shell on the bed
    Rear window while in the up position whistles whiling driven over 78 miles an hour if I drop a touch the window then noise got away, makes no sense. Truck has 3600 miles on it took it to the dealer today Mark Jacobs of Toyota where I bought my truck. Told them about the issue specifically at what speed it does it at. They called me about it said they could not find anything wrong with window and technician could not duplicate the sound at 70 miles an hour he could not go faster for it is against the law. What a bunch of crap, I would have been happy to stay and drive with the technician if they needed someone to drive it t duplicate the sound. Very unhappy with that lame answer. Any suggestions from here?
  2. Jan 26, 2018 at 9:46 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
  3. Jan 26, 2018 at 9:49 AM
    johng13
    johng13 New Member
    So Cal
    2016 MGM SR5 CM OR 4X4
    SnugTop Cap TRD Sway Bar Husky floor liners
    Same situation with my drivers side front window whistles when driving over 70+ worse if in head wind
    Sound goes away if window rolled down a touch
    Took to dealer they could not duplicate
    Suggested window may be dirty and not sealing when up
    Tried cleaning window and trim
    Still whistles occasionally
  4. Jan 26, 2018 at 10:31 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Silicone spray. I use it mainly on door seals but might help on windows too.
    15whtrd likes this.
  5. Jan 26, 2018 at 10:55 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Trade it for a DC :notsure::D
    15whtrd and Black Wolf like this.
  6. Jan 26, 2018 at 10:57 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Same exact problem with passenger side front window.
  7. Jan 26, 2018 at 11:01 AM
    GoCboys
    GoCboys New Member
    2018 MGM CrewMax
    o_O Because you’re getting close to that flux capacitor speed of 88
    Jk, Dealer “should” take care of that if they want any referrals from you. Law comment is :crapstorm:
  8. Jan 26, 2018 at 11:07 AM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    What a load of crap from Toyota...what if you're driving 70 and into a headwind of 8 mph?
    With my 2005 Tacoma, I had a pretty loud howl from the top of the windshield at higher speeds. Since it was a first-year truck version, Toyota didn't have any TSB's on it, yet, when I brought it in. Since there was a small gap between the top of the windshield and the truck, I filled it with clear silicone and it never did it, again.
  9. Jan 26, 2018 at 11:24 AM
    BamaGuyinTX
    BamaGuyinTX New Member
    2018 Silver Tundra SR5
    Definitely means something isn’t sealing properly. My guess is some sort of flex at that speed due to the vaccume behind the window?
    Regardless, I’d go to a different dealer, speak to the service manager, or call Toyota—and offer to drive it yourself if they won’t go over the posted speed limit. Hell, offer a free case of their favorite if that helps get r done!
  10. Jan 26, 2018 at 11:26 AM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    check the seal after it rolls up and make sure it has not become pinched or rolled over, My 12 had that issues sometimes if the wind was at just the right speed and direction. the seal that lies flat against the window had been rolled / pinched. If it is rolled or pinched its normally a two person job to fix, one to roll up and the other to keep the seal from rolling. Sometimes it takes some heat to help set the seal back to its original shape. Hairdryer should do the trick, shouldn't take as much heat as a heat gun makes.
    Best of luck
    BamaGuyinTX likes this.
  11. Jan 26, 2018 at 11:32 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    you sure it's not the antenna?
  12. Jan 26, 2018 at 12:57 PM
    Sooner77
    Sooner77 New Member
    Todd
    Tulsa, OK
    2017 Cement TRD PRO
    Predator Pro Step Bar, BackFlip MX4, XPEL Paint Protection Film, Husky X-ACT
    I received the same load of crap about techs not driving over the speed limit, so I drove the tech and experienced the whistle on my passenger side front. After several trips to the dealer without a fix, I opened a case with Toyota USA corp. After several discussions with corp and dealer, corp called and said they closed the case because noise could not be replicated at or below speed limit. I lost my mind with that answer, I asked what speed limit and corp replied any speed limit. I took the case up the chain to point we needed lawyers. After a letter was sent from my lawyer, I received the same response. I dropped it, mainly because the truck stop making the wind noise. At first almost any speed over 65 would produce the noise, a crossing head wind it might start at 50+. Nothing would help initially, then not using the recycled air button would help, now I get zero noise at any speed or wind. Not sure if the truck just "loosened" up some or seals finally sealed but luckily its gone.
  13. Jan 26, 2018 at 12:58 PM
    mzaluski
    Michal Zaluski
    2018 Tundra Crewmax
    thanks for all the great advise I will try the silicone after I check the seal stuff, keeping it under 78 is hard on North Carolina highways you will get run over
