Portable 12v winch
Discussion in 'Recovery & Gear' started by Gibzki, Jan 26, 2018.
  1. Jan 26, 2018 at 8:39 AM
    Gibzki
    Gibzki [OP] New Member
    14 White Tundra DC TRD 4X4
    Bakflip Tonneau Cover Fibermax Amp Power Step Moto Metal M0961 Pro Comp Xtreme M2 295/55R20 2 8" Rockford Fosgate Punch Alpine MRP-M500 Mono Power Amplifier LED headlight, foglight, reverse light, license plate light, cargo light, map light, dome light, vanity and footwell Magnaflow 15304 with black tip
    Is there one that you can hook up to the front hooks? I guess this would be cheaper than having to replace the front bumper. Plus you can have the option of using it at the rear or for your other vehicles.
    Marty McFly likes this.
  2. Jan 26, 2018 at 8:43 AM
    This....Made by Warn.....Will accept any standard winch but you will need a front receiver....[​IMG]
    Marty McFly and ColoradoTJ like this.
  3. Jan 26, 2018 at 8:46 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    By the time you add a front receiver to accommodate a front winch mount you may as well purchase the SDHQ hidden winch mount. You wont be disappointed.
  4. Jan 26, 2018 at 9:13 AM
    15whtrd
    15whtrd Mr. Blonde
    True but then you wouldn’t have the luxury of removing the weight as well as being able to use it from the rear.
    Marty McFly, joonbug and Black Wolf like this.
  5. Jan 26, 2018 at 9:40 AM
    Gibzki
  6. Jan 26, 2018 at 12:07 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Hopefully they make a larger one. a 4000lb winch won't pull your Tundra out of anything. Even with the pulley block that is rated for 16,000lbs I don't think this would be strong enough to do much if you got really stuck.
    There may be some here that are much more knowledgeable than me but I know when I was winch shopping for my old jeep I was advised not to get a winch with less than 9000lb capacity.
    14burrito and Black Wolf like this.
  7. Jan 26, 2018 at 12:28 PM
    Yep^^^ 1 1/2 times what you are pulling. 10Klbs and up.
  8. Jan 26, 2018 at 2:13 PM
    Gibzki
    They do come in bigger sizes for industrial use. Ill look for the link later after work.
  9. Jan 26, 2018 at 2:20 PM
    Marty McFly
    Morty McBoonJug
    Cool, if you get one Gibz you can pull me out of the mud ;)
    Black Wolf likes this.
  10. Jan 26, 2018 at 2:21 PM
    blizz86
    blizz86 New Member
    Grab some hi lifts and straps! I hope you've been working out
  11. Jan 26, 2018 at 4:34 PM
    Gibzki
    If you don't pull me out first.
    Marty McFly[QUOTED] likes this.
  12. Jan 26, 2018 at 4:34 PM
    Gibzki
    That, right there is the problem.
  13. Jan 26, 2018 at 4:47 PM
    Gibzki
    I was actually looking at this for different size portable winch
    https://www.amazon.com/Keeper-KW751...3608&sr=8-11&keywords=portable+12v+winch&th=1
    To rephrase my question, is there a portable winch mount that will utilize the oem front tow hooks instead of installing a front receiver. If so, I only need to buy 1 winch for 2 or more cars.
