Scraped a sidewall - replace?
Discussion in 'Wheels & Tires' started by j2007, Jan 22, 2018.
  1. Jan 22, 2018 at 6:40 PM
    j2007
    j2007 [OP] New Member
    VA
    2017 DC Bronze Limited TRD
    Full Debadge, TRD Antisway, Platinum Grille, Baja Designs Squadron Sport Fogs, Morimoto MLED Headlight Retros, Tekonsha P3 Trailer Brake Controller with dash mount, Front Tint, Tyger Tonneau Cover, Anytime Fogs, FRAC, Fortin Evo One Remote Start, 12 Volt Bed Power Socket
    Washing my truck this weekend I discovered two scrapes/gouges in one of my front tires. Anyone with any tire expertise able to weigh in with their thoughts on whether it looks like it needs replaced? It has 6000 miles on it.
    I’ve spent enough money on truck mods lately that I hate to spend more, but I also don’t want a blowout. When it warms up I’ll be towing my camper so that is a consideration too.
    Thanks.
  2. Jan 22, 2018 at 6:50 PM
    TheBeast
    TheBeast The Beach
    I would replace them. They are in a bad spot imo.
    Backslider, 831Tun and Noodle like this.
  3. Jan 22, 2018 at 6:51 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    They're fine, it's only cosmetic, there's no damage to the cords.
    I sold and installed tires for about 4 years, so I have seen my share of damage that is fine and damage that needs replacing, this is not in need of replacement.
  4. Jan 22, 2018 at 6:52 PM
    Noodle
    Noodle That Guy
    Files creek
    2016 Tundra Limited TRD DC Inferno
    Not worth taking a chance, replace that dude.
    Patriot and TheBeast like this.
  5. Jan 22, 2018 at 6:55 PM
    Grumpy Uncle
    Pat
    CO
    The OCD in me says, change it out and keep it as a spare. Also better safe.....
    The important question is, DO YOU TRUST IT?
    Slayer, Les7311 and TheBeast like this.
  6. Jan 22, 2018 at 6:56 PM
    Cuzican
    Cuzican New Member
    Louisiana
    If you had exposed the nylon cords or damaged them, I would agree to replace them, but the outer layer of rubber is cosmetic and protection for the cords.
    Edit: I did type nylon, but meant polyester.
  7. Jan 22, 2018 at 6:58 PM
    TheBeast
    TheBeast The Beach
    what brand tire ? some have warranties and sometimes the store that sells them covers those kind of stuff too.
    sleddogg6 and Grumpy Uncle like this.
  8. Jan 22, 2018 at 6:59 PM
    Grumpy Uncle
    Pat
    CO
    Yep, forgot about that angle, road hazard warrenty
    sleddogg6 and TheBeast[QUOTED] like this.
  9. Jan 22, 2018 at 7:00 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Just looking at it, looks like a Michelin, but the manufacturers warranty won't cover that, he would need to have purchased a road hazard warranty.
    TheBeast[QUOTED] likes this.
  10. Jan 22, 2018 at 7:01 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    If there’s no bubble in the tire, run them. Isn’t gonna hurt anything.
  11. Jan 22, 2018 at 7:01 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Really, I would disagree and that comment makes me wonder about your previous post.
    jberry813 likes this.
  12. Jan 22, 2018 at 7:04 PM
    jberry813
    Lake Tahoe
    1UPPER likes this.
  13. Jan 22, 2018 at 7:05 PM
    Cuzican
    Cuzican New Member
    Louisiana
  14. Jan 22, 2018 at 7:12 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Guess where the chunk is missing and the polyester cords are is exposed, is just a figment of my imagination.
  15. Jan 22, 2018 at 7:17 PM
    Cuzican
    Cuzican New Member
    Louisiana
    https://auto.howstuffworks.com/purpose-tire-sidewall.htm
    "The tire sidewall is just one of several components that make up the standard tire. For example, the bead is a rubber-coated steel cable whose function is to ensure that the tire remains attached to the wheel rim. A tire also has a body that’s comprised of several layers. These different layers are known as plies. Each layer is a different type of fabric. Polyester cord is the most popular ply fabric. Cap piles are extra layers of polyester fabric that some tires contain. Their purpose is to hold everything together. Another important part of the tire is its belt, which is made of steel and is meant to provide reinforcement to the section that’s directly underneath the tread. As for the tread, it’s basically a mixture of various synthetic and natural rubbers. Besides providing lateral stability, the tire sidewall prevents air from escaping and keeps the body plies protected. Some tire sidewalls may contain extra components that serve to increase lateral stability."
  16. Jan 22, 2018 at 7:25 PM
    Cuzican
    Cuzican New Member
    Louisiana
    Now if it truly concerns you, then look and see if you have a full-size matching spare and if so, then have the tires swapped and use this one as your spare.
    j2007[OP] and Grumpy Uncle like this.
  17. Jan 22, 2018 at 7:30 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    I’m TIA trained/certified. If the cords aren’t damaged and you don’t see and sidewall bulges, then it’s fine.
  18. Jan 22, 2018 at 7:31 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Try OfferUp for a replacement.
    I would also believe a bunch of tundrian-guys in Virginia has take offs that you could purchase a great conditioned one
    j2007[OP] likes this.
  19. Jan 22, 2018 at 8:36 PM
    j2007
    VA
    Thanks everyone for all the responses. I appreciate the help. It’s an OEM Michelin LTX A/T2. It makes me nervous mainly because of towing and if it failed affecting my steering. But I’m glad to hear it is probably okay since it’s shallow.
    I like this solution. I do have a full size spare so I’ll just get the tires swapped and keep this one.
    This is also a good idea I hadn’t thought of for getting a replacement.
