Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Jan 20, 2018 at 6:57 PM
    #1051
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    lol...I worked for NSA (No Such Agency) as a Senior Intel Analyst for 23 years...trust me, you're good! (But you do need to stop singing so loud!!) ;-)
  2. Jan 24, 2018 at 3:40 PM
    #1052
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
    Ok so I have my 2018 1794 and so far I have 173 miles in it. I been noticing the transmission when I put into drive, it kinda like feels like a double gear thing happening before going into actual drive. Kinda like a hesitation. This happens when I put into drive and go. If i put it into drive and keep my foot on the brake and give it a couple of seconds, then it shifts into drive with no hesitation. Same thing in reverse. It feels like the tranny is “jumping” into gear. I really hope im explaining it well enough for anyone to understand. Is this normal? Thanks for any input.
  3. Jan 24, 2018 at 4:15 PM
    #1053
    multirc
    multirc New Member
    Ron
    Yes, it does it everytime. I will bring it in and have them take a look. I just dont want to spend a whole day there only for them to tell me that its normal operation. Thanks!
    NewImprovedRon likes this.
  4. Jan 24, 2018 at 4:55 PM
    #1054
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Mine does this. I've always considered it normal and just wait for it. It's been the same before and after the transmission fluid change. I'll bet you get handed the "normal" card.
  5. Jan 24, 2018 at 6:02 PM
    #1055
    multirc
    multirc New Member
    Ron
    Yeah I know thats why im debating to bring it in. Its like a little “thump” with a very slight hesitation feeling when shifting into drive. I was thinking maybe its because its a truck?. When I had my 2007 4Runner, it suffered from the “clunk” when stopped and letting go of the brake, like someone bumped you from behind and also the deadly rotten egg smell. So I dont know if this is a recurring thing with Toyota only this time when shifting into drive or reverse and stepping on the gas.
  6. Jan 24, 2018 at 6:04 PM
    #1056
    multirc
    multirc New Member
    Ron
    By the way...how do you post someones comment into your reply box when replying? I tried copy and paste but looks like it didnt work...LOL!!
  7. Jan 24, 2018 at 7:14 PM
    #1057
    multirc
    multirc New Member
    Ron
    Ahhhhh...I see!!...well thank you very kindly sir!
  8. Jan 24, 2018 at 10:00 PM
    #1058
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It seems to me that when I drop it into gear, if I'm putting a little bit greater pressure on the brake pedal, it doesn't seem like it does it. Maybe it's just the driveline loading up. I drive a mix of diesel powered vehicles at work that do what you describe, in an exaggerated fashion if you're not really on the brakes when putting the Allison automatics in range. Maybe that's why I consider it normal.
    You could still go to the dealer and take another truck out to see if that one responds the same.
    I've always thought that the rotten egg smell meant that the catalytic converter was defective. Some of the Tundras had the bump sensation too, I think that was attributed to a dry slip yoke in the rear propeller shaft. Some the yoke was actually bad and there was a recall of a small number...if memory serves.
  9. Jan 25, 2018 at 5:44 AM
    #1059
    multirc
    multirc New Member
    Ron
  10. Jan 25, 2018 at 5:50 AM
    #1060
    multirc
    multirc New Member
    Ron
    Yeah, trying it out on another truck at the dealer is what I did with my 2017 Ram. Issue was when making a 3 point turn and go to step on the gas while turning, the front differential would hesitate bad...like tires were bouncing...didnt do it with another Ram. Manhattan Service said it was normal. Thats when I said I had it PLUS holding my truck hostage for a week..on two occasions without even touching it so went back to Toyota. And you are correct about the yoke but I followed that up with Toyota and they said the was no recall on my truck. Figures.
  11. Jan 28, 2018 at 2:12 PM
    #1061
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    The check engine light come on, the code p0138, I ordered a Denso Oxygen sensor 234-4260 and put it in. Now I get code p0136. So i put the old sensor back in, now it is giving me the code p0136. Can anyone help me out?
  12. Jan 28, 2018 at 9:15 PM
    #1062
    Nick T
    Nick T New Member
    2007 tundra 3urfe trd supercharger.
    How do you take the rearmost passenger side intake manifold bolt out? There is a wire harness in the way and it is secured by two clips on the back of the supercharger. I cannot figure out how to release these clips to move the harness.
    Any and all help appreciated.
    Thank you
  13. Feb 1, 2018 at 7:45 PM
    #1063
    Buck3tofchick3n
    Buck3tofchick3n New Member
    Iowa
    2018 Tundra Limited
    I seen this a few times replace one O2 sensor then the 2nd one goes bad. i would replace both and call it good.
  14. Feb 1, 2018 at 7:52 PM
    #1064
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Side note: Congrats, Jace! Future Toyota mechanic coming!
    757TUNDRA likes this.
  15. Feb 2, 2018 at 2:01 AM
    #1065
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    Are you saying replace the new sensor i just bought?
  16. Feb 2, 2018 at 7:13 AM
    #1066
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I think he is saying to replace both sides at the same time.
  17. Feb 2, 2018 at 5:02 PM
    #1067
    Buck3tofchick3n
    Iowa
    2018 Tundra Limited
    Correct!
  18. Feb 3, 2018 at 6:45 AM
    #1068
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    07 tundra, Now i have code p2757. What do i need to do to fix it. i have change the transmission fluid.
  19. Feb 6, 2018 at 8:13 AM
    #1069
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    I have a 2016, and want to paint my front sway bar after seeing the new red sport front sway. What are the torque settings for the stock sway?
  20. Feb 6, 2018 at 9:28 AM
    #1070
    Buck3tofchick3n
    Iowa
    2018 Tundra Limited
    4 bolts on frame = 51ft lbs
    Link bolts to stab bar = 111ft lbs
    Link bolts to frame = 89 ft lbs
    Skippy[QUOTED] likes this.
  21. Feb 6, 2018 at 9:58 AM
    #1071
    Buck3tofchick3n
    Iowa
    2018 Tundra Limited
    Beside the code what other symptoms you having? Was the code there before changing the fluid?
  22. Feb 6, 2018 at 10:47 AM
    #1072
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    Congrats!! @LOTSOFTOYS
    I can't wait for my kid to be old enough to help. So handy to use little hands to find lost nuts/washers/10mm sockets
  23. Feb 6, 2018 at 11:36 AM
    #1073
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    The code was there before i change fluids. was hoping it would help. truck drive good, cant tell there's a problem. i can burn a tank or 2 full of fuel before it comes back on. I was pulling a trailer one day to help someone to move, It came on. went from house to house and back to fist house. fired the truck up to second house again and it was off. Started back home it come on before i got home.
  24. Feb 6, 2018 at 11:43 AM
    #1074
    Buck3tofchick3n
    Iowa
    2018 Tundra Limited
    First I have to say I'm not a Toyota mechanic but have resources .There is a TSB ( 5/60k warranty) on this issues which either needs to have the ECM reflashed and or a new transmission.
  25. Feb 6, 2018 at 11:43 AM
    #1075
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    that dont sound good
  26. Feb 6, 2018 at 11:52 AM
    #1076
    Buck3tofchick3n
    Iowa
    2018 Tundra Limited
    No but the new transmission is more for if your having shifting issues .I would talk to the dealer to see what they would charge for the reprogram/flash of the ECM to see if that will fix the issue. Since you don't have shifting issues I would assume you don't need the new transmission or need it yet. It's really a issue with the pressure control solenoid .
  27. Feb 6, 2018 at 12:02 PM
    #1077
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    ok, thanks
  28. Feb 6, 2018 at 12:11 PM
    #1078
    Bergmen
    Bergmen New Member
    Ukiah, California
    On my 2006 Tundra (that I just sold to my daughter) I had a Toyota mechanic friend of mine dig out the relay that controlled the power windows (only providing power when the ignition was in ACC or ON). I jumpered the relay terminals (removing the relay) so the power windows worked all the time, key or not.
    I now have a new 2018 Tundra and would like to do the same. Can someone point out the location of this relay so I can remove it and jump the terminals like I did on my 2006?
    Thanks in advance!
  29. Feb 6, 2018 at 4:47 PM
    #1079
    Buck3tofchick3n
    Iowa
    2018 Tundra Limited
    should be these clips holding it on......
    https://static.summitracing.com/global/images/prod/large/rnb-85656.jpg?rep=False
  30. Feb 22, 2018 at 1:05 PM
    #1080
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Thanks @Sean266! Obviously been really busy haventhis been on here in a while
    T-Rex266[QUOTED][OP] likes this.
