Puddle light won't work with aftermarket remote ...Help
Discussion in 'Audio & Video' started by michaeltam2k, Jan 16, 2018.
  1. Jan 16, 2018 at 10:14 PM
    michaeltam2k
    michaeltam2k [OP] New Member
    michael
    any one have any idea how to fix this . After installing after market remote alarm my puddle outside mirror light not working but my dome light works fine .
  2. Jan 17, 2018 at 8:14 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Do the lights work if you use the factory remotes? I would check and see if a fuse is blown
  3. Jan 17, 2018 at 8:18 AM
    michaeltam2k
    michael
    Yes it does with factory remote
  4. Jan 17, 2018 at 8:40 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Aaaand what exactly is a puddle light?
  5. Jan 17, 2018 at 9:42 AM
    michaeltam2k
    michael
    It's a light that comes on , on the exterior door when you remote unlock your car .
  6. Jan 17, 2018 at 9:54 AM
    TundraTss
    Brandon
    2019 TRD SR5
    You learn something everyday...
  7. Jan 17, 2018 at 7:21 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    What year is your truck?
  8. Jan 17, 2018 at 7:56 PM
    michaeltam2k
    michael
    2014 crewman 1794
  9. Jan 18, 2018 at 4:53 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Ok my thought is its the way the locks are being integrated. Some of the bypass modules control the locks and some do not. Without knowing exactly what you have in the truck and how it is programmed I couldn't be sure. Just guessing here but I think that may be part of it. I would check programming of your bypass module.
  10. Jan 18, 2018 at 9:47 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Hope this is not a common thing? Mine gets remote start installed tomorrow!
    I will let them know ahead of time that I would like all the lights to work with the new remote.
