Interior LED...FML
Discussion in 'Lighting' started by Randy1794, Jan 8, 2018.
  1. Jan 8, 2018 at 6:03 PM
    Randy1794
    Randy1794 [OP] New Member
    Randy
    Wentzville, MO
    2014 Tundra 1794
    So after my LED bulbs supposedly got lost by Amazon, and I requested a refund; they mysteriously showed up this afternoon. I proceeded to install them and everything was going great, till I somehow bent or broke one of the little metal bulbs contactors on my drivers side map light. Then while trying to troubleshoot and fix the the contactor I ended up blowing the fuse (I HOPE) that powers all my interior lights. :censored::frusty::frusty::frusty:. Unfortunately it’s poring down rain tonight, so everything will have to wait till tomorrow. FML
    SouthBoundSteve likes this.
  2. Jan 8, 2018 at 6:17 PM
    Randy1794
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Thanks, will take a look into it tomorrow.
    4x4_Angel and SouthBoundSteve like this.
  3. Jan 8, 2018 at 6:23 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I install my Amazon kit tomorrow...any pointers?
  4. Jan 8, 2018 at 6:23 PM
    FML?
    Fix my lights?
    :D
    Y0TA PR0, TXMiamiFan, JMB and 5 others like this.
  5. Jan 8, 2018 at 6:30 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Theres a thread here a member told a funny ass story about when he messed up installing his bulbs. Someone here will know what im talking about. I cant find it because i suck at searching. I think he also made a thread about how to properly fix the problem.
    NewImprovedRon likes this.
  6. Jan 8, 2018 at 6:32 PM
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    The only bad thing is that you can't find that fuse by itself like in a five pack. At least I couldn't. You have to get an assortment pack. 1st world problems.
  7. Jan 8, 2018 at 6:32 PM
    Randy1794
    Randy
    Wentzville, MO
    2014 Tundra 1794
    I just attempted to install these chipset lights. They are pretty much just a one for one swap with the OEM bulbs. The older bulbs were a little difficult to remove since they set somewhat recessed inside a metal tray, had to use a small pair of needle nose to remove them.
    https://www.amazon.com/gp/product/B01DE7UC6C/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
  8. Jan 8, 2018 at 6:34 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    On you tube people use tape....did you try that?
    Black Wolf likes this.
  9. Jan 8, 2018 at 6:40 PM
    Randy1794
    Randy
    Wentzville, MO
    2014 Tundra 1794
  10. Jan 8, 2018 at 6:46 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    Shit after reading that I’m scared to death....and I’m buying a ton of 7.5 fuses
  11. Jan 8, 2018 at 7:46 PM
    TheBeast
    TheBeast The Beach
    a classic..it all happened to us at some point..
  12. Jan 8, 2018 at 8:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Happened to me
  13. Jan 8, 2018 at 8:46 PM
    Jimbo
    Jimbo New Member
    2017 Tundra Platinum
    Interior Vleds all around
    I just installed all vleds into my interior yesterday and after removing the first map light, the prongs were bent so the light would not stay in. I removed the upper console to fix them and I would recommend this to everyone. Really easy to drop and will make sure nothing gets damaged as seems to be a common occurrence when installing the lights.
    Also this has been my first upgrade on my tundra and I couldn’t be happier!!!
  14. Jan 8, 2018 at 10:38 PM
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    I bought some cheap led lights on Amazon too a few months ago and low and behold the $14 led’s started to fail one after another... bit the bullet and ordered them from vled’s. I didn’t run into any install issues with them thankfully and the new lights came with a 3yr warranty.
    I bought the footwell lighting kit front and rear, will be installing Saturday and will post pics.
  15. Jan 9, 2018 at 12:09 PM
    csuviper
    Broomfield, CO
  16. Jan 9, 2018 at 12:18 PM
    Randy1794
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Thanks to Southboundsteve for directing me to the post with directions on dropping the overhead console. I was able to quickly drop it fix the contacts. Luckily one side was just bend to far out, so a quick fix with small needle nose pliers. All good now, but I will be looking at VLEDs in the future, especially for a floorboard light modification.
    Black Wolf and SouthBoundSteve like this.
  17. Jan 9, 2018 at 12:21 PM
    csuviper
    Broomfield, CO
    I heard floorboard light modification.....
    https://www.tundras.com/threads/diy-footwell-led-install.1769/
  18. Jan 9, 2018 at 3:43 PM
    Ditto^^^^ Gorilla tape worked just fine.
