Heater core bypass
Discussion in '1st Gen Tundras (2000-2006)' started by Bradp, Jan 8, 2018.
  1. Jan 8, 2018 at 10:23 AM
    Bradp
    Bradp [OP] New Member
    Brad
    2001 4x4
    My heater started leaking coolant on the passenger side of my 2001 tundra.i very rarely use heat so was wanting to bypass it .is there any video s or diagams of how to do it?thank you in advance and I did a search but came up empty.
    Y0TA PR0 likes this.
  2. Jan 8, 2018 at 10:28 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome! Let’s picture of your ride!
  3. Jan 8, 2018 at 10:51 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I don't have a guide for you but it's as easy as following the heater core hoses from the firewall, pick one and unhook it, then follow the other hose back to the engine, unhook it from the engine side, route the first hose you unhooked from the firewall back to the engine and hook it up where you disconnected the second hose.
    Take the second hose and loop it back to the firewall where you disconnected the first hose and secure it and you're all done.
    The second part probably isn't necessary but if you decide to replace it later you still have both hoses in the engine compartment.
    mudslinger79 and NewImprovedRon like this.
  4. Jan 8, 2018 at 12:59 PM
    Steve6
    Steve6 New Member
    Tucson
    Good idea to reattach the heater core hoses (or at least secure them). Years ago, I did a temporary bypass on a car and left the heater core hose unsecured. The hose found its way to the headers and caught fire. No real damage to the vehicle but it was a little exciting until I could pull over and put the fire out.
