CAM SHAFT TOWER SEAL LEAKING ** PLEASE READ***
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Jan 5, 2018.
  1. Jan 5, 2018 at 1:51 PM
    jacob.jons.jj
    jacob.jons.jj [OP] New Member
    Jacob
    2014 toyota tundra SR5 5.7 trd4x4
    leveling kit
    Hello everyone!! I have a 2014 Toyota Tundra with 91k miles on it that has no warranty and the cam shaft tower seal was leaking ( VERY VERY COMMON). Its a freaking Toyota 91k miles isnt shi* on them and a dang seal should not be leaking so i called Toyota of America 1-800-331-4331 and complained like hell and Toyota called me back telling me to take my truck to my local dealership to have them diagnose the problem so i did. Toyota then called me back and they fixed my truck for free!!! 3500 dollar fix all i had to pay was 26 bucks for the seal. before you pay to have your truck fixed call Toyota and raise pure hell and tell them look im a dang Toyota lover and this is bull and do NOT GIVE UP on pushing the issue they will fix it!!!
    Sign the petition here
  2. Jan 5, 2018 at 2:00 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Glad it worked out for you!
  3. Jan 5, 2018 at 2:10 PM
    Glad that worked out for you. Hopefully this information helps out other members as well.
  4. Jan 5, 2018 at 2:11 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That's good service!
  5. Jan 5, 2018 at 2:13 PM
    jacob.jons.jj
    Jacob
    leveling kit
    Yes i thank Toyota should recall this problem because it leaks right onto the exhaust. but hopefully people will call and raise hell and get theirs fixed for free as well.
  6. Jan 5, 2018 at 3:00 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Thanks for the info, I got a 2014 with 47,500 miles no cam tower problems yet. Makes me want to get extended warranty just in case I call Toyota and it won’t be as good as it turned out for you. But I’ve read somewhere Toyota covered it on warranty because it became a frequent problem, I gotta find it and try to post it on here......
  7. Jan 5, 2018 at 3:04 PM
    Laz1388
    Laz1388 New Member
    Laz
    South Florida
    2019 1794 MGM
    Windows tinted, Spray-on bed liner, Chrome Delete, Roll-N-Lock retractable cover, Painted fender flares, TRD PRO Suspension, Front and Rear TRD Sway bar, Magnaflow Exhaust, ReadyLift 6" lift, Bronze KMC XD Grenade wheels 20X9-18, Toyo Open Country R/T 37X12.5-20
    Glad to see that Toyota did the right thing, hopefully this is something that they can rectify
    jacob.jons.jj[OP] likes this.
  8. Jan 5, 2018 at 3:06 PM
    Darth Tundra
    Curt
    17 CM TRD Black
  9. Jan 5, 2018 at 3:19 PM
    SCORE!!!!!!!!
  10. Jan 5, 2018 at 5:54 PM
    jacob.jons.jj
    Jacob
    leveling kit
    when does your factory warranty run out? the cam towers are known to start leaking around 60-70 thousand miles if there not leaking by that time then sounds like your good to go. im not sure what an extended warranty would cost you but to fix the cam towers is $3,500
    Samoan Thor[QUOTED] likes this.
  11. Jan 5, 2018 at 5:59 PM
    Factory is 3/36 and 5/60 powertrain
    woodcan and Samoan Thor like this.
  12. Jan 5, 2018 at 6:00 PM
    Samoan Thor
    Yup, facts!
  13. Jan 5, 2018 at 6:07 PM
    jacob.jons.jj
    Jacob
    leveling kit
    i would be looking really close around the 60k mark before buying an extended warranty. A LOT of extended warranty's do not cover oil leaks i would ask that very specific question before buying it. i was going to buy an extended warranty but everyone that i seen did not cover oil leaks and thats what i wanted fixed.
    Samoan Thor likes this.
  14. Jan 5, 2018 at 6:10 PM
    Samoan Thor
    Yea I researched hard on it, I cringe every time someone says “it’s a Toyota it’ll never have problems” but I wanted an extended warranty for a piece of mind when something does happen, but then again nothing might happen and by that time when it does I can whip out the dusty old credit card to get some credit points instead of buying the warranty.....
  15. Jan 5, 2018 at 6:14 PM
    jacob.jons.jj
    Jacob
    leveling kit
    ohh ya its a Toyota thats why i didnt buy the extended warranty i know for a FACT toyota's extended warranty does not cover oil leaks. knock on wood i have 3 toyota with over 250k miles and the only things i have done is batteries. i have a 99 4runner with the 3.4 with 322,574 miles on it and the ONLY thing that has ever been changed on it is batteries and i did have the timing belt replaced at 200k
    Toypower, woodcan, Black Wolf and 2 others like this.
  16. Jan 5, 2018 at 7:16 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No one is going to mention that there isn't actually a seal there? They owe you $26.
  17. Jan 5, 2018 at 7:18 PM
    jacob.jons.jj
    Jacob
    leveling kit
    ya know shit!!! its just RTV or something similar.
  18. Jan 5, 2018 at 7:19 PM
    Yep, best to save $$$ for a rainy day "if" something should happen.
  19. Jan 5, 2018 at 7:24 PM
    $26 bought pizza....
  20. Jan 5, 2018 at 7:24 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Exactly, and you shouldn't have had to pay for it.
    Black Wolf likes this.
  21. Jan 5, 2018 at 7:26 PM
    jacob.jons.jj
    Jacob
    leveling kit
    i want my dang $26 back or give me some of the dang Pizza toyota!!!
  22. Jan 5, 2018 at 7:27 PM
  23. Jan 5, 2018 at 7:40 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    FWIW, the parts listed in my Cam Tower Leak repair were:
    Oil Filter
    Engine Oil
    Oil Pan Drain Plug Gasket
    FIPG (Formed In Place Gasket) Oil Pan
    Camshaft Bearing Gasket
    Super Long Life Coolant
    Kinda seems like it could be incomplete, no rational reason why though.:notsure:
    jacob.jons.jj[OP] and Black Wolf like this.
  24. Jan 5, 2018 at 8:11 PM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    Where do I look to keep an eye out for this leak?
  25. Jan 6, 2018 at 3:56 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Look down onto the valve covers and you'll see oil weeping out the the area if they are leaking. You can also look thru the wheel well. I noticed mine on my 2012 when I smelled it getting out of the truck.
    Jmklly67 and Sas like this.
  26. Jan 6, 2018 at 9:45 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Good to know. Thanks!
  27. Jan 7, 2018 at 5:35 AM
    Jrfor0
    Jrfor0 New Member
    James
    I'm glad I saw this thread and starting doing additional research on this problem. I looked at my truck two nights ago and my driver's side tower seal on my 2015 5.7L is starting to leak. At this point it is very minor, only a little line of oil about 1 inch long along the seal. So I went to the dealership first thing yesterday morning and their lead mechanic visually confirmed it is leaking. Going back in about 1.5 weeks to get both sides replaced and will be covered under warranty as I only have 57,200 miles on the truck.
    gavia, jshannon613, Toypower and 4 others like this.
  28. Jan 7, 2018 at 5:45 AM
    Petroleum 1
    Petroleum 1 New Member
    Colorado / Arizona
    Does this problem exist thru all the model years up to current?? I have a ‘17
    Tia
  29. Jan 7, 2018 at 6:19 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    Yupp, had it done on mine about a month ago, yes mine is a 17.
  30. Jan 7, 2018 at 6:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    No one really seems to know for sure. 2015 is the latest that I've read about. We just have to wait and see as we hear from owners that report on what they're finding as they check their trucks.
    Edit: Okay, @TRD423 excepted. Posting at the same time, lol.
    Lowrange likes this.
