Toytec 3/1 Install Finished
Discussion in 'Suspension' started by twhittle14, Jan 4, 2018.
  1. Jan 4, 2018 at 9:56 AM
    twhittle14
    twhittle14 [OP] New Member
    Thomas
    2015 CM Limited 4x4
    I finally got my Toytec 3/1 kit installed and love it so far. The parts I installed are:
    Toytec 3" spacers on the front coils
    Toytec differential drop spacers
    Toytec shackles on the highest setting in the rear
    Bilstein 5100's in the rear
    Before the lift, from the ground to the center of my front fender was 37" and 39.5" for the rear fender. After the lift, the front fender is at 40" and the rear fender is at 42", so the total lift I gained was 3" in the front and 2.5" in the rear. I chose to put the shackles on the highest setting so that the rear sits a little higher than the front. I didn't expect to gain 2.5" from it but I still like the look.
    The only problem I ran into during the install was compressing the coils enough to add the spacers. For anyone who is thinking about installing this lift, note that the spacers sit between the coil and the top plate of the strut. They don't bolt onto the top of the strut like I originally thought, so make sure you have a way to compress the coils. I tried to compress the coils myself but ended up having to take it to a shop that had a hydraulic press.
    Before (stock):
    Front spacers installed, stock rear:
    Front and rear installed:
  2. Jan 4, 2018 at 10:03 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Looking good!
    twhittle14[OP] likes this.
  3. Jan 4, 2018 at 10:19 AM
    NICE!!!
  4. Jan 4, 2018 at 10:26 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sa-weeet!
  5. Jan 4, 2018 at 11:18 AM
    Did you go with the in-coil spacers or?
  6. Jan 4, 2018 at 11:26 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Very nice!
    Looks good!
    twhittle14[OP] and T-Rex266 like this.
  7. Jan 4, 2018 at 11:31 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Clean, brother.
  8. Jan 4, 2018 at 11:37 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Im digging that, looks tight.
  9. Jan 4, 2018 at 11:57 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Looks great Thomas!
    Here's a close up picture of my Toytec spacer (TU-3 kit) so that other's might see what you're speaking of. I went with black as I wanted the spacers to hide better ... the kit itself works fine if one is looking to get the leveled look, but not sure how well it would hold up to some serious 4x4ing.
    my installer didn't have any experience with this kit either and at first installed the rubber pad on top of the spacer. He made it correct the next day.
    how my Tundra looks from the side ...
  10. Jan 4, 2018 at 12:18 PM
    TheBeast
    TheBeast The Beach
    any height difference driver and passenger ? aka tundra lean
  11. Jan 5, 2018 at 1:27 PM
    twhittle14
    Thomas
    2015 CM Limited 4x4
    Thanks for the hookup and fast shipping David!
    TXMiamiFan likes this.
  12. Jan 5, 2018 at 1:29 PM
    twhittle14
    Thomas
    2015 CM Limited 4x4
    Looks good! I would have opted for the black spacers too but didn't know they were an option. That's a good close up pic of the spacers, it took me a few minutes to figure out the order everything went in.
  13. Jan 5, 2018 at 1:59 PM
    Toytec Lifts
    Denver, CO.
    Anytime buddy.
    T-Rex266 likes this.
  14. Jan 7, 2018 at 8:18 AM
    twhittle14
    Thomas
    2015 CM Limited 4x4
    Both sides sit pretty level right now. The spacers stiffen the coils which should actually help prevent one side from being lower than the other.
  15. May 31, 2020 at 8:49 AM
    TundraSteve143
    TundraSteve143 New Member
    Dripping Springs, Texas
    2018 1794 4X4 Black
    Fuel Wheels, Back Flip bed cover, Line X bed liner, Access Bed Mat, Precision LED's
    This is the set up from Toytec that I would like to go with. Have you had any issues with the TSS?
  16. Jun 3, 2020 at 12:26 PM
    I would go with coilovers. Much better ride. I had spacers before and it rode rough as hell.
  17. Oct 31, 2020 at 11:09 AM
    AlbertaGhost
    AlbertaGhost New Member
    Have date set to install the TU307 leveling kit. Reading threads, most say that I would see a 3" lift on front. Person at service desk said it would only see 3/4" difference. Any do this on a 2020 Tundra yet. Also I have Falken 275/65 R20 tires on order to put on after. Want would people recommend for tires, want to make sure they don't rub. Will be going to 305's after and adding fender flares but doing it in stages to spread the cost out.
    Owned lots of truck but this is the first one I am doing anything with. Just need some advice.
  18. Nov 5, 2020 at 2:40 PM
    Merkopac661
    Merkopac661 New Member
    White 2018 Tundra Sport 4x4
    Tundras look so much better once lifted more than stock. Its gonna be sweet with those new meats.
  19. Nov 10, 2020 at 7:23 PM
    Dg191
    Dg191 New Member
    2007 2 who drive limited tundra
    None
    I have a 2007 2 wheeler, I love what you did, May I ask what it costs?
  20. Nov 18, 2020 at 10:26 PM
    boat49
    boat49 New Member
    2013 Magnetic Grey Tundra
    Love the look of all of these. I just bought a 2013 and have been thinking about a leveling kit. Not knowing that much about them yet, after adding a kit how does it affect the ride when towing? I don't want the rear end to sag to where I'm going down the road with the front end higher. All comments and suggestions appreciated.
  21. Nov 19, 2020 at 2:36 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Congrats, looks good... How is the ride after TT leveling kit installed?
    Better or worse than stock?
    UCA addressed or stock?
    Alignment issues?
    What's the wheels /tiresyou going with next?
    Tundy looks better than stock. Well done!
  22. Nov 19, 2020 at 3:45 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    With load range e tires you would have to go with some mega $$ coilovers for it not to ride rough as hell. Spacers are fine for someone who just wants 2 level. Just put some spacers on my wifes '20 Tacoma, i for sure would have heard loud and clear if it rode ruff as hell now. It is the perfect way 2 level a mall crawler.
    toyofan87 likes this.
  23. Nov 20, 2020 at 5:15 AM
    toyofan87
    Seth
    Gettysburg, Penna
    Congrats again, as for the ride? Like @Tundra's234 says that the leveling kits ride rough, than Coilovers.... Please set the stage for other members of the fence about what kit to procure? Thx
