Custom Box for 10" single full size sub Gen2
Discussion in 'Audio & Video' started by Dougthebeast, Oct 15, 2017.
  1. Oct 15, 2017 at 3:16 AM
    Dougthebeast
    Dougthebeast [OP] GTF out of my way!
    Doug
    Newnan GA
    2008 Tundra TRD DC Sapphire Blue
    I have a Alpine Type R 10" sub that I love and have had for about 10 years. I am determined to get in my DC. I am thinking about building a custom sealed enclosure for it that fits behind the center console, about as wide as the console, that extends below the seat to get the .65 cubic feet of volume that Alpine recommends. So, does anyone have opinions on a side, down, forward direction for the sub? I think side firing is going to be the easiest to accommodate this big sub. Does shape of the box have an effect on sound? Has anyone attempted this?
    Next, I've even thought about building it into the center console itself, by pointing it out he back. This is risky due to the possibility of a screw up.... Has anyone tried this???
    MegaTronda and GNTundra like this.
  2. Oct 15, 2017 at 3:30 AM
    Dougthebeast
    Doug
    Newnan GA
    I looked at that and done a bit of research. I like it the option and am keeping that as a fall back. Don't really want shallow subs but will go there if all else fails. Best 10" shallow sub is????????
  3. Oct 15, 2017 at 3:35 AM
    Dougthebeast
    Doug
    Newnan GA
    nope, this one
  4. Oct 15, 2017 at 3:45 AM
    Dougthebeast
    Doug
    Newnan GA
    Got a link?
    GNTundra likes this.
  5. Oct 15, 2017 at 3:53 AM
    Dougthebeast
    Doug
    Newnan GA
    It's too small. LOL. The mounting depth won't work. Big Sub. This is going to be a crazy looking box . Will definitely keep this post going with my progress. I see template after template coming.
  6. Oct 15, 2017 at 3:56 AM
    Dougthebeast
    Doug
    Newnan GA
    I've got a serious woodshop in my basement. I got this!
  7. Oct 16, 2017 at 9:17 AM
    Dougthebeast
    Doug
    Newnan GA
    Got a basic design. Going to mock up and take careful notes, template and pictures next weekend. Maybe I can produce for others. This is a tight fit, I can tell you that. Down fires...
  8. Oct 16, 2017 at 9:31 AM
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    I have 2 of the Alpine Type R 10's.. I went ahead and grabbed some shallow 8's for my build. No way would the 10's fit. Good luck.
    GNTundra and Dougthebeast[OP] like this.
  9. Oct 16, 2017 at 9:38 AM
    Dougthebeast
    Doug
    Newnan GA
    Placing between the console and rear seat. Will only fit a single. Damn, it's a tight fit though
    JackWagon likes this.
  10. Oct 16, 2017 at 1:29 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Build a whole new center console...
  11. Oct 16, 2017 at 1:39 PM
    Dougthebeast
    Doug
    Newnan GA
    Thought about mounting in/integrating it into the console.... Might revisit that idea too because it's so large. Cutting it it's a scary idea though
  12. Oct 20, 2017 at 5:48 PM
    Dougthebeast
    Doug
    Newnan GA
    Mock up for DC sub box complete....
    GNTundra and JackWagon like this.
  13. Oct 20, 2017 at 6:04 PM
    JackWagon
    Will it fire up or down?
  14. Oct 20, 2017 at 6:05 PM
    Dougthebeast
    Doug
    Newnan GA
    Down fires.... Only way the sub fits. You can go higher, but lose rear cup holders. Volume estimated at .7 cu ft
  15. Oct 20, 2017 at 6:07 PM
    Dougthebeast
    Doug
    Newnan GA
    More pics tomorrow. Cutting out the real thing now. This is a big sub. Should be able to fit most out there
  16. Oct 21, 2017 at 7:27 AM
    speckmon
    Thornton, CO
    Looks good dude
    Dougthebeast[OP] likes this.
  17. Oct 21, 2017 at 2:26 PM
    Dougthebeast
    Doug
    Newnan GA
    Going as planned.... Fits tight, but good to go
  18. Oct 21, 2017 at 2:32 PM
    JackWagon
    Got enough air space?
  19. Oct 21, 2017 at 2:33 PM
    Dougthebeast
    Doug
    Newnan GA
    Specs range from .5-.8 cu ft. Ideal is .65 cu ft. I'm estimating about.63
  20. Oct 21, 2017 at 2:37 PM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    Awesome build.
  21. Oct 21, 2017 at 5:06 PM
    Dougthebeast
    Doug
    Newnan GA
    Placement... Rear cup holder flips open just fine...
  22. Oct 30, 2017 at 6:45 PM
    Dougthebeast
    Doug
    Newnan GA
    Fits like a glove and sounds fantastic....
  23. Oct 31, 2017 at 4:23 AM
    MikeyMTBs
    MikeyMTBs New Member
    Wow... great work.
  24. Oct 31, 2017 at 4:58 AM
    Dougthebeast
    Doug
    Newnan GA
    If anyone is interested, let me know. I have templates to duplicate. The only variable is the piece that extends under the seat. It can be adjusted depending on the specs of the sub you'd want to use
  25. Oct 31, 2017 at 5:32 AM
    JackWagon
    Nicely done.
  26. Dec 30, 2017 at 12:35 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I’m thinking oddments some think similar in a CrewMax
