missing oil
Discussion in '1st Gen Tundras (2000-2006)' started by txmax, Dec 27, 2017.
  1. Dec 27, 2017 at 1:45 PM
    txmax
    txmax [OP] New Member
    '06 Tundra SR5 crew cab
    Last week I bought an '06 Tundra with 41k miles on it. I've driven 500 miles. checked the oil and it was 2 quarts low. no leaks that I can see. no smoke. no oil on the ground it was full when I got it. where did it go?
  2. Dec 27, 2017 at 1:54 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    You have any burning smells going on?
  3. Dec 27, 2017 at 1:56 PM
    txmax
    nope, no smells
  4. Dec 27, 2017 at 1:58 PM
    TundraTss
    Brandon
    2019 TRD SR5
    Not to insult your intelligence, but did you maybe misread the dip stick? Like, in the dark or something..?
  5. Dec 27, 2017 at 2:04 PM
    TundraTss
    Brandon
    2019 TRD SR5
    I had a similar problem with my wife’s subie. Having to add frequently with no sign of leaks etc.
    In her case, it turned out that she had a blown seal, and it was in fact leaking oil, but in a spraying manor, only when the engine was running, and hot, and the oil was just being sprayed all over her engine compartment, not making it down to the ground or pooling anywhere. Not even smelling really, just slathering a layer of oil all over everything.
    I hope that’s not your issue, but for us, that solved the case of the missing oil.
    TXMiamiFan likes this.
