Retro's or '18 Headlights
Discussion in 'Lighting' started by renlo, Dec 25, 2017.
  1. Dec 25, 2017 at 8:07 PM
    renlo
    renlo [OP] New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    Which ones? Cost would be similar seeing as with the 18s I would get the fogs too. Lights would go on a 16 Platinum.
    I would also get the pro grill to go with either.
  2. Dec 25, 2017 at 8:09 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    retros will have better output, 18's will give you that oem look.
    someone made a nice chart of the comparison
    my vote is for retros
    Pudge and renlo[OP] like this.
  3. Dec 25, 2017 at 8:12 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The 18s don't seem to have nearly the output as a good retrofit. But they do look pretty nice. If I had the spare cash I'd go with an LED retrofit from @eledobleu
    They are plug and play and put out more light than the 18s, newer technology than HID retros.
    renlo[OP] likes this.
  4. Dec 25, 2017 at 8:14 PM
    Pudge
    CT
    As far as fogs go, Idk about the 18s light output but I have seen a few guys here with @Baja Designs fogs and they are bad ass. I'd assume way way way better than the 18s.
  5. Dec 26, 2017 at 11:37 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    If it were me I’d go with the retro’s, my .02
  6. Dec 26, 2017 at 12:27 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  7. Dec 26, 2017 at 1:34 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Go with the 2018 LED's they are nice. Forgive the wheels and tires, back to stock for the winter months, got to preserve the good ones from the salt.
