How much weight in bed for traction in winter?
Discussion in 'General Tundra Discussion' started by Outbound, Dec 21, 2017.
  1. Dec 21, 2017 at 10:12 AM
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    Im making a drive through the mountains tomorrow and plan on putting some weight in my bed for added traction. On other half tons i've done 3 - 400lbs. Should i stick with that for my 05 double cab?
    Y0TA PR0 likes this.
  2. Dec 21, 2017 at 10:16 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    I think there was another thread on this a few weeks ago.
    Personally, I don’t use any with the 4wd on the tundra and I’ve never had a problem, and I live in Colorado. With my 2wd silverado I used 4 60# sand tubes.
    15whtrd likes this.
  3. Dec 21, 2017 at 10:23 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  4. Dec 21, 2017 at 10:34 AM
    SMILE
    SMILE Drink, Smoke, and Smile!
    SOUTHEAST PA
    2016 TUNDRA CREWMAX SR5 5.7L V8
    Weather tech mats, to be continued.........
    I asked this a week or two ago. Overwhelming response was no weight if you have 4 wheel drive. Have driven in some snow since then with no weight in the bed and did fine, however not in the mountains. Just please tie down anything you put in there, as it will become a projectile if you have an accident.
  5. Dec 21, 2017 at 11:15 AM
    Outbound
    Aaron
    Northern Alberta
    Totally missed that thread. Thanks guys. I dont want run in 4wd the whole way on my trip(1200+kms). I dont think thats good for the truck. Or does it really make a difference?
  6. Dec 30, 2017 at 6:36 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I have 4 60lbs bags of sand. Probably should have them tied down. Noticed some improvement interaction on snow. Next year I plan on having a canopy and new tires. LTX tries have surprisingly good traction in wet and dry snow. Pisses me off to since I have no excuse to tell my wife we need new tires:cool:
  7. Dec 30, 2017 at 6:49 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Where you headed? Just use 4wd when you need to, you’ll be fine. How’s your tires?
    Let’s say If the road was covered in snow for 1200+Kim’s and you had it in 4wd all the way, won’t hurt it.
    Depending on how roads are just use it as needed.
    Outbound[QUOTED][OP] likes this.
  8. Dec 30, 2017 at 8:47 PM
    Outbound
    Aaron
    Northern Alberta
    I drove from Grande Prairie to Vancouver. Just got back last night. There were some pretty nasty sections from GP to Grande Cache on the way down and then most of the way home. I swapped in an out of 4wd as needed, but left it in 4wd probably 90% of the time coming home.
    I ended up going with around 400lbs of weight in the bed, loaded as far forward as possible to squat the truck evenly. I found it actually made a difference, even when in 4wd. I felt more secure and "glued" to the road if that makes any sense.
    MotoTundra and Y0TA PR0 like this.
  9. Dec 31, 2017 at 5:21 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    It’s not necessary with 4x4 and decent tires, but as you stated....it makes a difference
  10. Dec 31, 2017 at 5:30 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm glad it worked out for you. What did you use for weight?
  11. Dec 31, 2017 at 9:37 AM
    Outbound
    Aaron
    Northern Alberta
    I grabbed 3 scrap 3ft long sections of 15x40 channel iron from work and welded them together. 40lbs per foot times roughly 9 ft. The way I welded them (2 side by side with the 3rd centered on top) allowed me to run a ratchet strap through them. That combined with the rubber bed mat I have meant they didn't budge at all.
  12. Dec 31, 2017 at 10:43 AM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    How’s the weather up there in GP?
