Is it a big deal?!
Discussion in 'Wheels & Tires' started by Samoan Thor, Dec 21, 2017.
  1. Dec 21, 2017 at 9:54 AM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Hub centric wheels and those that are not, Is it that big of a deal or is it like wheel offset and wheel spacers debate where both have advantages and disadvantages over time, is it the same deal with hub centric wheels and those wheels that are not? Just want a straight answer since many people are running both type of wheels, thanks
    TXRailRoadBandit73 likes this.
  2. Dec 21, 2017 at 10:23 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    All the advantages of hub centric wheels are for consumers. All the advantages of lug-centric wheels are for the manufacturers.
  3. Dec 21, 2017 at 10:23 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Hub centric wheels transfer the weight of the vehicle to the hub. With the center bore matching the hub diameter there's no room for the wheel to move up/down/side/side on the hub meaning it will stay properly centered even if a lug nut or two become loose.
    With a lug centric wheel the wheel is centered on the lugs. This means all of the weight of your Tundra is also on the lugs, there is no point of contact to the hub to transfer any of the weight. Without having the center bore of the wheel matching the hub there is room around the hub for the wheel to move up/down/side/side and become off center and unbalanced.
    If you opt for a "lug centric" wheel the best course of action is to add a set of hub centering rings to close that gap so the wheel has no movement and to help transfer some of the weight to the hub rather than solely relying on the lugs.
    Sas, RangerBP, TheBeast and 6 others like this.
  4. Dec 21, 2017 at 10:41 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    WELL SAID !!!
  5. Dec 21, 2017 at 10:45 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Wow, best explanation I've seen to date!
    TheBeast and eccracer104[QUOTED] like this.
  6. Dec 21, 2017 at 10:56 AM
    Samoan Thor
    Thank you sir! Good wealth of knowledge, that’s why I love this page. There’s no good explanation using the search function here but you had it, thanks again!
  7. Dec 21, 2017 at 11:05 AM
    eccracer104
    San Diego, CA
    Thanks guys!
    I'm actually the wheel, tire and suspension specialist at my work. Learned nearly everything through the forums and my own errors aka life experience haha. I'm here to help :thumbsup:
    TheBeast and Samoan Thor[OP] like this.
  8. Dec 21, 2017 at 11:20 AM
    757TUNDRA
    Illinois
    Thanks @eccracer104, you've been a great addition to the forum.
  9. Dec 21, 2017 at 11:34 AM
    eccracer104
    San Diego, CA
    :hattip:
    I'll be learning from you guys as well. I'm familiar with the Tundras, but don't yet know some of the cool little details you learn over time.
    buckeyes1975 likes this.
  10. Dec 21, 2017 at 11:36 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    eccracer104 likes this.
