Lift/Tire setup?
Discussion in 'Wheels & Tires' started by hollandhunter, Dec 19, 2017.
  1. Dec 19, 2017 at 7:50 AM
    hollandhunter
    hollandhunter [OP] New Member
    2017 SR5 CM 4x4
    Im fixing to order a 3/2 lift kit for my 17 cm. An was wanting to run a 20x10 with -24offset wheel and a 305 55 20 tire. How bad am i going to rub. Dont mind doing a bmc chop but wanna keep my stock bumper. Anyone running this setup and have pics?
  2. Dec 19, 2017 at 8:08 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    you will defiantly need to do the BMC. regarding the front, you will most likely have to remove the front flap and move your liner forward. You can also shim you bumper out if needed. Just add some washers on the bumper mount. You should be able to fit them with the above mods.
    eccracer104 and SouthBoundSteve like this.
