Colorado Blue build - 2019 TRD Pro headlight swap
Discussion in '2.5 Gen Builds (2014-2021)' started by thetwood, Dec 13, 2017.
  1. Dec 13, 2017 at 3:29 PM
    thetwood
    thetwood [OP] New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    I've been semi-active on the boards here since getting my 2017 Tundra Crewmax Limited TRD in Blazing Blue. Mostly, I've been doing research and following others builds. My plan has been to focus initially on the mechanical side, leaving visual (color matching, etc.) till later.
    I finally made some decisions and started purchasing. The building has begun. Thought I'd document some of my changes.
    Started with this. Stock other than Spidertrax wheel spacers.IMG_2672[1].jpg
    Here's where I'm at now:
    Projects to date:
    • Front window tint
    • Toyota tri-fold bed cover (removed - hail damage)
    • Clear bra
    • Spidertrax 1 1/4" wheel spacers (removed)
    • Pop-lock tailgate lock
    • Rear seat consul USB mod
    • Front and Rear King OEM shocks with remote reservoirs
    • SPC Performance UCAs
    • Toytec Shackles
    • Icon Six Speed 17x8.5 wheels - Gunmetal
    • Falken Wildpeak at3w - 35x12.5 r17
    • Removed front mud flaps
    • Pushed front wheel well liner forward
    • Hypertech In-Line Speedometer Calibrator Module
    • RCI Engine Skid - Steel
    • Removed spare tire guides
    • Undercover Swing Case - Passenger side
    • P&P Type 4 Sliders
    • Shovel/Ax mounting system in bed
    • MattGecko cool while bed lights - modified with magnetic reed switch
    • In bed Fly rod holders - ABS pipe and fabbed supports
    • BAK Revolver X4 roll-up bed cover
    • P&P Engineering shock skids
    • ESP Long Box Under Seat storage
    • RCI Transmission/Transfer Case Skid Plate - Steel
    • Victory 4x4 Rear Diff Skid
    • Hi-Lift jack and X-Bull Recovery tracks mounted in bed
    • Color matched door handles and mirror caps
    • Expedition One Storm Trooper front bumper - color matched
    • Warn VR-12S winch
    • Factor 55 fairlead and Flatlink
    • PIAA RF6 6" yellow fog lights - in Expo One bumper
    • Baja Designs Squadron Pro Led lights - in Expo One bumper
    • Flipster V2 Winch License Plate Mount
    • FRAC harness with Natika camera and AOB switch
    • Victory 4x4 LCA skid
    • Fabbed ABS cover for winch access holes
    • ARB Diff Breather kit - rear
    • 2019 TRD Pro headlight swap using iHacker harness
    Stroke250, ColoradoTJ, PMG and 8 others like this.
  2. Dec 13, 2017 at 3:31 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Sweet! Looking BA!
  3. Dec 13, 2017 at 3:39 PM
    thetwood
    Louisville, CO
    Some pictures from King install. One of my buddies came over for an afternoon and we installed ourselves. Should have taken more pictures, but it started to get dark and cold and was taking longer than we anticipated. Overall, the install went great and I'm super happy with it.
    Started with the rear, installing King 2.5 remote reservoir and Toytec shakles, installed at the second hole.IMG_2786[1].jpg IMG_2789[1].jpg
    Then moved on to the front. King OEM 2.5 with remote reservoir. Changed out the UCA's to SPC at the same time. Had looked at the Total Chaos and Camburg UCA's, but advice was to go with the SPC's from multiple sources. Passenger side went on relatively smoothly. Was expecting the driver to be better since we knew what we were doing. Instead, we ended up spending twice as long trying to get everything to fit and in place. Not sure what we were doing wrong, but it sure was wrong. But took a break and figured it all out.IMG_2804[1].jpgIMG_2794[1].jpg
    Front lift was a bit under 3 inches. Rear a bit over 1. Was left with a rake of about 1 inch.
  4. Dec 13, 2017 at 3:48 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Looking great!!!!!
  5. Dec 13, 2017 at 3:51 PM
    Looks great!:thumbsup:
  6. Dec 13, 2017 at 3:54 PM
    Awesome Sauce!
  7. Dec 14, 2017 at 5:58 AM
    thetwood
    Louisville, CO
    Thanks guys. Have a few more projects in the works, just waiting on parts or warm weather (or time off work).
    A few additional notes from what I've done so far. First, I purchased my Kings and SPC UCA's from Filthy Motorsports here in Boulder, CO. Great, honest advice, personal service, they have the shocks tuned to your needs and shipped directly to you and still the lowest prices I could find. Very happy with how that has all turned out so far.
    The front King shocks didn't come with any instructions. I called King 15 minutes before they closed on a Friday and was immediately put in touch with someone with what I needed, who had them emailed to me within 5 minutes. Again, great customer service. That said, I'm not sure why King doesn't just have their instruction sheets available on their website. Would have been easier and I would have liked to look at them before my shocks arrived.
    Up next: front skid plate
    ColoradoTJ, Y0TA PR0 and TXMiamiFan like this.
  8. Dec 14, 2017 at 8:08 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Looking good bud!
    Blue rocks :headbang:
    thetwood[OP] likes this.
  9. Dec 14, 2017 at 8:51 AM
    thetwood
    Louisville, CO
    Blue does rock. Like what you've been doing to your Azul, especially the headlights. Very nice.
    Y0TA PR0[QUOTED] likes this.
  10. Dec 14, 2017 at 9:09 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    This looks awesome, I've been contemplating multiple setups... now I need to go look at King's closer.
    zcarpenter92 and Y0TA PR0 like this.
  11. Dec 14, 2017 at 9:11 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
  12. Dec 14, 2017 at 9:59 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Lovin the build so far Matt.
  13. Dec 14, 2017 at 10:59 AM
    Sweet looking Tundra!
    I recommend Filthy Motorsports as well Matt. I purchased one set of Kings from them as well.
  14. Dec 14, 2017 at 6:36 PM
    thetwood
    Louisville, CO
    Set-up and installed a Hypertech In-Line Speedometer Calibrator tonight to account for the larger tires. Install went fine, though taking the entire dash apart one piece at a time is a bit nerve wracking the first time. Was dark early, so ended up using a head-lamp to tell what I was doing, which added an extra bit of excitement to the affair. Lost one screw, but luckily had a fit in the extras bin so everything went back together just fine. Seems fine in slow driving around the neighborhood. Will test out fully tomorrow at higher speeds to see if I set everything up correctly.
    Y0TA PR0 likes this.
  15. Dec 16, 2017 at 4:26 PM
    thetwood
    Louisville, CO
    Since I had to remove the skid plate to install my lift, decided to upgrade. Installed a RCI front skid. Steel, powder coated black. Install was straightforward and didn't take too long, even doing it without help. Quite the upgrade over the stock TRD. Planning on slowly expanding backwards with RCI skids as the budget allows.
  16. Dec 17, 2017 at 2:53 PM
    thetwood
    Louisville, CO
    Need the truck bed free to carry all of my son's hockey goalie gear, so need to store the 35" spare under the bed. My spare is the same wheel/tire that I'm running normally, so knew it wouldn't fit without some work. After reading a bunch of posts here, decided to remove the spare wheel guides under the truck. Drilled out the bolts holding it in, using a progression of larger drill bits. Once it was close, used a hammer and chisel to knock them off. A bit of black paint and was able to get the spare under with enough room to be okay. Had to push it a bit forward to be where I want it. It's tight, but fits.
    It's stayed where I want so far, but I'm a bit worried that it'll move after a while. May look at adding something to keep it in place better.
    aperezsh likes this.
  17. Dec 17, 2017 at 2:59 PM
    thetwood
    Louisville, CO
    I believe it was one of your recommendations that got me looking at them in the first place. Ben at Filthy Motorsports was super helpful. Honest advice, didn't try to sell anything I didn't need and spent a lot of time on the phone making sure it was perfect.
  18. Dec 17, 2017 at 3:40 PM
    Awesome.
    Ben is good peeps.
  19. Dec 17, 2017 at 7:08 PM
  20. Dec 17, 2017 at 7:49 PM
    Lmao. That Ben and his friend Jerry rock!
  21. Dec 17, 2017 at 7:56 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Sweet rig brother! Thanks for the pics!
  22. Dec 23, 2017 at 7:21 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Nice truck brother, great build pictures!
  23. Dec 23, 2017 at 7:24 AM
    thetwood
    Louisville, CO
    Thanks. It's starting to turn into what I want. Of course, the more I read around here the more I want to do... Exhaust, gears, grille, storage... Keep finding more projects than money allows.
    gosolo[QUOTED] likes this.
  24. Dec 23, 2017 at 7:29 AM
    I'm loving it so far. Doesn't hurt that we have the same name and live in CO.
  25. Dec 23, 2017 at 8:15 AM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Same name... same reply... NICE RIG!!!
    Black Wolf and thetwood[OP] like this.
  26. Dec 23, 2017 at 8:26 AM
    jro05065
    jro05065 New Member
    Denver
    2017 CM Tundra TRD
    Great looking truck! What did you end up doing with your Spidertrax 1 1/4" wheel spacers??
  27. Dec 23, 2017 at 9:09 AM
    thetwood
    Louisville, CO
    Still have them. Haven't had a chance to do anything with any of my parts yet. Interested? They're in great shape with only about 3000 miles on them. Work great. Have them back in their original box and even have all the instructions still.
  28. Dec 23, 2017 at 3:10 PM
    thetwood
    Louisville, CO
    The boys and I took the truck out today to see how things handle with all the recent changes. Headed up to the top of the Switzerland trail near Nederland. Snow on the ground and started to come down pretty hard. Went in a mile or so from the top.
    As we were alone and I didn't have proper recovery gear, we decided to go with discretion and turned around instead of taking the trail all the way thru. Still, pretty cool and truck handled everything great. No issues with traction and ride was pretty smooth. We headed over to Mud Lake just to see what we could find. Did realize that no mud flaps and wider tires spray the truck pretty good.
    Some mud flaps may be in order. The boys found an old bus frame with wind chimes inside to play with. Was pretty cool.
    Fun day in the Tundra. Need to get recovery gear for Christmas to get ready for some real playing.
    MatthewPTguy, r4z0r51o and Black Wolf like this.
  29. Dec 23, 2017 at 3:13 PM
    That's a nice area up there. Usually more snow and all it takes is one big snow drift to ruin the day......nice pics.
  30. Dec 23, 2017 at 3:55 PM
    thetwood
    Louisville, CO
    Snow wasn't too bad, but with the kids I didn't want to take any real chances. Looking forward to going back again when properly prepared. Thanks for the complement on the pics.
