Things your Tundra does that you didn't know
Discussion in 'General Tundra Discussion' started by AxelsHumanDad, Nov 28, 2016.
  1. Nov 30, 2017 at 6:43 PM
    #61
    geno0506
    geno0506 New Member
    Michael
    and go, another tread goes south quickly, :bananadance:
  2. Nov 30, 2017 at 6:44 PM
    #62
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    too much work! if you can't get in on you're own you're not getting in mine
  3. Nov 30, 2017 at 7:02 PM
    #63
    geno0506
    geno0506 New Member
    Michael
    I here that!
    4x4_Angel[QUOTED] likes this.
  4. Dec 1, 2017 at 3:28 AM
    #64
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I did that accidently on ranch road. I was not going nearly 25. No grinding or noise and did not actual go in reverse. Only way I knew was camera came on. I use the manual shift on hills on ranch especially going downhill.
    4x4_Angel likes this.
  5. Dec 1, 2017 at 3:11 PM
    #65
    4x4_Angel
    Bree
    Funky Town, Texas
    when i lock the windows i can only control the drivers side window:confused: my last vehicle i could lock the windows so the kids couldn't mess with them but i still had full control. not sure how i feel about this
  6. Dec 5, 2017 at 5:02 PM
    #66
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Today I learned that even when the key isn't in the ignition, the cigarette lighters are wired in such a way that they can still distribute a current.
    Huh?
    Let me explain...
    I have this little battery powered LED work light that I use for work and charge on the drive to and from work. I keep the charger plugged into the rear center console cigarette lighter power port (CLPP). Today after work I got in my truck and plugged the light in, it still had power in the battery. I then plugged my phone into the front CLPP charger that I use (USB aux is for my Ipod) in front of the shifter. My phone then started to charge. All this before I put the key in the ignition.
    This could be a handy trick if you find yourself in an emergency situation, although highly unlikely, of your truck battery and phone battery being dead but you have something battery powered, i.e. light, laptop, ipod etc. to draw power from.
  7. Dec 5, 2017 at 7:06 PM
    #67
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I wonder if it was triggered ON by your getting into the truck, the way that the interior lights do and then eventually times out. If I'm doing something around my truck and leave the door(s) open, the puddle and interior lights will stay on for about 20 minutes or so then turn off until I open/close a door. I wonder if this might be the same for some of the outlets, I've never thought to see what any of mine do.
    TRD-tv likes this.
  8. Dec 5, 2017 at 7:10 PM
    #68
    Baja Mike
    South Bay, Ca.
    None of my CLPP work without the key in and ignition on. Gets annoying when I'm in Baja and my race radio and GPS turn off every time I get out of the truck.
    TRD-tv likes this.
  9. Dec 5, 2017 at 7:38 PM
    #69
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was confused for a second, now I think I understand. The charge that remained in the work light battery was available to be distributed via the other charge ports when the work light was plugged into one of them. That's fricking cool. I'll have to try to see if mine has this ability as well.
    TRD-tv, Smiley, Sunnier and 3 others like this.
  10. Dec 5, 2017 at 7:39 PM
    #70
    Baja Mike
    South Bay, Ca.
    Exactly.
    Smiley, Pudge and Wynnded[QUOTED] like this.
  11. Dec 8, 2017 at 8:27 AM
    #71
    TigerTanker
    TigerTanker Tyranny doesn't leap, it creeps
    Tacoma WA
    2016 White Platinum Edition Tundra
    none so far
    So, can I listen to "Her" concession speech over and over?
    Yep, that is a bit annoying. Mine seems to adjust at only 35 mph, so it is constantly making this robot sound. I guess I could just turn up the music...
    TRDProLife and Viper3G[QUOTED] like this.
  12. Dec 8, 2017 at 3:04 PM
    #72
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    That would work if my radio was decent. The JBL system is so weak. I'm always cranking up the volume.
    UseEveryColor and 4x4_Angel like this.
  13. Dec 8, 2017 at 8:34 PM
    #73
    Mrfols
    Mrfols New Member
    Pat
    New London NC
    2018 Platinum MGM Crewmax
    Spray In Beadliner, Stealth Running Boards, Extang Solid Fold 2.0.
    When you hold down the button to turn on cruise, it allows you to use cruise without radar. Found this out while traveling from DC to NC today as the nasty weather kept TSS from working.
    Chili1, NCinCO, UseEveryColor and 2 others like this.
  14. Dec 9, 2017 at 12:09 AM
    #74
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Found out the other day that each source for the HU has its own equalizer. I originally set the EQ up when listening to XM radio. Didn't realize i needed to set it for each source.:anonymous:Well....it helped a bit but, as you all know, a sound upgrade is a much needed MOD.
  15. Dec 9, 2017 at 2:04 AM
    #75
    Jim the Jarhead
    Jim the Jarhead New Member
    2017 SR5 4X4
    Odometer read is on when you open door, dont need key to see how many miles are on truck.
    AxelsHumanDad[OP] and 4x4_Angel like this.
  16. Dec 9, 2017 at 3:17 AM
    #76
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    I'm not sure how I feel about this. My boys love to play with buttons so I have to keep it locked for when they are in the truck. Hate having to remember to unlock the windows just for me to roll them down. Never had to do that in other vehicles that had a window lock button. Wonder if that can be changed?
  17. Dec 10, 2017 at 12:49 PM
    #77
    Petekre
    Petekre New Member
    Pete
    2016 TRD PRO MGM
    96AFA591-24EF-4035-8CDF-14BB8CFBF846.jpg 75F9BB1F-7AB4-4E0D-9718-CAAB5181A448.jpg Anybody know what this is? My tundra has it and I don’t know what it is/does.
  18. Dec 10, 2017 at 1:00 PM
    #78
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Looks aftermarket. Do you have an aftermarket alarm or something?
    GodlessPro and Sunnier like this.
  19. Dec 10, 2017 at 1:13 PM
    #79
    Petekre
    Petekre New Member
    Pete
    2016 TRD PRO MGM
    Lots of aftermarket on the truck when I bought it used from the dealer. They didn’t know what it was.
  20. Dec 10, 2017 at 1:56 PM
    #80
    ScottsBad
    ScottsBad New Member
    Scott
    Free Idaho, escaped Commiefornian
    2018 TRD Limited
    Just a Bed Rug, Soft Topper, Console Safe
    My Tundra has glass breakage detection for the alarm. Which is important here in the Bay Area since SF makes breaking into cars like a parking ticket now. So there are THOUSANDS of car break-ins around here.
    Wait! This seems backwards, wouldn't you want the fat ones to jump out?! No big lift for me...
    joonbug, 4x4_Angel and Petekre like this.
  21. Dec 10, 2017 at 3:23 PM
    #81
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I didn’t know I had a centre speaker :anonymous:
    Anyway I was wondering what this wire is for? What does it do?
    I’d leads to this circle on the other side.
  22. Dec 10, 2017 at 3:27 PM
    #82
    Mr Swervlin
    O H I O
    It the sensor that adjusts for night and day driving
    Sunnier and 4x4_Angel like this.
  23. Dec 10, 2017 at 3:31 PM
    #83
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    What you mean? So when it gets dark my lights suppose to turn on? If it is it’s not working for me.
  24. Dec 10, 2017 at 3:32 PM
    #84
    Notachickmagnet
    Notachickmagnet New Member
    I love Haul-Ass mode tried it today !
    I knew there seemed to be a loss of power from my stock 2013 Tundra compared to my 2016... this is more like it !!
  25. Dec 10, 2017 at 3:36 PM
    #85
    Mr Swervlin
    O H I O
    Like adjusting your rear view mirror or adjusting your navigation screen from light to dark depending on how dark or light it is outside. Don't think it does anything for the headlights
    Edit: if you have the auto option on your headlight column and leave it on auto the lights should turn on and off by themselves depending on how dark it is
    Y0TA PR0[QUOTED] likes this.
  26. Dec 10, 2017 at 3:52 PM
    #86
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Ah ok gotcha, thank you.
    Must be for my rear view mirror cause I don’t have navigation nor auto option on my headlights.
    Mr Swervlin[QUOTED] likes this.
  27. Dec 10, 2017 at 3:54 PM
    #87
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Almost certain that is the sensor for the auto lights. @eledobleu did a write up on how to add auto headlight function. Maybe he’ll chime in.
  28. Dec 10, 2017 at 3:58 PM
    #88
    4x4_Angel
    Bree
    Funky Town, Texas
    Wouldn't you not want them in there in the first place?
    htw_hawaii, GAknight and Y0TA PR0 like this.
  29. Dec 10, 2017 at 4:11 PM
    #89
    PermaFrostTRD
    Northern NY
    Likely aftermarket remote start alarm sensor.
  30. Dec 10, 2017 at 7:27 PM
    #90
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You may have to follow the wires and see where they go to determine what that's a part of.
    That's a blank filler piece for a sensor that's for Auto Headlamps and Auto Climate Control, depending how your truck is fitted.
