2017 TUNDRA NOT STARTING
Discussion in '2.5 Gen Tundras (2014-2021)' started by markypoo, Dec 7, 2017.
  1. Dec 7, 2017 at 4:53 PM
    markypoo
    markypoo [OP] New Member
    mark
    2017 tundra
    air bags
    hello everyone, so i was hauling full bed of dirt, and i ran out of gas when i was in my yard, so i filled her up to half tank and she would not start :(, i primed it a bunch of times and still dosent start, i really need some help and would really appreciate it if yall could help :),
    thanks markypoo
  2. Dec 7, 2017 at 4:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Are you sure you ran out of gas? There’s like 5 or 6 more gallons after it reads empty.
  3. Dec 7, 2017 at 4:58 PM
    markypoo
    mark
    2017 tundra
    air bags
    yea it shut off on me, so i went and bought gas but would not start after that
  4. Dec 7, 2017 at 5:03 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    "primed it" how did you do that?
    I'm no expert, but you could hold it in start for a min and maybe it needs to let the fuel travel to the engine (you probably already did this)
    or give removing the negative battery terminal for a few min a try.
  5. Dec 7, 2017 at 5:04 PM
    markypoo
    mark
    2017 tundra
    air bags
    i put the ignition on for 20 seconds a time like 5 times, isn there another way to prime it?
  6. Dec 7, 2017 at 5:04 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Maybe you burnt out the fuel pump. Those extra few gallons are supposedly there to keep the fuel pump cool.
  7. Dec 7, 2017 at 5:06 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    And you can hear the fuel pump?
  8. Dec 7, 2017 at 5:06 PM
    markypoo
    mark
    2017 tundra
    air bags
    scary, well how could i check if the pump is out
    ColoradoTJ likes this.
  9. Dec 7, 2017 at 5:07 PM
    markypoo
    mark
    2017 tundra
    air bags
    yes we could hear the pump yes
  10. Dec 7, 2017 at 5:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I’m not sure, it’s in the fuel tank. Hopefully someone will chime in.
  11. Dec 7, 2017 at 5:10 PM
    Truck won’t start...
    Buahhhaaahhhaaa. Sorry, couldn’t resist.
    You can disconnect the fuel line, point the end into a bucket, have someone cycle the key to the on position.
    joonbug likes this.
  12. Dec 7, 2017 at 5:10 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  13. Dec 7, 2017 at 5:12 PM
    markypoo
    mark
    2017 tundra
    air bags
    ok, just asking lol, is it hard to take off the fuel line?
  14. Dec 7, 2017 at 5:17 PM
    Danimal86
    Daniel
    Sacramento, CA
    did you try resetting the ecu by disconnecting the battery (negative i believe) terminal for a few min?
    just throwing it out there
  15. Dec 7, 2017 at 5:19 PM
    SMILE
    SMILE Drink, Smoke, and Smile!
    SOUTHEAST PA
    2016 TUNDRA CREWMAX SR5 5.7L V8
    Weather tech mats, to be continued.........
    stupid question but did you try to start it in neutral? My gear selector in my old hyundai sometimes would not fully set into park activating the safety sensor. took me 2 hours to figure it out. LOL
    joonbug likes this.
  16. Dec 7, 2017 at 5:23 PM
    TheBeast
    TheBeast The Beach
    how did you run out of gas in your yard ? once the light is on there is a big reserve still.
  17. Dec 7, 2017 at 5:24 PM
    markypoo
    mark
    2017 tundra
    air bags
    well it was empty for a while, i guess i holded off to long to fill it up :(
  18. Dec 7, 2017 at 5:27 PM
    How long (mileage) is a while?
  19. Dec 7, 2017 at 5:30 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Personally I would play stupid and take it /have it towed to the dealer and try to have it fixed under warranty.
    Lesson learned don't do that again.
  20. Dec 7, 2017 at 5:35 PM
    markypoo
    mark
    2017 tundra
    air bags
    this is really wired cuz i only have 23,000 miles on the tundra:(
  21. Dec 7, 2017 at 5:39 PM
    blizz86
    blizz86 New Member
    doesnt matter if you have .2 mi or 200000 miles.. if you run your truck completely out of gas the pump/sending unit can be damaged
    hopefully you can get it hauled onto a road and have toyotacare tow it to a dealership
  22. Dec 7, 2017 at 5:48 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Agree with others tow it to dealership and never say u ran out of gas. Hopefully u still under waranty
    geno0506 likes this.
  23. Dec 7, 2017 at 5:48 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Probably should ask a mod to delete this so there's no evidence.
    Just saying...
  24. Dec 7, 2017 at 6:42 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Not sure why it would kick off but did you check your fuel cutoff switch?
  25. Dec 7, 2017 at 6:45 PM
    If your asking me, you should not perform this task
    However, this could lead to a rather funny story, so what the hell.
    Most modern fuel systems you need to get a fuel line disconnect tool set. They’re rather cheap and easy to use. YouTube has a ton of videos on performing this task safely.
    Now to do this even safer and not even disconnect the fuel line, your fuel rail has a test port for messsuring fuel pressure. Most auto parts stores will let you borrow the tester and will not charge you if the tool is returned. On your fuel rail, drivers side, a shrader valve is available to test this out. Won’t cost you but fuel back and fourth.
    Looks like this.
    joonbug likes this.
