How much weight do you put in your bed when it snows?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SMILE, Dec 7, 2017.
  1. Dec 7, 2017 at 12:18 PM
    SMILE
    SMILE [OP] Drink, Smoke, and Smile!
    SOUTHEAST PA
    2016 TUNDRA CREWMAX SR5 5.7L V8
    Weather tech mats, to be continued.........
    Wondering how much weight to put over my rear axle when it snows this year. I have heard people say 200lbs all the way up to 1500lbs. Last year my truck was brand new to me so it stayed parked and I drove my Cherokee. This year I have new tires and am used to how it drives. Live in southeast Pa so we get a decent amount of snow, but not like in the mountains. Thanks for any advice.
  2. Dec 7, 2017 at 12:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Zero.
    SMILE[OP] and joonbug like this.
  3. Dec 7, 2017 at 12:29 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I live in Central New York where we do get a fair amount of snow. I run winter tires on the truck but don't bother with extra weight in the bed.
    SMILE[OP] likes this.
  4. Dec 7, 2017 at 12:57 PM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    None with the 4wd and MTs on the tundra.
    About 200 when I had a 2wd Silverado.
  5. Dec 7, 2017 at 1:00 PM
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    NONE!
  6. Dec 7, 2017 at 1:59 PM
    nodak67
    nodak67 New Member
    JR
    just be mindful that any weight in the bed will become a missile in a emergency stop situation. use to use 70lbs bag for weight but after a slight emergency stop, never again. I tell the wife if its that slippery just use the 4x4 knob. no point in having a 4x4 if you are not going to use and I tell her to use at any time.
    our winters are long and brutal so use it.
  7. Dec 7, 2017 at 2:05 PM
    15whtrd
    15whtrd Mr. Blonde
    When I go up to the local mountains and drive in the snow, I have not had one problem with the small amount of weight that I carry in the bed. A.k.a. snow gear sleds and ice chest. I have gone with zero in the bed and not had any issues with traction.
    I would say... 1 to 2 average build dead bodies would be perfect.
  8. Dec 7, 2017 at 2:29 PM
    Warreng
    Warreng New Member
    I have a single sled deck that weight 200 lb or so? Makes a huge difference in traction with 2wd. Have seen people use a steel plate, takes up almost 0 space.
  9. Dec 7, 2017 at 2:29 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    The wife goes about #160 :)
  10. Dec 7, 2017 at 3:24 PM
    SMILE
    SOUTHEAST PA
    Thanks for the info. All my past pickups were 2WD and needed the weight. Tundra is my first 4x4 truck, but have had a couple jeeps. Looks like I will give it a shot with nothing in the bed.
    I do know anything back there becomes a projectile in a crash, I used to strap down scrap steel over the axle with more straps than necessary. Thanks for the heads up tho @nodak67.
  11. Dec 7, 2017 at 3:40 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Sand bags if you’re not running snow tires helps but 4x4 helps more
    200 lbs is what I used to put back there
  12. Dec 7, 2017 at 3:56 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
  13. Dec 7, 2017 at 4:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You made your girlfriend ride in the bed? In the snow? o_O
  14. Dec 7, 2017 at 4:59 PM
    How much does a cubic foot of snow weigh?
    Whatever doesn’t blow out of the bed, and tie down straps is about it.
  15. Dec 7, 2017 at 5:44 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Between 200 & 300lbs I have currently use four 70lb sand bags. It's more of a precaution then a necessity. I've been caught before without weight and haven't had any trouble. It's that wet heavy snow you gotta watch out for. Powder is easy. :thumbsup:
  16. Dec 7, 2017 at 6:04 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    It's easier to drift if you keep the back light
  17. Dec 7, 2017 at 6:09 PM
    Eclipsed & Floating
    Voluptuous Whitey
    She was full of helium and floated away
  18. Dec 7, 2017 at 7:00 PM
    Didn’t you have to replace the rear leaf packs already?
    Helium huh? You’re full of shit..lol.
  19. Dec 7, 2017 at 7:03 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    oh. holy hell. can not unsee. bastard.
  20. Dec 7, 2017 at 7:04 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    300 lbs of secured weight, Iowa can be a bitch in the winter and most county plows go home when the sun goes down.
  21. Dec 7, 2017 at 7:51 PM
    Eclipsed & Floating
    Voluptuous Whitey
    That’s her “little” sister that I latched on to when the winter set in. Needed to keep the home fires burnin’! How’d you get my private photos?
  22. Dec 7, 2017 at 7:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  23. Dec 7, 2017 at 7:56 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Chains are for amateurs
  24. Dec 7, 2017 at 8:21 PM
    ColoradoBoo
    ColoradoBoo New Member
    Rick
    2014 Red Toyota Tundra 4X4 TRD Maxcrew
    Firestone Airbags; remote starter; replaced stock mirrors with larger, pull-out mirrors for towing; hard plastic sectional cover for bed.
    x2.....don't need any if you have 4x4, and about 200 pounds if you don't. (Home Depot usually has sand bags that weigh about 100 pounds.) Some use concrete bags placed inside Home Depot buckets, too.
  25. Dec 7, 2017 at 8:37 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    whatever snow lands in the box
  26. Dec 7, 2017 at 8:43 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
  27. Dec 7, 2017 at 8:46 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Ice fishing with that rod?
  28. Dec 7, 2017 at 8:48 PM
    gladecreekwy
    J
    Jackson Wyoming
  29. Dec 7, 2017 at 8:50 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Ballsy, yet badass
  30. Dec 7, 2017 at 9:00 PM
    jberry813
    Lake Tahoe
    Look closer. No chains there buttercup. Just bald BGF KO2s
