360 degree camera system
Discussion in '2.5 Gen Tundras (2014-2021)' started by ubserved, Dec 1, 2017.
  1. Dec 1, 2017 at 6:24 PM
    ubserved
    ubserved [OP] New Member
    Michael
    2017 Toytota Tundra Platinum Crewmax
    Grillguard, front LED light bar, Leer Tonneau cover, rear LED bars
    I've been mulling over installing a front and rear mounted camera system with a dvr system. I've seen some companies that make a 360 degree system and was curious if anyone has had any experience with them? Basically the setup I am looking for is on that is subtle as far as camera placement, I don't want to advertise it meaning if there is need for the footage, I want to be the one who volunteers it, not where someone see's it easily and then it gets seized.
    4x4_Angel likes this.
  2. Dec 1, 2017 at 7:48 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I didn’t even know they had such a thing for vehicles.
    Pretty neat. I have seen dash cams with parking mode, etc.
    :popcorn:
  3. Dec 2, 2017 at 6:42 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I had the 360 degree cameras in my F-150 King Ranch and F-150 Platinum and I found the front view very useful and the two side cameras useless. I would like to add a front camera to my Tundra some day, it is very helpful during parking.
  4. Dec 2, 2017 at 6:51 PM
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    I installed the frac system soon after I got my truck. One of the best mods I have done.
  5. Dec 2, 2017 at 6:57 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Same! i love mine!
  6. Dec 3, 2017 at 6:26 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    What is the frac system, does it add a front camera?
  7. Dec 3, 2017 at 7:31 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Front Rear Anytime Camera
  8. Dec 3, 2017 at 7:32 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
  9. Dec 3, 2017 at 7:51 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
  10. Dec 3, 2017 at 10:04 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @smooosh, Do you have pics of your front camera installation? How did you install yours?
  11. Dec 3, 2017 at 1:16 PM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    Love my FRAC system , parking (with both ) and watching my trailer with the rear camera .
    TundraTex and 4x4_Angel like this.
  12. Dec 3, 2017 at 4:21 PM
    smooosh
    Ongoing project
    Here is the camera. I installed it in the center of the bumper. 5F21A6F5-FB07-44DA-B87B-7D3CAB07CE94.jpg
    I installed the buttons under temperature selectors.
    Thirdegree, BlueBottle and 4x4_Angel like this.
  13. Dec 3, 2017 at 6:02 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I read up on the Frac system and I have that on my list now as well. From what I read it also allows to access everything on the radio that is normally blocked while moving. Will it also allow you to get in the settings menu on the 2018 dash cluster while the truck is moving?
  14. Dec 3, 2017 at 8:28 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I haven’t tried accessing the dash settings in motion. However, I’d be very surprised if it worked. The VIM signal I’m intercepting for the FRAC harness is specifically for the Entune HU. If other parts of the truck are using VIM as well, the FRAC switch would not affect their normal operation.
    dcsleeper408 likes this.
  15. Dec 7, 2017 at 3:24 PM
    ubserved
    Michael
    I like the idea of the FRAC system, but that's not what I am trying to do. I am looking for a camera setup that is independent of the factory system. One that will have at a mininum of a front and rear camera that records to a hard mounted DVR in the truck.
  16. Dec 7, 2017 at 4:50 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    This can be accomplished with the FRAC harness. Simply by installing a two-channel DVR in-line with the Front and Rear Cam inputs to the FRAC PCB. I'm looking into a single channel dvr at the moment, because I'm only interested in recording the front cam video.
    Scpringle likes this.
