Got extended shackles? What are other advantages/disadvantages?
Discussion in 'Suspension' started by RMFTundra, Dec 5, 2017.
  1. Dec 5, 2017 at 5:38 PM
    RMFTundra
    RMFTundra [OP] New Member
    2014 Tundra TSS CM
    6”PC Stage2, PC UCA,35x12.50R20AT, Bakflip,Tint,Hypertech, SpidrTrx, Linex Bed & wTech Floor Liners
    Hello everyone. Just completed 6” ProComp stage-2 lift. Everything is great except I am 1” lower than that preferred level stance in the rear after almost 1000 Miles. Pretty sure the front coil- overs have finished settling in and now I want to bring up the backend a tick. 3” extended coach-builder Shackles is one option I’m considering. However, what’s the downside to this mod? Handling? Comfort? Towing or Bed capacity? Any users out there that can shed some light on this b4 I pull the trigger?
  2. Dec 5, 2017 at 6:07 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    No negatives that i have found so far. They are more robust and use a poly bushing instead of rubber so you get a better ride. No loss in payload or towing. Go for it!
    Coachbuilder1 and Sunnier like this.
  3. Dec 5, 2017 at 6:16 PM
    RMFTundra
    2014 Tundra TSS CM
    Thank you for promo reply.
  4. Dec 5, 2017 at 6:42 PM
    RMFTundra
    2014 Tundra TSS CM
    That’s all I needed to hear. Install looks pretty easy too. Thanks for the quick feedback.
  5. Dec 5, 2017 at 6:45 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    if you installed the lift they will be easy. ride does improve due to not having the rubber bushing binding up and the poly one that lets the suspension work
  6. Dec 5, 2017 at 6:46 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Are you running blocks in the back now?
  7. Dec 5, 2017 at 6:58 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I didn't think CB made a shackle that increased ride height by 3"?
    Coachbuilder1 likes this.
  8. Dec 5, 2017 at 10:44 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    +3” increases height by 1.75”.
  9. Dec 5, 2017 at 10:57 PM
    TheBeast
    TheBeast The Beach
    I thought without proper leaf pack the ride was not so great. Anyone had issues ?
  10. Dec 5, 2017 at 11:51 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I know, was just making sure I didn’t misunderstand the OP. Never heard the CB +3 shackles referred to as 3” shackles, just as +3’s.
    joonbug[QUOTED] likes this.
  11. Dec 6, 2017 at 9:37 AM
    RMFTundra
    2014 Tundra TSS CM
    Yep. Using AAL & 3” blocks that came w/lift kit.
  12. Dec 6, 2017 at 9:58 AM
    RMFTundra
    2014 Tundra TSS CM
    They don’t. I should’ve referred to them or described them as +3. Stepping back on this topic the “+3” description makes me curious. What does +3 actually describe, is it a deminsion, a degree, a robustness gauge? Dunno?
    zcarpenter92[QUOTED] likes this.
  13. Dec 6, 2017 at 10:10 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yeah, that's not a good way for CB to label their shackles, it's pretty confusing. My guess is it's 3" longer than the stock shackles? Maybe? Anyways, another negative of the CB shackles is fitting a spare tire under the bed.
    zcarpenter92 and TheBeast like this.
  14. Dec 12, 2017 at 3:53 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Thanks for the feedback, We def don't want anyone getting confused with sizing, Ill include all sizes at the bottom of my post. We've used the same sizing method since 2009 and feel its easier to understand, we also include actual lift amounts with all sizes rather than machine multiple holes calling them adjustable and loosing strength. You're still able to fit a full sized spare up to 35" with any of our Coachbuilder shackles. The spare tire winch holds the tire off to the driver side and will just need to center the tire when raising back up into place. The amount of strength our shackles provide is worth centering the spare by hand :thumbsup:
    ** Lift amounts are when used with a factory Tundra leaf spring **
    +1" Coachbuilder Shackles provide .625" of total lift.
    +2" Coachbuilder Shackles provide 1.25" of total lift.
    +3" Coachbuilder Shackles provide 1.75" of total lift.
    equin, Cement Pro, The Juice and 6 others like this.
  15. Dec 12, 2017 at 3:58 PM
    Coachbuilder1
    Salt Lake City UT
    You're right on, Our +3"s are 3" longer than factory. 7" from bolt center to bolt center. With the arch and location of the front spring hangers we don't want to use anything larger than our +3"s for the factory leafs. This would not allow the leafs to cycle completely, We have built +4"s in the past for larger Atlas leafs.
  16. Dec 12, 2017 at 4:09 PM
    TheBeast
    TheBeast The Beach
    how about Deaver K37s and KING rear shocks. which size do you recommend ?
  17. Dec 12, 2017 at 4:19 PM
    Coachbuilder1
    Salt Lake City UT
    The K37s are a very soft leaf pack, Softer than your factory leafs. The leafs provide about .750" of additional lift but will loose it after they settle. We normally use a set of our +2" Coachbuilder shackles (1.25" of lift) for trucks running less than 3" up front and our +3"s for guys a touch over 3" up front or who prefer a small amount of rear rake. How are you using your truck and how much rear lift are you wanting?
  18. Dec 12, 2017 at 8:09 PM
    Blindman75
    Blindman75 New Member
  19. Dec 12, 2017 at 8:55 PM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    If they increase by 3” I’m gonna put some in the front AND back
  20. Dec 12, 2017 at 9:38 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I’m not a fan of adding different types of lifts ontop each other like extended shackle with block. The best ride your going to get is replacing the leaf springs with ones built for the proper lift. OME Dakar or custom Alcans are good options.
    I had a 6" lift on my Tacoma with blocks in the back. Rode like crap. I ended up replacing the rear springs with blocks with a set of custom Alcan leaf springs that were to the exact lift that i needed. No more blocks. Road so much better.
    dcsleeper408 and TheBeast like this.
  21. Dec 13, 2017 at 6:45 AM
    Hey David- out curiosity, what type of testing have you conducted to state that multiple holes would cause them lose strength? Any stress testing you could post?
  22. Dec 13, 2017 at 1:08 PM
    Coachbuilder1
    Salt Lake City UT
    Using different items together can be a headache especially with the Tundra, Dakar Leafs are longer than the OE leafs and require at least a +1" Shackle in order to clear the frame rails when loaded heavy. Deavers need at least a 1.50" shackle because of the rear eyelets diameter and spring rate of there leafs. Reason they use the TC shackles.
    The Alcans use a progressive design keeping the leafs overall length restricted and Atlas has reduced the rear eyelet diameter in order to clear the frame rails. We designed our Coachbuilder parts specifically to be compatible with all other brands. I agree with you on blocks, They add just enough leverage to increase axle wrap, even a 1" block you'll feel the difference.
    The Juice and Watt maker like this.
  23. Dec 13, 2017 at 1:17 PM
    Coachbuilder1
    Salt Lake City UT
    Your sway bar end links are adjustable and will def work for your application. We just want the returns of the sway bar to sit parallel to the frame with the truck on the ground. Your air bags will work with our +1"s and +2" Shackles but will need our Air bag spacer kit when using our +3"s (The bag can only reach so far before needing to be extended) Depending on the type of driving you're doing you can set the 5100s on the top setting and use one of our shims above the driver side assembly. This will correct the driver side lean and provide a level side to side stance at 2.5" up front. If you prefer a softer ride you can set them at the middle setting and use 2 shims per side, our front bump stop extension kit would also be needed for the setup. For a level looking stance you'd use our +2"s for this application. your truck will look level but will measure .750"-1" higher in the rear.
    Watt maker likes this.
  24. Dec 13, 2017 at 1:28 PM
    Coachbuilder1
    Salt Lake City UT
    Not much testing needs to be done to know when removing material you loose strength. If the stress or load is controlled to only one direction you can design the part strong and add speed holes in order to loose weight. But with the load being 360 degrees on the rear pivot its a fact that by adding holes for adjustment you're loosing strength. Ive attached a few pics, there is not only a strength difference but functionality difference in the material and finish. hope the helps.
  25. Dec 13, 2017 at 3:48 PM
    csuviper
    Broomfield, CO
    From my knowledge, Toytec has been selling their shackles of the same design on the Tacoma since 2004. They have had zero customer complains and zero negative social media posts about damaged or broken shackles. I don't know for sure but im guessing the same goes for the Ekstom design. In fact i have not seen or heard of a stock one failing on a tundra.
    My experience with the Toytec shackles has been very positive. Was able to easily adjust between 1.5" and 1" height to get the look and feel i wanted. I do not have any concern with failure.
  26. Dec 13, 2017 at 3:57 PM
    Ditto ^^^^. The ToyTecs are so beefy..the shackles ever failing is the last thing on my mind. Zombie Apocalypse will happen first.
    Toytec Lifts, TheBeast and T-Rex266 like this.
  27. Jun 5, 2018 at 5:31 PM
    csuviper
    Broomfield, CO
    The bushings from Toytec are supplied by Energy Suspension. Not sure who makes the ones that coachbuilder supplies. The Toytec ones are poly as well.
    Energy suspension is the worlds largest manufacturer of performance polyurethane automotive components.
    http://energysuspension.com/products.html
  28. May 12, 2021 at 12:14 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Old thread. Just came to say....
    @Coachbuilder1 if you want to point out that adding adjustment holes decreases strength, then you’ll have to admit using aluminum instead of steel is going to decrease strength. Posting side by side pictures claiming your shackles are much “beefier” is disingenuous.
    Yours are aluminum. Toytecs are steel.
  29. May 12, 2021 at 12:32 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Both Coachbuilder and Toytec contain 0% beef and no beef byproducts. So neither are beefy.
    And holy old thread Batman.
