Questions for those of you with Weathertech's
Discussion in 'General Tundra Discussion' started by airgunner, Dec 5, 2017.
  1. Dec 5, 2017 at 6:37 AM
    airgunner
    airgunner [OP] New Member
    N-KY
    2015 DC MGM TRD
    Hey guys,
    One of the first things I did when I got my Tundra was ordered a set of Weathertechs for it. I've had them before and love them but so far, not loving them in the tundra.
    The front drivers side is great but the front passenger moves around a bunch. I know it came with some hold downs but they didn't look very good. Any of you use them? How well do they work and hold up?
    What I was really wondering is there a way to get the factory hold downs that are on the driver side and use them with the Weathertech on the passenger side?
    Also on the rears, they stay OK but I've noticed while you are trying to get in, your foot can hit the edge and pull it up and you can kind of trip on it. I was thinking about tucking the ends under the door sill plates? Looking at it, I realize I will have to cut some holes in the mat to allow the door sill plate to reinsert correctly but that's not a big deal I don't think?
  2. Dec 5, 2017 at 6:42 AM
    Sunnier
    Sunny
    San Diego, CA
    Um. I don't want to be a downer... and I don't have Weathertechs. However, after reading a ton on this forum, I know that to get the best out of Weathertechs, you gotta get rid of 'em and get Husky instead. I hope you hear differently from someone else.
  3. Dec 5, 2017 at 6:52 AM
    Get some Velcro strips the hook ends apply 4 long strips evenly spread out to underside of passenger side mat this works
  4. Dec 5, 2017 at 6:53 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I’ve got weathertechs....I use the little pop in grippy on the passenger side and never had an issue. Also on the back mine seem to sit flush and again never had an issue
  5. Dec 5, 2017 at 7:27 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I have WT and no issues. Sit flush and no movement in mine.
  6. Dec 5, 2017 at 7:36 AM
    Newm
    Newm New Member
    KC
    I used to have Wethertechs....^ see above....IMO.
  7. Dec 5, 2017 at 7:38 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Husky!
    Eclipsed & Floating likes this.
  8. Dec 5, 2017 at 7:42 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Same here. Mine sit flush and no issues with movement at all.
    TXMiamiFan[QUOTED] likes this.
  9. Dec 5, 2017 at 7:59 AM
    B_brand
    B_brand New Member
    Brandon
    2017 White SR5 4WD DC
    NFab Steps, LEER Shell, BedRug
    I have the WTs and love them. I know what you mean about your foot catching the end and bending it up though. You could try taking them out and laying them upside down with something heavy on the edge to help them form better.
  10. Dec 5, 2017 at 8:07 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    My passenger side does move but isn't an issue. I found the rear oem works well and the WT would need cut up for the ESP under seat storage. For the front driver side, I'm not happy with them and will recommend a diff brand. My dead pedal and bottom plastics are exposed, no protection from going from sand, mud, snow, or clay straight to the truck. After time, im sure that the dead pedal carpet will wear through down to the metal floor board.
  11. Dec 5, 2017 at 8:19 AM
    TXMiamiFan likes this.
  12. Dec 5, 2017 at 8:27 AM
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    3 vehicles with Huskys....no problem
    1 vehicle with WT....nothing but problems even after I Velcro them to the floor
    I’m rough on floor mats and will never go WT again
  13. Dec 5, 2017 at 8:40 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    I velcro the passenger side and haven't had any issues. If you have them already do that and try to make them work before you sell them and lose money.
    Sunnier likes this.
  14. Dec 5, 2017 at 8:46 AM
    airgunner
    N-KY
    2015 DC MGM TRD
    I will try the plugs that came with them or the velcro thing but I'm not selling them and buying Husky's. This is my 3rd set of WT's and the only one I've had issues with and those issue are pretty minor. Well the back is anyway. The front is an issue because it slides on my GF as she tries to get in sometimes and I'm afraid she going to end up busting her ass (or worse) one of these days.
    I wish I could get the factory hold downs like what's on the Driver's side. Wonder if that is something Roman can get? Will have to check with him.
    Sunnier likes this.
  15. Dec 5, 2017 at 8:49 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    I have WT's front and rear in mine and added the Velcro to the passenger side. It sort of works but would probably work better had I used more aggressive Velcro. The rear fits great but there is an edge that can be caught and pulled. I can't say that they've been an issue for me though as I'm usually the only one in the truck.
  16. Dec 5, 2017 at 4:25 PM
    Fucking love my WT!!!!!
