Can I see your 275/70r18 please.
Discussion in 'Wheels & Tires' started by Rngr188, Sep 16, 2017.
  1. Nov 9, 2017 at 8:08 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    Good to hear. I know size wise it's not much of a jump but I was concerned that going from a "Passenger/Highway" tire that weighs ~42# to an "E" rated LT tire that weighs ~58lbs might be more noticeable? The stiffer sidewalls affecting ride quality and the weight affecting gas milage and maybe ride too?
  2. Nov 9, 2017 at 2:32 PM
    Smokin1794
    Smokin1794 New Member
    Northern Washington
    What about 275/70/18 vs. 285/65/18? If you can run a 275/70 with no rub, can the same be said for a 285/65? Seems like they even out? One is 1" taller but the same width. The other is 1/2" wider and 1/2" taller. Is this the case?
  3. Nov 9, 2017 at 2:50 PM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    @airgunner ...I didn’t have a lot of seat time as the factory wheels and tires came off at around 2k miles....that said my butt dyno doesn’t seem to notice too much of a difference and the vehicle computer is reading less than 1 mpg on the computer on my normal highway commute.....17.3 vs. 16.5 mpg. Vehicle is probably stiffer than stock but again without a lot of seat time I didn’t notice a huge difference
  4. Nov 9, 2017 at 3:00 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    303A1A76-13AE-4053-8E7D-FE3193E36161.jpg I’m really happy with the 275/70r 18
    7EBB63D7-326C-4E1B-A88B-BD775B15CC65.jpg 0841B8F1-0687-4E9D-82C0-67BA9BE8BE41.jpg
  5. Nov 9, 2017 at 3:34 PM
    airgunner
    N-KY
    2015 DC MGM TRD
    Understood. Thanks again for the pics and follow ups. Your truck looks awesome! :cheers:
    Vendeta2k[QUOTED] likes this.
  6. Nov 22, 2017 at 9:03 AM
    FISHMASTER
    FISHMASTER New Member
    KURT
    South dakota
    2017 TUNDRA
    I put on a set of 275/70/18 Cooper ST max
    What's most people running for pressure?
    I'm at 50psi now.
  7. Nov 25, 2017 at 9:02 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    275/70 on 6112’s at its highest setting
  8. Nov 25, 2017 at 9:55 AM
    TheBeast
    TheBeast The Beach
    running 40 psi in my Toyo 33"s. I could probably run 45 or 50. Trying different psi right now see what rides the best after my suspension mods.
  9. Dec 1, 2017 at 2:31 PM
    cityneck
    cityneck New Member
    Los Angeles
    2020 Tundra TRDOR4x4
    Bilstein 5100 Front (middle setting) and Rear - Spidertraxx 1.25" spacers front and rear. 275/70/18 BFG KO2
    GELCW, silverstreak16, JRock and 10 others like this.
  10. Dec 1, 2017 at 3:59 PM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    @cityneck looks really good! Would you mind posting a pic from the front or rear? Just wanted to see how the stance is with Spidertraxx on this size tire. Thanks.
    DantheMan likes this.
  11. Dec 2, 2017 at 11:29 AM
    cityneck
    cityneck New Member
    Los Angeles
    Here ya go!
    The Dude, Gee Dub, Big J and 5 others like this.
  12. Dec 2, 2017 at 4:21 PM
    757TUNDRA
    Illinois
    Thanks @cityneck, looks good!
    NoMoTaco likes this.
  13. Aug 7, 2018 at 1:32 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Let’s get this train rolling again... any new 275/70r18 folks out there since last December??
    Dougr6 and Yoda1 like this.
  14. Aug 7, 2018 at 2:29 PM
    Yoda1
    Yoda1 New Member
    2016 MGM Tundra Crewmax
    I just went to 275/70R18 with 1.25" Spidertrax spacers and Toytec BOSS kit. 20180729_120948.jpg 20180729_121006.jpg
    The Dude, Kyk1e, Big J and 4 others like this.
  15. Aug 7, 2018 at 3:47 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Here is mine with stock wheels and an OME lift.
    It doesn't even come close to rubbing.
    I have 50k miles on my KO2's and I'm pretty sure I will simply buy the same type and size tire again when it is time to replace them.
    Something else to think about is that 275/70R/18 is a pretty common size. It is my understanding it is a stock size on a lot of 3/4 ton trucks.
    I was on a road trip and I blew out the sidewall on one of my tires...I was being stupid. I pulled into a Discount Tire in Grand Junction and they had my tire in stock and they replaced it for free...apparently "stupid" is covered under their warranty...and I was back on the road in a couple of hours.
    If I would've purchased an unusual size or brand of tire I might have had to spend a couple of days in Grand Junction while they ordered a new tire.
    The Dude, TxLock21, Big J and 2 others like this.
  16. Aug 7, 2018 at 4:51 PM
    CCLJ03
    Craig
    Ooooooh shit I have been looking at those wildpeaks for a long time! And my truck is Cement... so you’re truck is literally exactly what I was looking for.
    I would love to see as many angles as you’re willing to post!
    danno266 likes this.
  17. Aug 7, 2018 at 5:22 PM
    Tuckerman048
    Tuckerman048 New Member
    Western Pennsylvania
    2014 CM 4x4
  18. Aug 7, 2018 at 5:35 PM
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    275 70 R18 cooper discover A/T3. Had to take front mud flaps off put I don’t like those anyway.
  19. Aug 7, 2018 at 5:52 PM
    CCLJ03
    Craig
    I’m guessing this is with a level? Any rubbing in those mud flaps? And did you need spacers of any kind.
    What an awesome looking truck!!
    Haggis777 likes this.
  20. Aug 7, 2018 at 5:57 PM
    #50
    Yoda1
    Yoda1 New Member
    I'll try to get some more this weekend.
  21. Aug 7, 2018 at 6:01 PM
    #51
    CCLJ03
    Craig
    My man! Much appreciated.
  22. Aug 7, 2018 at 6:01 PM
    #52
    Tuckerman048
    2014 CM 4x4
    CCLJ03, it is leveled with Billsteins 5100 on top setting, running 295/70/18 Nitto Ridge Grapplers on stock wheels.
    When I did the level I removed the small front mudflap and cut away a small portion off the edge of the skid plate. I have no rubbing at all under full lock out.
    I lost about 2-3mpg with the tire size upgrade but I knew it was going to happen.
    CCLJ03 likes this.
  23. Aug 7, 2018 at 6:18 PM
    #53
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Forgot I started this thread!! I went with 275/70 RG on stock TRD OR wheels and suspension no rub.
  24. Aug 7, 2018 at 6:35 PM
    #54
    CCLJ03
    Craig
    2-3 mpg!? Yikes. Haha
    BP207 likes this.
  25. Aug 11, 2018 at 11:11 AM
    #55
    Yoda1
    Yoda1 New Member
    Here are a few more.
    The Dude, HbbTundra08, Big J and 2 others like this.
  26. Aug 11, 2018 at 11:23 AM
    #56
    CCLJ03
    Craig
    Well it sure does look good!!
    I’m just so indecisive with the tire decision. Haha
  27. Aug 11, 2018 at 11:31 AM
    #57
    Yoda1
    Yoda1 New Member
    Thanks. It took me awhile too. Being in snow country I didn't want a wide tire. I was trying to find a tire that would do good on the slick, winter roads. I added the wheel spacers have more clearance for tire chains. I ended up needing to remove the front mud flap so now I'm concerned I'll have tire chain rubbing, but I really like how it turned out.
    CCLJ03[QUOTED] likes this.
  28. Aug 11, 2018 at 12:45 PM
    #58
    CCLJ03
    Craig
    Yeah I’m in the same boat. 12.5” wide tires just don’t cut it in the snow. I stick between 10” and 11”. Luckily I don’t need chains though.
    I’m really hoping I can get 275/70’s in there an still have some clearance with the bilstein 5100’s.
  29. Aug 14, 2018 at 3:24 AM
    #59
    PermaFrostTRD
    Northern NY
    Stock wheels? No spacers? No problem. I’m all stock except 275/70 tires. (TRD-OR wheels and suspension which are the billy 4600’s I believe). No rubbing. No fender pushing, no liner moving. No mudflap removal.
    Henry1jg and splitfuse like this.
  30. Aug 14, 2018 at 5:03 AM
    #60
    CCLJ03
    Craig
    Yessssss that’s what I’m talking about!
