Starting to think my truck is possessed.....warranty issue yet again
Discussion in '2.5 Gen Tundras (2014-2021)' started by Matthew1794, Oct 24, 2014.
  1. Oct 24, 2014 at 5:32 PM
    Matthew1794
    Matthew1794 [OP] New Member
    Matthew
    2014 Copper 1794 Edition
    Window/windshield Tint, AMP research power steps, Line-X bedliner. More to come.
    So I was under my truck yesterday and noticed a small amount of oil building up on the base of my transmission bell housing. I suspected a rear main seal, and sure enough after taking it into the dealership today they agreed and said that it was the rear main seal. I have to take it back Monday and drop it off for them to remove the transmission and replace the seal. I wanted to post this not to complain because I love my truck and wouldn't trade it for anything, but instead wanted to see if this is a common issue or if anyone else has had this problem and if so how it has been since repaired. My truck is a 2014 1794 Edition with 6,400 miles on it, so obviously this isn't a normal wear and tear issue. Thank you in advance for the feedback!
  2. Oct 24, 2014 at 7:27 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Jeeze..... not the normal for sure!
    Relentless likes this.
  3. Oct 24, 2014 at 11:24 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Wow yea for a 2014 I would be pushing toward lemon law if this isn't the first major thing to happen.
  4. Oct 25, 2014 at 7:29 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Warranty....go get it reapaired and drive it for a few hundred thousand miles. :)
    These issues should not come up, but they do, machines are not perfect, at least your under warranty. I am sure Toyota will make it right.
    Best of luck!
    NewImprovedRon likes this.
  5. Oct 27, 2014 at 10:14 AM
    Stuff fails...it's built by a human, and there's bound to be a bad part at some point
    Patriot likes this.
  6. Oct 28, 2014 at 6:53 AM
    Matthew1794
    Matthew
    Yeah the dealer has been awesome handling this for me and has kept me informed. The only thing that is laughable is I went from a crewmax tundra to a crew can Tacoma. I feel like I'm in a power wheels.
    T-Rex266 likes this.
  7. Oct 28, 2014 at 7:44 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Just imagine what we would be reading if this was a Dodge forum....
    just kidding Dodge fans..
    LGTundra likes this.
  8. Oct 29, 2014 at 8:02 PM
    Matthew1794
    Matthew
    Well the short story version is the rear main deal was not the problem. They then looked to the crankcase sensor, replaced it, and it is still leaking. Today a field engineer checked it and found that apparently an oil galley is leaking and if that is the case I will be getting a new short block for my truck with all new internals. So still sucks to not have my truck but they are definitely diligent at getting it figured out.
  9. Oct 29, 2014 at 9:52 PM
    csuviper
    Broomfield, CO
    Oh wow worse than you thought. I would push for a new truck rather than a new engine swap.
    TruckyTruck likes this.
  10. Oct 29, 2014 at 10:40 PM
    TruckyTruck
    Gary
    Man... If you don't get a different truck, you sure better get a platinum warranty for free. Seriously, they will give you this if you push for it. I think I'd be pushing for an unmolested truck... Or at least a supercharger and non flex equipment... Damn you've been thru the ringer
  11. Oct 30, 2014 at 3:58 AM
    Matthew1794
    Matthew
    Well I love my truck and for now I am having faith in the dealerships ability to handle the problem. My theory is basically if I get the truck back and it starts having issues again then the discussion needs to happen about possibly swapping the truck out. Only time will tell, I'm suppose to find out a definitive "what's going to happen" today.
  12. Oct 30, 2014 at 2:24 PM
    Push for a free plat warranty or rig.
    This is a $45k+ truck that is BRAND new. They need to make it right somehow.
  13. Oct 30, 2014 at 4:14 PM
    Matthew1794
    Matthew
    OK so verdict is in and truck is repaired. Turns out oil pan was damaged at assembly and because of that wasn't sealed properly so they replaced that and also replaced the rear main seal and crankshaft seal because they had been removed during diagnosis.
  14. Oct 30, 2014 at 7:01 PM
    TruckyTruck
    Gary
    So.... New motor?
  15. Oct 31, 2014 at 5:19 PM
    Patriot
    Patriot Member
    Verdict in thread closed?
  16. Oct 31, 2014 at 7:22 PM
    csuviper
    Broomfield, CO
    That's better than expected. Oil pan leaks aren't bad, unless you run the engine with little to no oil because of the leak Sucks they had to open it all up for just an oil pan leak though. Really should have been the first thing they looked at.
  17. Nov 3, 2014 at 6:58 PM
    Matthew1794
    Matthew
    Yeah you would have thought that would have stuck out a little, but I would rather it be fixed than go unnoticed. Hopefully that's it and the issues are over. Definitely happy to have my truck back.
  18. Nov 27, 2017 at 10:03 AM
    Krabage
    Krabage New Member
    2014 DC TRD
    Hi OP are you having any issues? This just started on my 14' with only 36k miles.
  19. Nov 27, 2017 at 10:16 AM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Probably not gonna get a reply, since the OP hasn't logged on since Dec 2, 2014.
  20. Nov 27, 2017 at 10:33 AM
    TheBeast
    TheBeast The Beach
    fix must be good. OP has not been back in 3 years ;)
