New member from cape cod
Discussion in 'New Member Introductions' started by 13tundra, Nov 24, 2017.
  1. Nov 24, 2017 at 5:18 AM
    13tundra
    13tundra [OP] New Member
    13 white crew max
    I recently purchased a 2013 crew max. I took the dealer installed drop in bed liner out to make sure it was ckean underneath. When i took it off i noticed the normal wear caused by the rubbing of the liner but i alsi noticed rust! I took it to the local dealer and they they told me its not covered under the 5 year corrosion perforation of sheet metal warraty. The tec told me to sand it down myself and have a spray liner installed. Anyone else experiencing rust in there not quite 5 year old truck? Should the dealer fix this? Any advice would be appreciated.
    T-Rex266 likes this.
  2. Nov 24, 2017 at 6:05 AM
    Slayer
    Slayer Member
    Slayer
    Welcome from the Pacific NW.
    got any pictures of the rust?
    if it's just surface rust... do as dealer advises
  3. Nov 24, 2017 at 6:09 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Ugh. I bought my truck from a dealer on the Cape. Leased by a fellow who used it as a work truck. Never occurred to me to look under the drop in bed liner. :crapstorm:
  4. Nov 24, 2017 at 6:10 AM
    Welcome from Ohio!
  5. Nov 24, 2017 at 6:20 AM
    Welcome! Can you post photos of it?
    TundraTss and NewImprovedRon like this.
  6. Nov 24, 2017 at 8:11 AM
    Welcome from Texas! Let's see your ride
  7. Nov 24, 2017 at 8:28 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Welcome bud
  8. Nov 24, 2017 at 8:36 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    2015 Platinum Super White Crewmax 4X4
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Welcome!, Pull the bed liner, sand it down and have a spray in bed liner done. You will be a lot happier.
    Law323 likes this.
  9. Nov 24, 2017 at 9:23 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  10. Nov 24, 2017 at 10:40 AM
    TundraTss
    TundraTss The Mistress
    Brandon
    2019 TRD SR5
    Everything. Literally.
    Welcome bud.
  11. Nov 24, 2017 at 11:15 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Drop in liners just don't make sense unless you live in the desert and don't wash your truck.
    Law323 likes this.
  12. Nov 24, 2017 at 11:37 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome
  13. Nov 24, 2017 at 11:47 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Welcome from Texas!
  14. Nov 24, 2017 at 1:49 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Welcome from San Antonio!
  15. Nov 24, 2017 at 6:19 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Welcome from WI
  16. Nov 25, 2017 at 6:35 AM
    13tundra
    13 white crew max
    Heres the rust spot.
  17. Nov 25, 2017 at 6:46 AM
    Slayer
    Slayer Member
    Slayer
    no big deal there..
    sand & paint it or sand & bed line it.
    done
    T-Rex266 and NewImprovedRon like this.
  18. Nov 25, 2017 at 8:34 AM
    Marty McFly
    Morty McBoonJug
    Welcome from SoCal sir :hattip:
  19. Nov 25, 2017 at 7:58 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Welcome from Las Vegas
  20. Nov 26, 2017 at 6:11 AM
    13tundra
    13 white crew max
    Thanks everybody. What concerns me is the fact it looks like the rust is coming from the seam. i can fix the surface area no prob. Im afraid its what i cant see below that caulking that im worried about covering.i looked underneath the bed and did not see rust on that side.
  21. Nov 26, 2017 at 6:28 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Welcome!
  22. Nov 26, 2017 at 8:01 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Not a problem, sand it and put some spray in liner. As for the seam, look under the truck and find the spot, sand it down and spray some rustoleum caulk some silicone or more spray in liner (if needed) Noone's gonna see it. Blast and forget.
    Welcome from TN!
  23. Nov 26, 2017 at 12:39 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  24. Nov 26, 2017 at 2:53 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    I’m from CT, I still have my drop in but I peek under it from time to time
  25. Nov 26, 2017 at 6:40 PM
    13tundra
    13 white crew max
    So it seems like no one thinks this is a manufacturer defect and i should take care of it myself? Thanks for everyone's input.
  26. Nov 26, 2017 at 6:41 PM
    I agree with this. You can try taking it up, but it may be a bigger hassle then just doing the small correction yourself.
