2004 Rear Suspension Vibration
Discussion in 'Suspension' started by RCouto, Nov 26, 2017.
  1. Nov 26, 2017 at 8:42 AM
    RCouto
    RCouto [OP] New Member
    My '04 SR5 TRD Tundra has a vibration when braking between 40 and 60 MPH. The rear drums were just replaced and the new tires balanced by a Toyota dealership. If I brake hard, there is minimal to no vibration. This vibration is kind of like a shutter. What are some other things this could be?
  2. Nov 26, 2017 at 8:44 AM
    Ragecage92si
    Ragecage92si New Member
    Josh
    17 blue TRD
    7" BDS lift kit,3” body, King 2.0’s, Mammoth Guards, Custom powder coating, Nitro 5.29, D.A.P. Tuned, Coachbuilder shims, Coachbuilder Steering kit, Wether Tech vent visors, and hood protector, spray in bed liner, Bakflip, Fuel wheels, 38” TOYO tires, Bushwacker fender flares, Dirty deeds exhaust , TDK front bumper, Rigid light bar/floods/spots. Husky fronts, Weather Tech rears, ESP under seat storage, PowerX2 battery, Android Tesla unit, AJT chrome delete, Horn Blasters, Custom switch cluster, Interior leds, Revere leds, 19 pro headlights, Rocklights, Custom MAYHEM projector
  3. Nov 26, 2017 at 8:45 AM
    RCouto
    Oh, sorry, I forgot...I just replaced the rear shocks too with stiffer Gabriel off road shocks.
  4. Nov 26, 2017 at 8:46 AM
    RCouto
    Also, the truck only has 123K on it.
  5. Nov 26, 2017 at 8:46 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Do you feel the shudder in the steering wheel? Pedal? Or whole truck shakes?
  6. Nov 26, 2017 at 8:49 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    When you say that the rear drums were replaced, is it safe to assume that they were replaced trying to solve this issue? And didn’t make a diference?
    I’ll suggest checking for a bent axle shaft with a dial indicator, and checking that all the spring u-bolts are tight.
  7. Nov 26, 2017 at 8:51 AM
    RCouto
    Not in steering wheel and not in the pedal. The back of the truck is shuttering, kind up and down . I also tried the e-brake test. Go real slow and only put the e-brake on (slowly) until the truck stops. No pulsing at all. Oh, ya, I just did a complete rear and front brake job too.
  8. Nov 26, 2017 at 8:54 AM
    RCouto
    Would worn bushings in the leaf springs or worn out springs cause this? Bent axle...wouldn't this show up in a 4 wheel alignment? I just had the truck aligned at Toyota too.
    I have been replacing the simple things to solve this, yes I started with brakes and shocks.
  9. Nov 26, 2017 at 9:24 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    No, a bent axle shaft on a semi-floating axle won’t show up on an alignment, unlike a bent axle housing. Might be a long shot, but an easy check.
    And yeah, have a good look at the rear spring bushings.
  10. Nov 26, 2017 at 9:29 AM
    RCouto
    Thanks, I will check both the axle shaft run-out and bushings.
    One question, wouldn't a bent axle shaft show up in regular driving just as much or even more? The truck drives (when not braking) real smooth.
