Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Nov 23, 2017 at 9:45 PM
    #991
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    285/65/20 is basically a 34.6” tire. It might fit with a stock offset but with +25, it will definitely rub the front liner, mudflaps, and will be really close to the cab mount. I have a 34.4” MT tire with +25 but didn’t need a CMC but am really close. Impossible to say for sure because it also depends on your UCAs and your caster. Like I said, there’s a good chance you won’t need a CMC, but I don’t want to say you won’t incase you do need it. Personally I would try it or get a 295/60/20. In between the two.
  2. Nov 23, 2017 at 9:48 PM
    #992
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    2016 Magnetic Gunmetal Metallic Platinum
    Tinted Windows, Baja Designs LED Fog Lights, EGR Matte Black Bug Guard, SCS SR8 Gunmetal wheels, 295/70/18 Nitto Ridge Grapplers, 3/1" Readylift Kit, Morimoto XB Headlights, Viper Smartstart Remote Start, Kobalt Low-Profile Toolbox, Husky X-Act Contour Floor Mats
    I'd be perfectly happy with a 295/60/20 I think. That's only about 39.4" diameter and 11.6" wide. You think that should clear everything okay?
  3. Nov 23, 2017 at 9:52 PM
    #993
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It’s about a 33.9”. You still might rub the front liner a little but you’ll clear the cab mount. Check out @r4z0r51o ’s build. He has flares and has tried a lot of different combinations with 20’s.
  4. Nov 23, 2017 at 9:55 PM
    #994
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  5. Nov 23, 2017 at 10:17 PM
    #995
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Hey Zack. Just put on these bushwhacker pocket flares a couple weeks ago. Here are a few before/after pics so you can see the flare coverage. Tires are 35x12.5/18 on a 4.5 in lift. Don't know exact offset of rims tho. Your rim guy should be able to calculate offset for desired tire position. Mine were out about 2in and ended up slightly outside of the flares. Stance looks good tho. Definitely don't want to have the tucked in look when you do it.
    Before
    Half
    Both
    Biby, robcast52465, TxLock21 and 3 others like this.
  6. Nov 23, 2017 at 10:41 PM
    #996
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    Your truck looks sick. I couldn't quite convince myself to do a 4.5 inch lift but your stance is mean and your truck's image will now forever be burned I'm my mind. Thanks for the pictures and the info!
    BakNBlk2014[QUOTED] likes this.
  7. Nov 23, 2017 at 10:50 PM
    #997
    BakNBlk2014
    Donald
    Virginia Beach VA
    Thank you sir. Post up some pics and specs when you complete your project. MGM trucks look awesome modded out.
  8. Nov 23, 2017 at 10:52 PM
    #998
    ZackRP
    ZackRP New Member
    Zack
    Wyoming
    I'll be sure to post it all for you and anyone else to inspect. :D
  9. Nov 25, 2017 at 6:40 PM
    #999
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Does anyone have some pictures of a 2” leveling kit with 285/75 in stock trd off road wheels? Perhaps 295/70/18 also?
    eastwa and HBdirtbag like this.
  10. Nov 27, 2017 at 9:52 AM
    #1000
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    Just got my 2017 CM 4X4 and would like to know if 18x9 with +18mm offset will work with 32" tires (same overall diameter as oem) on STOCK height. No level and lift. Thanks.
  11. Nov 27, 2017 at 8:20 PM
    #1001
    EduardMusatov
    EduardMusatov New Member
    Eduard Musatov
    Lynden, WA.
    2017 toyota tundra crewmax
    Trd exhaust, Trd intake, sway bar, amp running boards, tunnel cover, paint match handles and mirror caps, aftermarket remote start, 2018 head light,
    So I am looking to get some wheel 20x9 +12 offset or 20X10 00 offset what would be better ?
  12. Nov 28, 2017 at 6:00 PM
    #1002
    TigerTanker
    TigerTanker Tyranny doesn't leap, it creeps
    Tacoma WA
    2016 White Platinum Edition Tundra
    none so far
    I’m getting 20x9 bs4.53 bore 110.2 with a -12 offset.
    Can anyone explain or show a pic of what that would look like?
  13. Nov 28, 2017 at 6:12 PM
    #1003
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Check out @CMLenny's build in the 3rd gen builds page. He ran that size on Bilstein 5100's for awhile before upgrading to 37's.
  14. Nov 29, 2017 at 7:23 AM
    #1004
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Anyone running a set of Method Vex? I've looked around and have found very few Tundras with this wheel. I'm trying to decide between the Vex and the NV with Cooper STT PROs. If I stick with 18's I'll just go with 275/70. If I go down to 17's, I'll do 295/70. Thoughts or suggestions?
  15. Nov 29, 2017 at 7:51 AM
    #1005
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've been happy with the STT Pros. Now I gotta go look up the Vex, doesn't sound familiar.
  16. Dec 6, 2017 at 2:50 AM
    #1006
    Toyota10s
    Toyota10s New Member
    Chace
    West Coast
    2017 Toyota Crewmax limited Tundra
    Bone stock.
    So, for the 2018s, is this list updated?
    Also, regarding the 20" wheels above, it shows the same width as factory. Is it possible to go wider without going up to 21s or 22s? Or would I just go with 295s or 305s? If I'm at that point, am I gonna have to cut the wheel wells? thx
  17. Dec 6, 2017 at 3:40 AM
    #1007
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    the 2018's are still a 3rd gen and I don't think there were any changes from the previous years so these lists still apply. you do not have to go to a larger wheel to get wider tire. you could also fit a 295/55/20 without a lift, but you will have to remove the little front mud flap. you can check out my build thread for pictures. I leveled the front (1.5"), but these tires will fit without a lift.
  18. Dec 7, 2017 at 4:42 AM
    #1008
    Dausman351
    Dausman351 New Member
    2015 Black Tundra CrewMax
    ARE Cap Toyota SS Step Bars Fuel Cleaver 20x9 +20 275/60R20
    2015 Crewmax, Fuel Cleaver 20x9 +20 offset with DuraTrac 275/60R20, no lift. Decent rub in front drivers side at full turn in reverse. 3/1 leveling kit on the way.
    Tony v likes this.
  19. Dec 9, 2017 at 7:14 PM
    #1009
    Sigbrown1297
    Sigbrown1297 New Member
    2018 Tundra Platinum
    20x9.5 ET25 with 33x12.5 or 305/55/20 with 3/1 level. Rubbing on 18 CM?
  20. Dec 10, 2017 at 6:15 PM
    #1010
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Cooper STT Pro 295/70R18 on Method NV 25mm offset. No rub. Mud flaps removed, aftermarket bumper, 3” lift, trimmed skid plate but don’t think I needed to. Tires stick out of fenders about 2”. Gravel roads did some damage today. Need to modify my mud flaps and get them back on ASAP!
    J&ATundra, JRock, shapinoweno and 8 others like this.
  21. Dec 19, 2017 at 2:35 PM
    #1011
    Sutterhunter
    Sutterhunter New Member
    Placer County, CA
    2014 Black Platinum Tundra
    3/1 lift, 20" Fuel Trophy's
    Just had some Fuel Trophy's put on, 20x9, Toyo A/T's, 275/65/20, +20. I'm very happy with the look!IMG_0106.jpg
  22. Dec 19, 2017 at 4:29 PM
    #1012
    Ship_Wreck
    Ship_Wreck New Member
    Dave
    Great Thread
  23. Dec 22, 2017 at 10:30 AM
    #1013
    naptown21
    naptown21 New Member
    New member, first-time poster
    I am looking to buy my first Toyota Tundra in February. Have essentially found the truck I want:
    2018 CrewMax SR5 (Silver Sky)
    I've been reading this thread for a few days (extremely helpful, you all are awesome / nuts about your trucks) and am looking for help.
    Basically, there is a truck in my work office park that I love. I got in touch with the owner but she bought the truck used and doesn't know all the details of the modifications.
    What I want to know is if the white truck in the pictures below has any mods (eg. lift / leveling, spacers, etc.) other than the BFG KO2s.
    I'd like to know what I'm getting into before buying my Tundra and if I can just put on a set of KO2s and roll!!
  24. Dec 22, 2017 at 1:15 PM
    #1014
    thetwood
    thetwood New Member
    Louisville, CO
    2017 Blazing Blue Limited CrewMax TRD
    Kings, SPC, Icon Six Speed, Falken Wildpeak AT3w
    Falken Wildpeak AT3W 35x12.50 r17 on Icon Six Speed wheels. King suspension ended up with 2 3/4" front lift. Rubbing on mount till I did a BMC. Also removed front mud flaps and pushed the wheel well liner forward as far as it would go. Perfect now.IMG_2802[1].jpg IMG_2810[1].jpg
  25. Dec 22, 2017 at 1:27 PM
    #1015
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Hard to tell from that angle on the white one. Pics looking down the side and from the side would be beneficial, pics of the front coil overs and of the rear axle/leaf springs would be easiest to tell. Doesn’t look like there are wheel spacers.
  26. Dec 23, 2017 at 7:45 PM
    #1016
    SSGmedic
    SSGmedic New Member
    2017 SR5 4x4
    How’s it going. First post for me. I just got my 2017 SR5 4x4 for Christmas. I have some left over Fuel 20x9 +20 offset with 275/55/20 Wild Peaks that are still pretty damn new. It’s from a Chevy so I have 5 to 6 lug adapters coming that are 2inch. How far out will these sit, and will I need to lift or do any trim work to make it happen. I’m looking for a wide stance. Also I know I should probably sell those rims for 5 lugs but the kids drained the reserve funds for now. Thanks.
  27. Jan 1, 2018 at 7:58 PM
    #1017
    EduardMusatov
    Eduard Musatov
    Lynden, WA.
    Black Rhino 20X10 0 Offset BFGoodrich All-terrain T/A Ko2 Lt 285/55/20
  28. Jan 5, 2018 at 7:11 AM
    #1018
    white offroad
    white offroad New Member
    Anthony
    North Carolina
    I can get a deal on a set of 20x9 XD Heist wheels only thing I'm concerned about is they are -24 offset. Currently I have a 3/1 readylift and 18x9 with -12 and 35" tires. I had to do a good bit of trimming just to get those to fit. How much more will I need to do to get the XD's to fit and what size tire would you guys recommend?
  29. Jan 5, 2018 at 7:38 AM
    #1019
    Fuel Lethals 20x10 with -19 offset on 35/12.50/20 Toyo Open Country Mt
    Biby, Noodle, Tony v and 1 other person like this.
  30. Jan 7, 2018 at 5:11 PM
    #1020
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Sick!
    kevin9763 likes this.
