What could this be?
Discussion in '2nd Gen Tundras (2007-2013)' started by Muntazir, Nov 19, 2017.
  1. Nov 19, 2017 at 5:25 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    You two are about to be neighbors. :confused:
  2. Nov 19, 2017 at 5:26 PM
    Ah, you learned how to turn off caps lock. Who has the answer?
    Phone a friend
    SouthBoundSteve likes this.
  3. Nov 19, 2017 at 5:27 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    To reiterate, that appears to be the Cam Tower leak. It doesn't look too bad, mine actually had oil forming drips. The reason that you don't want to tel it go and just keep adding what leaks out, is that there may be noxious fumes. If it gets bad, to the point that it leaks enough to drip onto a hot exhaust manifold, your truck could catch fire and someone could die (this hasn't happened, just a speculative worst case scenario). Seller sounds kinda like a dick, but that's just my opinion, and should be taken with a grain of salt. My warrantied repair for this was just over 2K, that was for both sides repaired. You could still try your luck with a call to Toyota Corporate. Be prepared to make several, I don't think that they're really interested in fixing this if they can avoid it. You may be able to find an independent shop that's done a few of these repairs if it comes to that.
  4. Nov 19, 2017 at 5:28 PM
    Ill bet all of @aramirez73 BL stock it is a cam tower leak.
  5. Nov 19, 2017 at 5:30 PM
    TheBeast
    TheBeast The Beach
    Personally I would get it fixed but no need to stress over it.
  6. Nov 19, 2017 at 5:41 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Recommended oil is not 5-20 it's 0-20...
    Yeah...Another Yankee moves south. Thats fine just don't bring your Yankee voting habits with you...
    Stormtrooper81 likes this.
  7. Nov 19, 2017 at 5:46 PM
    Vizsla
    Vizsla 2 = 2.5
    I am a 3 time cam tower loser, but they were all under 20k miles or less. It’s not if, but when, they all seep at some point, mine dripped, left oil in my garage, and smelled burning oil. You have a 8 year old truck, it will sweat horsepower, no drips on ground, no burning smell, life should be good. I also see at least one trail down from the valve cover gasket, could be that simple. If it bothers you, clean the crap out of your motor, buy an engine oil dye kit(a few days will reveal if you have a leak or normal seeping). Then if needed document results(pics), and go talk to the mechanic first. Doubt oil consumption is an issue.
  8. Nov 19, 2017 at 5:53 PM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    This issue for whatever reason makes me get crazy ideas trading it in and getting a Tacoma (which I know is retarded). I still haven't seen it on any 2016's so my fingers are crossed.
    OP, welcome to the forum. This place is awesome. It's sad, but I talk to a lot of these people more than some members of my family. Your leak doesn't look too bad. Besides this issue and the AIP pumps, these trucks are solid.
  9. Nov 19, 2017 at 7:03 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Hoooooooollleee up!!!!
    If Cam Tower is the same as Valve Cover then this is an easy fix. I did mine right after I bought my truck and the cost was what..... under $100 and doing the surgery.
    If they are not the same them am back to eating my Doritos and the game!!!!
    Are they the same?
    4x4_Angel likes this.
  10. Nov 19, 2017 at 7:13 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Not the same. The Cam Tower leak is WAY more involved.
    Les7311[QUOTED] likes this.
  11. Nov 19, 2017 at 7:18 PM
    Les7311
    Ok.
    Back to eating Doritos.
  12. Nov 19, 2017 at 8:22 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Now I’m hungry.
    4x4_Angel and TheBeast like this.
  13. Nov 19, 2017 at 8:38 PM
    tacomawv
    tacomawv New Member
    Richard
    If it makes you feel better I have driven cars with a lot worse leaks. My jeep leaks about the same and I have no concerns.
    Stormtrooper81 and Muntazir[OP] like this.
  14. Nov 20, 2017 at 7:16 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Missed it but I can tell you, I will pass. However, I’ll play Santa and get you a bottle...
    4x4_Angel and T-Rex266[QUOTED] like this.
  15. Nov 20, 2017 at 8:06 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    o_O
  16. Nov 20, 2017 at 10:28 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    I had a cam tower leak. It looked exactly like the op's photo. The oil would leak down and burn on the heat shield right below it (the shiny metal with the honeycomb like pattern). It smelled horrible. The dealer originally thought it was a valve cover gasket and replaced that first, which did not fix the problem. Eventually, mine was fixed under warranty. The leak did not affect the performance of the tundra and did not produce a noticeable drop in engine oil. It is a difficult question of whether I would pay to fix it myself if it was not covered by warranty. If I were in the OP's position, I may just try to sell the vehicle and cut my losses. I'd trade it in so that it becomes a dealer's problem and not some poor other person's.
    Muntazir[OP] likes this.
  17. Nov 20, 2017 at 10:32 AM
    Muntazir
    Muntazir [OP] New Member
    I am certainly thinking about going that route but I don't know if I want a 40K commitment. I have already paid 1700 to register it in CT and I will certainly be out of that money :(.
    What do you guys think? should I trade this in and just buy a brand new one?
  18. Nov 20, 2017 at 10:42 AM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    I can't answer the trade in question, but it seems to me the mechanic who told you it was fine is really the one liable for this issue. You purchased it based on his assessment, if he would have provided an accurate assessment describing the leak and potential cost and you bought it anyway then he is off the hook. Did he put anything in writing re the tests he performed (compression, etc) or the mechanical quality of the truck? If so, he should be the one that pays for the repairs. I wouldn't let him repair it though :)
  19. Nov 20, 2017 at 10:45 AM
    Muntazir
    The Mechanic is about .5 miles away from my house and is a local guy. I am pretty mad at him but oh well, What am I gonna do? He didn't put anything in writing and didn't charge me for the inspection either. I think he tried his best. The truck is in such a good shape that it may have fooled him and he didn't deem it necessary to really look at everything.
  20. Nov 20, 2017 at 11:17 AM
    #50
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The mechanic may simply not be familiar with the issue that Toyota has with the leak. You went to him seeking his opinion, not an absolute verification. Ultimately, you had to decide what weight to give to his assessment, then decide whether to purchase or not.
  21. Nov 20, 2017 at 11:20 AM
    #51
    Muntazir
    I agree with you. Since I don't know a lot about engines, I tried to give business to a local shop. I guess you live and learn. I have got the dye and UV light on order and will keep all of you posted.
  22. Nov 20, 2017 at 11:47 AM
    #52
    TheBeast
    TheBeast The Beach
    I would run the dye test before making any big $$ decision. You can monitor the extent of seeping or leaking.
    when was the last time an oil change was done on your truck and how does the dipstick look ?
    As far as trading for new or whatever, this is a much bigger purchase than just getting the issue fixed and go on with your truck and life. I'm sure on the trade a dealer would low ball you for what the cam leak fix would cost you at a dealership.
    I would keep the truck and get the leak fixed. It's not like you blew the transmission and the truck cannot drive.
  23. Nov 20, 2017 at 11:50 AM
    #53
    TheBeast
    TheBeast The Beach
    plus your truck has 95K ish miles. You should have flushed most of the potential issues already.
    Wynnded and Muntazir[OP] like this.
  24. Nov 20, 2017 at 12:02 PM
    #54
    Muntazir
    I called Toyota to see if they could help me out but they couldn't however they did mention that the vehicle has had all recalls done and has a good service history. At this point, I am going to do exactly what you suggested. The last OIL change was done recently by the seller but I am going to get one done just for the peace of my mind. I am also have rear/front differential and transfer case OIL changed. I am also going to drain and replace the ATF.
  25. Nov 20, 2017 at 12:30 PM
    #55
    TheBeast
    TheBeast The Beach
    yeah fresh oil, drop that dye and drive it. If it leaks it will show with the UV light/yellow goggles then you can tell if it's both sides and where.
  26. Nov 28, 2017 at 11:27 AM
    #56
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    I am at Toyota dealership, they're replacing my valve cover gasket (under warranty:thumbsup:)... IMO mine looks like a cam tower leak :argue:but dealer wants 2 do valve cover gasket 1st. Which I guess, I understand... less labor and parts for them.
    Afterwards I guess I watch like a hawk and hope that it fixes it. The kicker is, if this doesn't fix the small leak, then I have to make sure I don't drive too many more miles and put myself outta warranty :confused:
  27. Nov 28, 2017 at 11:48 AM
    #57
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    To restate what everyone has already made abundantly clear, I am almost certain that this is a Cam Tower leak. It is expensive to get fixed, 3-4k, most likely.
    If I were in your shoes I would just not worry about it and add oil if it gets low.
    If it makes you feel better, I had a 2000 Toyota 4runner that leaked roughly 7 quarts of oil per oil change (5,000) miles. It gave a whole new meaning to "leaking like a sieve". However I just checked and added oil every few days and the motor lasted to just under 500,000 Miles.
    Honestly, just check the oil and add oil to it if it gets low. Toyota recommends 0w-20 or 5w-20 motor oil for the Tundra. There are valid arguments out there for using more viscous oil (thicker), mainly CAFE standards, and engine longevity.
    Save yourself some $$$
  28. Nov 28, 2017 at 12:20 PM
    #58
    SouthBoundSteve and TheBeast like this.
  29. Nov 28, 2017 at 4:53 PM
    #59
    gdiep
    Syracuse, New York
    Have them put dye in the oil. You'll know very quickly if its a cam tower leak.
    TruckLife900[QUOTED] likes this.
  30. Nov 28, 2017 at 6:57 PM
    #60
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Seller said he sold under book value. What book and how did he rate condition? Exceptional is like brand new and very few vehicles fall in that category. I am guessing he used NADA which can be way over valued. Best gauge of value is what similar vehicles actually sell for. Something between NADA and KBB is probably real value. I never would never have sold my 2013 for NADA value. I would drive and monitor oil levels before I dumped $3k into it. $3k buys a lot of oil. Not sure of Ct. laws but in Texas you get tax break on trade value. Most likely dealer will catch leak they are pretty thorough when evaluating trades. Clean trades are where they make money. I would try cleaning right before trading and see what you can do. If you can find a 2017 you like there are some great deals right now.
