Grinding noise
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nickj619, Nov 19, 2017.
  1. Nov 19, 2017 at 1:06 PM
    Nickj619
    Nickj619 [OP] New Member
    San Jose, ca
    2014 tundra trd crew max
    Hi guys just picked up a 14’ tundra CrewMax trd. It does have a level kit on it. I noticed when making a left u-turn with the wheel fully locked it makes a pretty bad grinding noise. Any ideas would be extremely appreciated
  2. Nov 19, 2017 at 1:22 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Like rubber on plastic? Rubber on the cab? Or metal on metal? What size tires?
    1UP, 14burrito, TheBeast and 2 others like this.
  3. Nov 19, 2017 at 1:39 PM
    Nickj619
    San Jose, ca
    Sounds like metal on metal, Only with steering wheel fully locked. Reading online some people said they greased the steering stops and that fixed it
  4. Nov 19, 2017 at 2:10 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Do you have bigger tires? Most rubbing doesn’t sound like metal on metal, but I would check that first just to be sure. See if there are any rub marks on the front plastics, the cab mount, and your skid plate. Or get someone to drive it while you stand outside and try to see where the sound is coming from.
  5. Nov 19, 2017 at 2:13 PM
    Nickj619
    San Jose, ca
    Thanks for the suggestion, it’s got meaty 275/70-18s on it. I checked to see if any of the surrounding plastics had marks but nothing. Checked the dust shields on brakes as well. Going to try some grease. Maybe have the alignment checked to see if anything is off
  6. Nov 19, 2017 at 2:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Might as well try greasing the steering stops. I remember reading about that on another forum.
  7. Nov 19, 2017 at 2:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Bacon grease might work better. :p
    SouthBoundSteve likes this.
  8. Nov 19, 2017 at 3:43 PM
    Nickj619
    San Jose, ca
    Thanks for the suggestions guys. I’m going to check out greasing those stops, like I said it’s only when steering is completely locked too, anything less than that and no rubbing. Any of you guys with a front lift/leveling kit notice Any changes in sound? When I roll down my driver window when going over 40mph the wind flowing through the vehicle sounds a little different, almost like something was stuck or flapping around under the wheel well
  9. Nov 19, 2017 at 4:45 PM
    Nickj619
    San Jose, ca
    It’s weird, I know I’m probably hypersensitive to every little noise since I just bought the vehicle. Runs great, just have a feeling the leveling kit up front altered the suspension geometry in a way I’m not used to
  10. Nov 19, 2017 at 5:14 PM
    Nickj619
    San Jose, ca
    Friend of mine owns a shop and pretty much all of them have tundras I think I’ll stop by next week and have him look over the suspension and see what he can dig up. This site is awesome by the way, didn’t expect so many helpful replies so quickly
  11. Nov 20, 2017 at 3:30 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Mine does the exact same thing. Figured out it's the skid plate. I haven't had a chance to trim it but will do so pretty soon.
    Might try greasing the steering stops too.
  12. Nov 20, 2017 at 3:41 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    @Nickj619 , I had the same problem with a grinding noise after a lift I put on it. Turns out it was the skid plate being rubbed. Sounded just like metal grinding though.....
  13. Nov 20, 2017 at 7:15 PM
    Nickj619
    San Jose, ca
    Thanks guy I’ll check out the skid plate
  14. Nov 20, 2017 at 7:18 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Lol start there and come back with what you find.
    Oh yeah. Welcome to tundras.com
  15. Jan 3, 2018 at 7:29 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I just heard the noise when turning hard left with my 6112s installed. I have the same wheels and tires both stock.
    Anyone figure out for sure what the noise is? Thanks.
  16. Apr 3, 2023 at 9:42 AM
    GrizzlyJimmy
    GrizzlyJimmy Big Dog
    New Jersey
    2017 Black DC Long Bed
    Clazzio seat covers, Husky liners, VLEDs, TRD Rear Sway Bar
    Anybody every figure this out?
  17. Apr 3, 2023 at 10:11 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    Well when the wife’s old Santa Fe was doing that, the rear was shot and dumped it for a sienna
