Red@9k Build Thread
Discussion in '2.5 Gen Builds (2014-2021)' started by Red@9k, Oct 17, 2017.
  1. Nov 15, 2017 at 6:49 PM
    #61
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    How much height are you running on them kings @Red@9k ?
  2. Nov 15, 2017 at 10:15 PM
    #62
    TheBeast
    TheBeast The Beach
    love my Kings. can't go wrong.
    Red@9k[OP] likes this.
  3. Nov 15, 2017 at 10:41 PM
    #63
    Red@9k
    Red@9k [OP] New Member
    Erik
    2015 Super white Crewmax Tundra
    Didn't make any height adjustments on them so I believe Kings sets them up at 2" out of the box and I installed them as-is. I'll probably lift the front another inch when i remove the front wheels for the CMC install tho. It's a pain in the ass doing everything on jack stands in my driveway.
    4x4_Angel and BlueBottle[QUOTED] like this.
  4. Nov 15, 2017 at 10:46 PM
    #64
    Red@9k
    Erik
    Thank you. It's definitely my all time favorite wheel and color. I use it on all my car builds and looks good on just about anything.
  5. Nov 15, 2017 at 10:47 PM
    #65
    Red@9k
    Erik
    Right. I was almost about to hold out for the 3.0 kings but it' overkill for me at least. Beast of setup tho
  6. Nov 15, 2017 at 10:59 PM
    #66
    TheBeast
    TheBeast The Beach
    same here. overkill for my uses.
    Eclipsed & Floating likes this.
  7. Nov 15, 2017 at 11:22 PM
    #67
    Red@9k
    Erik
    Quick question? What are you front coils set to for ride height? Also, are you running shackles? Debating about adding the CB ones
  8. Nov 16, 2017 at 9:22 AM
    #68
    TheBeast
    TheBeast The Beach
    stock height from King for now. will go up when I go with Deaver pack/shackles in rear
    Red@9k[QUOTED][OP] likes this.
  9. Nov 16, 2017 at 11:44 AM
    #69
    Red@9k
    Erik
    Gotcha. Trying to decide that myself as well.
  10. Nov 16, 2017 at 7:42 PM
    #70
    Gtfour43
    Gtfour43 New Member
    Oahu
    How much were your kings if you don't mind? Where did you buy them from?
  11. Nov 16, 2017 at 7:56 PM
    #71
    Filthy13
    Filthy13 New Member
    NorCal
    2017 White 1794 TRD OR
    A few goodies
    Erik, I have kings and CB shackles installed. Let me know if you want to meet up - the visual might be helpful with deciding shackle size. Awesome build you have going!
  12. Nov 17, 2017 at 10:44 AM
    #72
    Red@9k
    Erik
    They're about $2200( No adjusters) & $2800ish w/adjusters. I got mine directly from Kings in Socal. I called and spoke with them directly and they were very helpful so just placed an order with them since they helped me out. I could've probably found a better deal though a vendor here. I'm in Cali so sales taxes is few hundred alone lol
    Gtfour43[QUOTED] likes this.
  13. Nov 17, 2017 at 10:47 AM
    #73
    Red@9k
    Erik
    I'm going to take you up on that offer...is it the +3? what are your front set too?
    Filthy13[QUOTED] likes this.
  14. Nov 17, 2017 at 12:16 PM
    #74
    Red@9k
    Erik
    My buddy says I should've went with American forces
    BlueBottle likes this.
  15. Nov 17, 2017 at 12:27 PM
    #75
    Filthy13
    Filthy13 New Member
    NorCal
    A few goodies
    11 threads showing on the drivers side; 7 on the passenger side. Took care of most of the Tundra lean. Let me know if you’re ever in the Loomis area. I’d like to check out your front bumper caps... I’m considering getting mine powered coated.
  16. Nov 17, 2017 at 3:03 PM
    #76
    TheBeast
    TheBeast The Beach
    I have 7 threads passenger side and 8~9 threads driver side. Still has some minimal lean. I think it's about 2" height total for me.
    Filthy13 and Red@9k[OP] like this.
  17. Nov 17, 2017 at 4:09 PM
    #77
    Red@9k
    Erik
    Mine are both at 7 threads. Gonna get some measurements on mine and see how bad the lean is. I did read that adding a CB shim on the driver side helps with lean.
    @Filthy13 Will do. For the cost and durability powdercoat was the best choice. $35 an end cap. Not a perfect match but it's close enough and doesn't bother me.
    TheBeast and Filthy13 like this.
  18. Nov 20, 2017 at 9:21 AM
    #78
    Red@9k
    Erik
    Went ahead this weekend and installed my driver side headlight last night. New passenger side replacement will be here tomorrow. Dam, what a difference these lights make in appearance. 100% satisfied in going this route.
  19. Nov 20, 2017 at 9:36 AM
    #79
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Them Volks got me doing backflips at work!
  20. Nov 24, 2017 at 12:29 AM
    #80
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    With your harness from slightwork do the leds dim when the headlights are on? Did you have to cut the grey wire inside the cab?
  21. Nov 26, 2017 at 1:05 PM
    #81
    Red@9k
    Erik
    LED DRL is on full bright at all times. I wanted it like that personally. No cutting of any wires.
  22. Nov 27, 2017 at 7:49 PM
    #82
    Red@9k
    Erik
    20171126_154033.jpg 20171126_153955.jpg Went up to Laporte this weekend for the annual Thankgiving dinner. No snow but still had a blast.
  23. Nov 27, 2017 at 8:18 PM
    #83
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Looking good! No more chrome!
  24. Nov 27, 2017 at 8:51 PM
    #84
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Damn!!! That thing is looking soooo good
  25. Nov 27, 2017 at 9:05 PM
    #85
    Bannock452
    Bannock452 New Member
    Brandon
    Murrieta, CA
    2016 White Crewmax 4x4 SR5
    King coilovers 35x12.50-18
    Badass truck man! Blue is my favorite color. That’s why I got my Kings. Glad you finally got your new headlights. They look super clean. Keep the pix comin
  26. Nov 27, 2017 at 9:06 PM
    #86
    TheBeast
    TheBeast The Beach
    looking sharp
  27. Nov 29, 2017 at 11:03 AM
    #87
    Red@9k
    Erik
    Almost, there's still 4 chrome badges but I have the TRD Pro replacements already just need the time. It gets dark early AF now so have to make time this weekend hopefully.
    BlueBottle[QUOTED] likes this.
