Grade of fuel
Discussion in 'General Tundra Discussion' started by blazin461, Nov 2, 2015.
  1. Nov 12, 2017 at 8:16 AM
    Welcome from Texas! Let's see your ride
  2. Nov 12, 2017 at 8:21 AM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Welcome from AZ! Just run 87 and you'll be fine.
  3. Nov 12, 2017 at 10:30 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    87 octane
    Welcome from Cleveland, Ohio!
  4. Nov 12, 2017 at 11:50 AM
    Welcome from CO. I use 87. Truck is factory tuned to perform best with 87 if I remember correctly.
    Baja Mike and GNTundra like this.
  5. Nov 12, 2017 at 12:47 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome
  6. Nov 12, 2017 at 12:50 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Welcome from San Antonio! I run 85 in mine.
  7. Nov 13, 2017 at 8:34 PM
    Lxa772
    Lxa772 New Member
    Jake
    Tundra limited 2017
    Thank you all for the suggestions!
  8. Nov 13, 2017 at 9:22 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Welcome! I run 87 in my Tundy....no issues here!
  9. Nov 14, 2017 at 3:26 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    So higher octane = better? Not true here. You can get ethanol free at some stations when you head out of DFW area but in 87 only. I hear the reason why is because they use ethanol to boost octane. I ran a carbed Mercury outboard with milled heads and 140 lbs compression. I had to run high octane. I really liked to run the ethanol free but had to add an octane booster when I did.
  10. Nov 14, 2017 at 1:16 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Another Welcome from Texas. Most stations have either 87 or 89 as the lowest octane, run whatever they have. As has been mentioned before, stick with Top Tier gas http://www.toptiergas.com/ and you'll be fine.
