Level kit? What should I use?
Discussion in 'Suspension' started by fireguykirk, Nov 7, 2017.
  1. Nov 7, 2017 at 10:48 PM
    fireguykirk
    fireguykirk [OP] New Member
    Kirk
    2017 tundra crewmax platinum
    level kit, tires, fuel wheels,
    I am selling my 05 double cab with 6” RCD lift.
    I just bought a 2017 crewmax platinum. Looking into what suspension to do.
    1. Revtek spacer in front to level the Truck.
    2. Toytec 3/1 basic spacer lift
    3. OME coil overs in front and shackle or add a leaf in the back.
    What do you think?
    I primarily use my truck on the road but go up logging roads and hit the snow a lot in the winter. I will also be putting aftermarket tires and wheels on
  2. Nov 7, 2017 at 11:18 PM
    Zero One Actual
    Toytec Boss lift kit. Call them and they will lead you down the path of comfort and enlightenment. Don't put a spacer lift on your truck. That's like only having 100 feet of hose on your ladder truck!
    That kit allows you to run a 17 or 18 inch rim with up to 35's.
  3. Nov 8, 2017 at 5:44 AM
    Toytec BOSS kit! It’s valved for the Tundra and adjustable.
    drobb, Jsena, Troy2017TRD and 7 others like this.
  4. Nov 8, 2017 at 5:58 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Hello and welcome to the forum, great group of people in here with more than enough knowledge to help you out.
    When it comes to a nice kit that will give you aggressive stance but without breaking the bank, check out the new Toytec/ Eibach kit we have to offer! http://toyteclifts.3dcartstores.com/TTHA-TUN--ToyTecEibach-3-Lift-Kit--07Tundra_p_1828.html
    Its a non adjustable 3'' kit in the front along with a 1'' block in the back to give it that equal/ level stance in all 4 corners. Or you can swap the rear end lift out to an adjustable shackle if you would like.
    There are a ton of options that we have to offer you, shoot me a message anytime and we can chat more about them and figure out what is going to be the best bet for you!
    Thanks!
  5. Nov 8, 2017 at 8:04 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    IMO different shocks/ coils is preferable to a Revtek urinal cake* on top of stock shocks. Then you just need to decide what shocks/ coils.
    *credit to @MotoTundra for the analogy.
  6. Nov 8, 2017 at 9:04 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Haha good memory! I agree with @16tunterd and the others, don't take the urinal cake route.
    SouthBoundSteve likes this.
  7. Nov 8, 2017 at 2:15 PM
    #KNOWN!
  8. Nov 8, 2017 at 2:18 PM
    ^new acro...UCS...urinal cakes....!!
    MotoTundra[QUOTED] likes this.
  9. Nov 8, 2017 at 3:18 PM
    A pair of UCS make great sinkers when bottom fishing for rock cod 400ft down.........no..wait...aluminum. Worthless after all.
  10. Nov 8, 2017 at 9:48 PM
    Troy2017TRD
    Troy2017TRD New Member
    Eugene,OR
    2017 SR5 CM TRD
    ToyTec/Eibach 3" lift, SPC UCA's, 275/70/18 BFG KO2's, Line X Spray in Liner, Bakflip MX-4 Tonneau Cover, Window tint.
    I just bought my first Tundra and am curious about suspension lifts too. I would like to hear some feedback on the OME setup as well and how it compares to the Bilstein and Toytec setups.
  11. Nov 8, 2017 at 10:47 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    Is the ride quality similar between the Eibach and the Boss kits? Advantages for Boss other than the height adjustment?
  12. Nov 9, 2017 at 7:39 AM
    Toytec Lifts
    Denver, CO.
    Honestly the biggest difference is going to be that the BOSS coilovers are adjustable and the Eibach's are not going to be.
    Thanks!
    T-Rex266 likes this.
  13. Nov 9, 2017 at 10:06 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Very Interesting. Does it come with a red spring? Ha. I've been on the fence of getting the Boss kit, was just waiting to save up a little more funds. But this is about a $400 difference. Hummm...
  14. Nov 9, 2017 at 11:53 AM
    Toytec Lifts
    Denver, CO.
    We do not offer a red spring at this time, just the silver.
    Thanks!
  15. Mar 11, 2020 at 6:03 PM
    GOBUCKEYES
    GOBUCKEYES New Member
    Jeff
    How do u guys feel about the bilstein 6112 system
  16. Mar 12, 2020 at 2:22 AM
    Zero One Actual
    Bob likes this.
