Constant weight
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tondra, Nov 6, 2017.
  1. Nov 6, 2017 at 12:41 PM
    Tondra
    Tondra [OP] New Member
    2018 Magnetic Gray Metallic SR5
    I run an auto detailing business and I have a 60 gallon water tank at the back of my truck. I don't fill it up to 60 gallon but only up to 30 gallons. With all my supplies and equipment I think I may around close to 700 lbs. at the back.
    My question is I don't plan to unload the truck so all that weight will always be there well except when I use up the water. Will the constant weight damaged my leafs? The truck is not sagging.
  2. Nov 6, 2017 at 1:10 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes, they're going to get flattened real quick. Maybe add some leafs before it happens.
    Y0TA PR0, Black Wolf and TXMiamiFan like this.
  3. Nov 6, 2017 at 2:17 PM
    Ditto ^ An AAL certainly couldn't hurt.
  4. Nov 6, 2017 at 6:38 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Get air bags and a trailer. Put your detailing stuff on the trailer..
    NewImprovedRon likes this.
  5. Nov 7, 2017 at 8:27 AM
    Tondra
    The trailer is a great idea but I have no place to store it. I don't want to pay monthly storage fees as well.
    I'm either going to try SumoSprings or add an extra leaf. I got the actual weigh of all my stuff including 30 gallons of water and its about 425 lbs. I over estimated by a lot.
  6. Nov 7, 2017 at 8:34 AM
    CaptObvious
    CaptObvious New Member
    Patrick
    2015 Black Tundra SR5 Crewmax TRD
    I put a set of Firestone ride rites without onboard air, super easy to install! and can hold quite a bit. I ordered mine from Amazon pretty cheap.
  7. Nov 7, 2017 at 8:54 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    You keep it in the bed all the time now. Pull the trailer all the time. Just get Air bags they are better than sumo springs/bump stops and only $100 more. AB ride good when loaded.
  8. Nov 7, 2017 at 9:13 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I have no complaints on my Sumosprings after having them for a few weeks. They don't change unloaded driving at all. They're simple and maintenance free. I debated between them and air bags for a while. I didn't want the compressor, lines, and bladders.
  9. Nov 7, 2017 at 10:20 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    HE doesn't drive unloaded. He's loaded all the time. He doesnt need a compressor. Just ck it monthly.
