BFG ko2 Tires 305/65/18
Discussion in 'Wheels & Tires' started by Young80i, Nov 1, 2017.
  1. Nov 1, 2017 at 11:55 AM
    Young80i
    Young80i [OP] New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    What do you guys recommend on the psi? Ko2 305/65/18..Contacted BFG and they said 35 front and 45 rear.
  2. Nov 1, 2017 at 12:14 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    I run 35 on both. 45 in the rear seems a bit ridic
  3. Nov 1, 2017 at 12:45 PM
    Young80i
    Kyle
    Garden Grove CA
    2015 Platinum
    Oh man I had 35 on both. Just put 45 on the rear lol
  4. Nov 3, 2017 at 5:59 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    On those, 35 will give you 2600lbs load, which should be about what the factory tires were, 45 psi will get you up to about 3000,
