Wheel conversation
Discussion in 'New Member Introductions' started by Ben_jamin25, Sep 15, 2025 at 11:18 AM.
  1. Sep 15, 2025 at 11:18 AM
    Ben_jamin25
    Ben_jamin25 [OP] New Member
    Monday
    2015 Tundra i-force 5.7 litre SR5
    I have a 2015 Tundra SR5. I have the opportunity to acquire a set of tires sized 265/60r20 112h on stock 20" rims with 6 lug pattern. Tires have less then 3000 miles on them. My 2015 has 18" 5 lug pattern. I am considering using Venum wheel adapters, 5x150 mm to 6x5.5". Will this work? Thanks.
  2. Sep 15, 2025 at 11:23 AM
    It's not quite that simple, but yes it could. The lugs on the adapters need to match the size on the new (I'm assuming) Tundra 3rd gen wheels. Different than the lugs on the 1st Gen Tundra that also has the same bolt pattern. Backspacing will also change, but probably for the better. Know that if those are stock tires, they run out faster than comparable aftermarket versions. Tundras ship with an "OEM version" of most tires. Less tread and compound / tread patterns that maximize MPG and minimize cost for Toyota. I haven't heard of the Venom brand of wheel adapters. Most run Spidertrax or Bora.
    Ben_jamin25[OP] likes this.
  3. Sep 16, 2025 at 4:41 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
