2012 Parking Sensors upgrade?
Discussion in '2nd Gen Tundras (2007-2013)' started by Aramk, Aug 26, 2025.
  1. Aug 26, 2025 at 1:21 PM
    Aramk
    Aramk [OP] New Member
    Aram
    2012 Tundra crewmax 5.5 bed platinum
    I just got a 2012 Tundra Crew Max, and the Parking assist sensors are quite weak on it. Looked it up it uses ultrasonic proximity sensors. Their effective detection range typically spans roughly 0.3 meters (1 ft) up to about 2–3 meters (6–10 ft). The front sensors only activate at very low speeds (below ~5–6 mph). I would like to see if there is a better solution for this, as the detection is outside of my comfort range. Is there an available upgrade without getting into heavy wiring and extra equipment, or do I live with it?
  2. Sep 15, 2025 at 11:37 AM
    FDNewbie
    FDNewbie New Member
    I tried an ultrasonic aftermarket kit that gets applied on the inside of the bumper several years back, and it was total crap. I personally haven't come across a simple alternative to upgrading/adding proximity sensors without a full out retrofit :(
