Do I need to reboot these CV axles?
Discussion in '1st Gen Tundras (2000-2006)' started by BigTuna8695, Sep 7, 2025.
  1. Sep 7, 2025 at 5:58 AM
    BigTuna8695
    BigTuna8695 [OP] New Member
    05 DC Limited 4x4
    Hey, all. Apologies for being a noob when it comes to basic knowledge on vehicles. I recently bought a first gen. When I took it for the initial inspection when I got it back to NY, I noticed there was some grease that had kicked up under the truck from the CV boots. I took some photos this morning. The outer boots like fine, but the inners look a little dicey to me.
    Couple questions.
    1. Do the inners look like they need to be rebooted?
    2. If so, is it fine to just use reboot the inners with these high angle inner boots and keep the original outers on? Or should I just replace all 4 boots at once?
    IMG_2221.jpg IMG_2222.jpg IMG_2223.jpg IMG_2228.jpg IMG_2229.jpg IMG_2224.jpg IMG_2227.jpg IMG_2230.jpg
  2. Sep 7, 2025 at 8:09 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I don’t see anything crazy but it wouldn’t be a bad ideas to have it on your radar. It looks like you slung some grease from a lift; or at least new springs raising the truck compared to old worn out springs? I see new coils in the pictures indicating this.
    I would clean the areas around the clamps to get a good look at the area and look for cracking.
    There’s some slight cracking in the areas circled in this picture.
  3. Sep 7, 2025 at 8:56 AM
    I would clean the inners as recommended and see if they’re still an issue. They may just need new bands which would require the purchase of the correct band clamping tool so they’re not half assed and leak even more.
  4. Sep 7, 2025 at 9:14 AM
    bfunke
    bfunke Tundra Curmudgeon
    Looks like a little slinging on the pax side. Clean it up at the DIY car wash and watch it. May only need the clamp tightened a bit.
    chugs likes this.
  5. Sep 7, 2025 at 9:50 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    If it were me I'd go ahead and replace both.
    I might even go as far as to replace all four on both sides.
    But then I'm kinda anal about Shi..Stuff like this.
  6. Sep 9, 2025 at 4:15 AM
    Dook55
    Dook55 RCLB Guy
    Montana
    They look a lot better than mine. I wouldn't replace them. They look like factory boots/axles. Mine are NAPA axles (don't buy them) and the Chinese boots are cracked in several places. They use cheap neoprene, probably mix clay in it to increase profit. Not leaking yet and no significant slop in the axles yet. I bought NAPA's "lifetime warranty" axles and twice I have taken them back and had them give me new ones. They last about 60K miles.
  7. Sep 9, 2025 at 8:20 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Ya that's another thing. @BigTuna8695 those are OEM axles and are hard to get anymore. If you're able to and up for it, I would reboot those axles rather than buying aftermarket. If the truck being down is an issue I would buy a cheap NAPA axle and swap it in while you reboot the OEM axle and then swap that into the other OEM axle; reboot, and then replace the NAPA axle.
    Reboot kits are $60 each and the OEM style tool $20 plus the earless too is $20. I say OEM style tool because you just need to buy a knock off from one of the big websites.
  8. Sep 9, 2025 at 9:01 AM
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
    Avoid aftermarket axles, use the OEM reboot kit and party on.
    SolarOctane22 likes this.
  9. Sep 15, 2025 at 7:16 AM
    If the boots aren't torn, re-clamp with NORMA clamps before attempting to re-boot.
