Dilemma
Discussion in '1st Gen Tundras (2000-2006)' started by Bosslarry, Sep 5, 2025.
  1. Sep 5, 2025 at 2:16 PM
    Bosslarry
    Bosslarry [OP] New Member
    Larry
    2000 Tundra SR5 2WD V8
    Light bar on roof and front bumper, yellow and white caution flashers on front bumper.
    I'm going to put it all out there. I don't know if one has to do with the other or not. #1 the cruise quit a couple of weeks ago, haven't found out why. #2 a few days later both driver and and passenger side electric windows quit working. #3 another few days could not get gas to the engine. Checked all fuses and relays and all were fine. Changed the fuel pump and relay, still nothing. No power to the fuel pump. Oh, and also still no power to windows or the cruise. All fuses are good.
  2. Sep 5, 2025 at 2:28 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Others will chime in, but I know that one place to start is this thread and specifically hone in on the water leaks section. These first gen Tundras tend to get water leaks in the passenger side windshield cowl and this corrodes the ECU connections. This results in a wide variety of electrical issues.
    https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/unread
    Also be certain to look at timing belt/water pump, front lower ball joints, and radiator sections
  3. Sep 15, 2025 at 6:53 AM
    Yup. Sounds like he's been leaking water into the in-dash fusebox, and into the connectors sitting along the driver's side kick panel. @Bosslarry the way it hit one circuit, then the next circuit ... there are pics in that thread of the very common leaks into the in-dash fusebox (pics & pics & pics) it happens a LOT. Either because of a piss-poor windshield install, people driving around with cracked windshield, the vertical trim on the side of the windshield is rusted out, or the rubbers for the A-pillar are ripped.
